3rd August 2007, 09:39 | #581 | Link | |
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
3rd August 2007, 11:16 | #582 | Link | |
3rd August 2007, 13:03 | #583 | Link | |
http://www.w6rz.net/xportdev.zip Demux your problem file and note the number of "chunks" when it bombs. Multiply the number of "chunks" by 1048576. This is the approximate offset into the file where the bomb occurred. Then use the clip.exe program (included in the .zip) to clip out a small portion of the file for upload. Here's an example. Let's say that xport bombs at 28376 "chunks". 28376 * 1048576 = 29754392576. Then clip out about 10 megabytes around (-5 megabytes to +5 megabytes) this offset with this command: clip movie.m2ts clip.m2ts 29749392576 10000000 (29754392576 - 5000000 = 29749392576) Then upload the 10 megabyte clip somewhere for me to debug. Make sense? Ron
3rd August 2007, 14:25 | #584 | Link |
Ok, here's my case. The xport encounters problems on me when demuxing LPCM audio from The Exorcism of Emily Rose BluRay m2ts. It starts demuxing fine and makes a .mpa file exactly 33220kB big (that's about chunk 100), then the filesize freezes at 33220kB, but xport still reports that chunks are being processed until the end.
Here's a 10mb sample of the m2ts stream: http://www.box.net/shared/tcl82u257t There's also a 640Kbit DDPlus track but xport never even starts to demux eac3 (the mpa file is always at 0Kb, even though xport reports chunks are being processed). Last edited by smekoslav; 3rd August 2007 at 18:10. |
7th August 2007, 06:56 | #586 | Link | |
The first discontinuity appears at packet 436908. This would be 436908 * 192 or 82886336 bytes into the file. In my 1 megabyte "chunks", this would be at around chunk 80, which is fairly close to your report of audio demux failing at chuck 100. So a better test clip would be about 30 megabytes starting at around 80 megabytes in. This clip command line would do the trick: clip movie.m2ts clip.m2ts 79999872 30000000 Note that 79999872 is a multiple of 192 so that the clip starts on a packet. As for demuxing the AC3 track, you must also demux the video track. That's because for AC3 audio, xport cuts the audio stream to match the first video PTS. If there's no video track specified, then the audio cutting code never starts and no audio gets demuxed. For LPCM, xport doesn't try to sync the audio and specifying video stream 0 works okay. Ron
7th August 2007, 09:41 | #587 | Link |
dmz01,
Thank you for this fantastic tool. Do you have any plans to add muxing capabilities (from elementary streams) to TSRemux or add AVCHD structure to the current options and lastly would it be possible to remove 1088 flag from some h264 streams as this should improve the playability. |
7th August 2007, 13:48 | #588 | Link | |
Anyone found a way to get this working properly? |
8th August 2007, 18:50 | #592 | Link |
New version 0.0.17:
8th August 2007, 18:58 | #593 | Link | |
8th August 2007, 19:15 | #594 | Link | |
C:\Programme\MKVtoolnix>mkvinfo.exe c:\c\TS\test.mkv + EBML head |+ EBML version: 1 |+ EBML read version: 1 |+ EBML maximum ID length: 4 |+ (Unknown element: EBMLMaxSizeLength; ID: 0x42f3 size: 4) |+ Doc type: matroska |+ Doc type version: 1 |+ Doc type read version: 1 + Segment, size 25745124 |+ Seek head (subentries will be skipped) |+ EbmlVoid (size: 14) |+ Segment information | + Muxing application: Haali DirectShow Matroska Muxer 1.7.189.11 | + Writing application: GraphEdt.exe | + Segment UID: 0x64 0xb6 0x1b 0x9b 0xd6 0x5c 0x0c 0x84 0xd2 0x1c 0xf2 0xd7 0x6b 0xc0 0xa9 0x70 | + Date: Wed Aug 08 18:11:59 2007 UTC | + Timecode scale: 1000000 | + Duration: 26.960s (00:00:26.960000000) |+ Segment tracks | + A track | + Track number: 1 | + Track UID: 1 | + Track type: video | + Lacing flag: 0 | + Default flag: 0 | + Codec ID: V_MPEG4/ISO/AVC | + CodecPrivate, length 34 | + Video track | + Pixel width: 1920 | + Pixel height: 1080 | + Display width: 1920 | + Display height: 1080 | + A track | + Track number: 2 | + Track UID: 2 | + Track type: audio | + Lacing flag: 1 | + Default flag: 0 | + Codec ID: A_AC3 | + Audio track | + Sampling frequency: 48000.000000 | + Channels: 6 |+ Cluster |
8th August 2007, 21:08 | #595 | Link | ||
- Add: An option to always crop 1088 video to 1080 lines (enabled by default) I don't know if this is possible but maybe coreavc 1.5 in combination with graphedit can remove the 1088 flag Last edited by enjoyer; 8th August 2007 at 21:11. |
8th August 2007, 23:25 | #598 | Link |
thx for this great tool.
The rexux funktion is nearly perfect. My problen is muxing AVC - and VC-1 videostreams with a new Audiostream. MPEG2 is not a problem, there are a lot of programms avalible. My problem is, a lot of Blu-Ray aren`t availible whit german audiotrack. Is it possible inmux SUPreader. Which Programm i`ve to use to create german Subtitles? Hollydoc. |
9th August 2007, 00:56 | #599 | Link |
I ve tested some h264|1080p *.ts file and tsremux created a faultless blu ray structure...
then I created a AVCHD dvd with hollydoc s method ps3 plays this file without problems and ac3 5.1 output!!! so we need a way to remux h264.mkv properly to h264.ts!!!!! Last edited by enjoyer; 9th August 2007 at 00:59. |
9th August 2007, 01:17 | #600 | Link |
Update to AVCHD burn method
Hello all,
We do not need to go through any trouble to burn AVCHD. After you run your file through TSRemux Bluray, go to BDMV directory and replace the MovieObject.bdmv and index.bdmv with these http://rapidshare.com/files/47821885/BDMV.rar.html (or use the ones that NeroVision produced) and burn the BDMV directory with Nero UDF 2.5 and that IS it. Hope this will help Last edited by Has123; 9th August 2007 at 01:54. |
