Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 20th March 2007, 12:04   #1  |  Link
PoshSpur
Burning?
Okay, so I've learn't how to use the superb program that is RipIt4me (www.RipIt4Me.org).
I don't have Nero and was wondering how to burn the files onto blank DVD's?
I used freeware Burn4Free, but realised that the DVD wouldn't work on standalone DVD player for some reason. Is there a freeware program that can burn the DVD files?
PoshSpur is offline   Reply With Quote
Old 20th March 2007, 12:23   #2  |  Link
Pata
IMGBURN.
http://www.imgburn.com
Pata is offline   Reply With Quote
Old 20th March 2007, 12:26   #3  |  Link
PoshSpur
Cheers Pata.
I've just downloaded it now. I'll be able to try it at home after work.
So with ImgBurn v2.2.0.0, I can take the files shrunk by DVDShrink and burn them onto my DVD that can be read by my standalone DVD player?
Old 20th March 2007, 12:31   #4  |  Link
Pata
Yes you can, but maybe the media is currupt.
Test DVD- DVD+ and so on.
Old 21st March 2007, 12:04   #5  |  Link
PoshSpur
I am a bit lame at using ImgBurn. It keeps telling me to find a .iso file???
All i want to do is copy the DVD file Video_TS to a DVD in order to be able to watch it on a standalone player.
Can ImgBurn do this?
Old 21st March 2007, 14:44   #6  |  Link
dialysis1
dialysis1's Avatar
Perhaps this will help.
http://forum.imgburn.com/index.php?showtopic=1780
dialysis1 is offline   Reply With Quote
Old 22nd March 2007, 15:57   #7  |  Link
Abond
Use Build Mode. Set Imgburn to burn to disc (not to create an ISO image). Add VIDEO_TS folder. Burn.
Abond is offline   Reply With Quote
