#1 | Link |
TsRemux v0.21.2: Transport Stream De/Re-muxer
Having been inspired by Pelican9's and DrMpeg's work, I decided to write a transport stream re-muxer similar in functionality to EvoDemux. Some of the features currently implemented:
Current Version 0.21.2 Notes:
Download link Source Code (GPL) Last edited by dmz01; 21st May 2008 at 02:55. Reason: new version |
#3 | Link |
since im not too familiar with that technical stuff, which transport streams does this tool demux now, only mpeg2 or also h264 .ts streams ? and where do they get demuxed too, in which file or container ?
btw. tried to open a skyHD cap h264 .ts 12 gb file and then a 150 mb sample of this stream: in both cases the cpu seemed to work to infinity, but nothing actually happened, the file apparently cant be opened. Last edited by Thunderbolt8; 5th May 2007 at 00:47. |
#4 | Link |
In theory it should work with any TS file. Is there somewhere where I can download the non-working sample?
I don't demux, since there is already a tool for that. I can add that if there is demand for it. For now I just re-mux into a new TS file. |
#8 | Link |
Pain and suffering
You're free to test all these: http://x264.nl/h.264.samples/
(x264.nl) |
#9 | Link | |
#10 | Link | |
Yes, you can make a sample of a sample etc. even a 1MB sample would be fine as long as it breaks the app. |
#13 | Link |
dmz01 - Thanks. Looking forward to trying this.
Thunderbolt8 - try cutfile - http://jsoto.posunplugged.com/tools/CutFile_exe.zip Edit: dmz01 - drmpeg's Mpeg2 TS test files = http://www.w6rz.net/ AVCHD .MTS files = https://oncourse.iu.edu/access/conte...napp/00055.MTS https://oncourse.iu.edu/access/conte...napp/00043.MTS Last edited by Pookie; 5th May 2007 at 09:01. |
#14 | Link |
I have the same problem here, but with a Blu-Ray .m2ts (AVC)
all my compares are riddles so please try to decipher them yourselves :) current Main XviD PSNRLab version 1.1 current XviD PSNRLab update 1.1.3 MT1389xx Player Infos XviD EDP Build CVS (CruNchers Visual System ©) V 1.4 new with predefined profiles ;) Code:
Olivera: "We're expendable assets"
"and we've just been expended"
#16 | Link |
allright, so its the same as when making a sample for .mkv with mkvmerge (or any other mkv muxer), when I just cancel/close the process in the mid of the work ?
wasnt sure if this way maybe could alter or invalidate the file. edit: doesnt work for me, when I cancel the copy process, the file gets deleted automatically apart from that he copies too fast anyway, so the file would be getting too big that way Last edited by Thunderbolt8; 5th May 2007 at 12:04. |
#17 | Link |
ангел смерти
![]() Join Date: Nov 2004
Virtualdub has a hex editor with a "truncate" menu item. Most hex editors do, as well as those "file splitters", but that's one you probably already have.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt |
#18 | Link | |
For anyone who has an issue, please try go get me a sample if you can. |
#19 | Link |
as written above, I cant do it the way you described
apart from that I have computer problems atm, my comp is is rebooting constantly when I try to open certain things or dl anythig with any browser, get emails etc. (virus?) so I might get back later again |
| Thread Tools | |
| Display Modes | |
