Old 29th April 2012, 20:11   #19441  |  Link
clsid
Bug: unchecking "Keep history of recently opened files" does not clear the DVD/File position cache.
clsid is offline
Old 30th April 2012, 00:34   #19442  |  Link
dioxholster
Does anyone know what the purpose to regain volume is? These are enabled by default, is it recommended to have them as is when using reclock as renderer? MPC-HC seems to be louder than other players in its default settings im wondering if regain volume or something else is going overboard with the volume. Also do I need audio switcher enabled?
dioxholster is offline
Old 30th April 2012, 08:02   #19443  |  Link
DMD
DMD's Avatar
Good day.
For inquiries concerning your file .mpeg I found an incompatibility between the latest release of ffdshow and MPCHC. (all these software are 64-bit)
To be more precise, ffdshow is used only as post-processing (upscaling etc ...) by disabling all internal codecs, using the ones built into MPCHC.
By performing a regression test, it was found that up to the release svn1906 (05/21/2010) works regularly with the latest release of ffdshow (with internal codec disabled) with the files .mpeg, the next relase are crashing.
If I can confirm this and if you can find a solution.
Sincerely thank you
DMD is offline
Old 30th April 2012, 08:43   #19444  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Fixed at r4552 and r4553.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline
Old 30th April 2012, 11:11   #19445  |  Link
MSL_DK
I have a problem with this film. The subtitles appear delayed and in less time than they should. I've tried to convert to srt and then there are no problems.
I am using the latest version from xhmikosr.1f0.de
Could it be a combination of VC-1, TrueHD and PGS
There are no problems in eg VLC
General
Complete name : H:\THE_NOTEBOOK\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 22.6 GiB
Duration : 2h 3mn
Overall bit rate : 26.1 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : VC-1
Format profile : AP@L3
Codec ID : 234
Duration : 2h 3mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format profile : TrueHD / Core
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 131
Duration : 2h 3mn
Bit rate mode : Variable / Constant
Bit rate : Unknown / 640 Kbps
Maximum bit rate : 2 772 Kbps / 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Language : English
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : Danish
Sample (174 MB): removed
General
Unique ID : 234788848588746225411762498864259870018 (0xB0A2AFFA22E32B89ADC36DBBCC052D42)
Complete name : E:\New folder\Notebook.mkv
Format : Matroska
Format version : Version 2
File size : 175 MiB
Duration : 51s 469ms
Overall bit rate mode : Variable
Overall bit rate : 28.5 Mbps
Encoded date : UTC 2012-04-30 09:47:17
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : VC-1
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 51s 468ms
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Danish
Default : Yes
Forced : No
MSL_DK is offline
Old 30th April 2012, 17:39   #19446  |  Link
khagaroth
khagaroth's Avatar
Czech translation updated.
khagaroth is offline
Old 30th April 2012, 17:51   #19447  |  Link
Underground78
Underground78's Avatar
Thanks! Commited as r4558.
Underground78 is offline
Old 1st May 2012, 03:02   #19448  |  Link
wanezhiling
http://forum.doom9.org/showpost.php?...ostcount=18701
Should be same.
LAV Splitter is ok.
wanezhiling is offline
Old 1st May 2012, 07:56   #19449  |  Link
MSL_DK
Should be same.
LAV Splitter is ok.
Yep, same problem. There has not been so much response to the problem, so it's probably not a problem. Returns to LAV Splitter.
MSL_DK is offline
Old 1st May 2012, 11:02   #19450  |  Link
Underground78
Any opinion on this test build? It uses a masked edit for entering the timecode in the Go To dialog.
Do you like the masked edit knowing you won't be able anymore to enter something like "300.000" to jump to 300s?
Edit: link updated, the new build will display the timecode as "mm:ss.ms" when the duration is less than 1h and will show an error message when trying to jump after the end of the file.
Old 1st May 2012, 14:17   #19451  |  Link
Sylt
The current MPC-HC Authors.txt file says, that Aleksoid is an inactive developer, although Aleksoid's last SVN Commit was 4563.
Sylt is offline
Old 2nd May 2012, 13:26   #19452  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Is anyone willing to work on mini webui ?
We need something that'll work properly on all mobile platforms, so we can have proper 'remote control' for those of us who doesn't have real remote controller.
Also we need someone that'll work on website.
vBm is offline
Old 2nd May 2012, 17:28   #19453  |  Link
wanezhiling
http://p.gokuai.com/index.php?m=Inde...4W87X11cRGeO14
MPC-HC 1.6.2.4568 failed, LAV Splitter is ok.
http://p.gokuai.com/index.php?m=Inde...35TTG6KeZC3728
Would MPC-HC support Apple ProRes?
Old 3rd May 2012, 00:55   #19454  |  Link
Aleksoid1978
Aleksoid1978's Avatar
https://rapidshare.com/files/2215177...be.20120503.7z
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
Old 3rd May 2012, 01:06   #19455  |  Link
mr.duck
quack quack
Originally Posted by Aleksoid1978 View Post
Try making new thread for MPC-BE.
Media Player Classic Home Cinema Icon Library: NORMAL VERSION / GLOWING VERSION
mr.duck is offline
Old 3rd May 2012, 03:37   #19456  |  Link
boyumeow
boyumeow's Avatar
He is using mpc-be more like alpha test, whatever that works well will be ported to mpc-hc, so please stop asking him to make new thread. Thanks.
boyumeow is offline
Old 3rd May 2012, 03:44   #19457  |  Link
wanezhiling
Works.
Old 3rd May 2012, 10:50   #19458  |  Link
Aleksoid1978
wanezhiling, MSL_DK
try this https://rapidshare.com/files/3655567...GS_20120305.7z
Old 3rd May 2012, 11:44   #19459  |  Link
wanezhiling
Now it's good. Many thanks.
Old 3rd May 2012, 12:01   #19460  |  Link
fad
xxxxxxxxxxxxxx
fad is offline
dxva, h264, home cinema, media player classic, mpc-hc
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
