Old 28th December 2010, 22:18   #15561  |  Link
mindbomb
you find no problems with artifacts when you use arcsoft video decoder in mpc hc?
what tmt version are you using dbone?
edit:
registered the asvid.ax from tmt 5, it seems to be working actually. The last time I tried with tmt2 I think, and that resulted in tons of artifacts.
Now, this isn't scientific or anything, but I feel like libavcodec was actually producing smoother results, despite no dxva.
mindbomb is offline
Old 28th December 2010, 22:24   #15562  |  Link
o770
MS decoder makes many irregular encodes I tested play too fast although blockiness was indeed gone. Haven't you experienced that?
Found this about the compatibility check. Should I really skip reference frame check?
No problem caused by 10-bit RGB Output and Full floating point processing. Force 10-bit RGB input creates artifacts.
I can't verify the first two settings actually do anything. Do the stats show? This snapshot shows the configuration I intend to maintain - is it good?
o770 is offline
Old 28th December 2010, 23:20   #15563  |  Link
dbone1026
edit:
I used the TMT3 decoders (I own a license for TMT3 so it was easy to grab)
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline
Old 28th December 2010, 23:22   #15564  |  Link
dbone1026
No, I have had zero issues with MS Video Decoder for h264 and core i5 (tested on both my core i5 HTPC and core i5 laptop). This is for 1:1 BluRay mkvs which is a large majority of my content and using MPC HC for playback
Cheers,
Damian
Old 29th December 2010, 00:08   #15565  |  Link
xiulet
xhmikosr , a new update for catalan translation!
https://sourceforge.net
adéu.
---Intel i5 3570k --Asrock z77 ext. 4 --Skill 4x4GB dd3 --amd r9 270 --S.O Gentoo & Win 8.1 64bits --Dell u2414h"
xiulet is offline
Old 29th December 2010, 02:04   #15566  |  Link
Thunderbolt8
Originally Posted by LigH View Post
Possibly by changing the "Start in folder" property of the link to MPC-HC? At least I hope so...
doesnt work, unfortunately (although it did with the older version I had installed, but it doesnt work any more now with the latest)
Thunderbolt8 is offline
Old 29th December 2010, 02:34   #15567  |  Link
mindbomb
I've been playing around with the vc-1 decoder from tmt3 and tmt 5, and in both, im finding that i run into problems with audio video sync upon seeking occasionally, and I'm also getting dropped frames, especially in There Will Be Blood, where i was getting about one per second through any particular scene.
Idk have you experienced anything like this, or does this only affect nvidia cards?
I love the idea of hardware acceleration, but I think im going to have to go back to libavcodec.
edit: also, when i tried to play the movie Greenberg, i just get a black screen.
mindbomb is offline
Old 29th December 2010, 02:42   #15568  |  Link
dbone1026
I have only tested the arcsoft video decoder (TMT3) with my core i5 and have had none of those issues you describe. For my ATI GPU HTPCs I just use the internal MPC filters. I don't have a NVidia GPU so cannot confirm what you are seeing.
Cheers,
Damian
Old 29th December 2010, 04:01   #15569  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic HomeCinema (x86/x64), 1.4.2808
Changes (2801-2808):
  • Another update for 2798 rev;
  • rename Belarus.isl to Belarusian.isl, update changelog;
  • update ffmpeg;
  • Fix: playback seamless BD;
    Add: PGS subtitles name and language;
    Patch by Sebastiii;
  • update MediaInfoLib to r3620;
  • update Compilation.txt. Patch by thevbm;
  • updated translations, catalan by xiulet, ukrainian by arestarh;
  • Revert rev. 2684, because it's broken play subtitle in single MPEG file (*.m2ts).
Win10 x64, i7 7700K 5.2Ghz, ASUS MAXIMUS VIII HERO, HyperX Fury 16GB (2x8GB) 3000MHz, ASUS GTX1060-6G,TV Philips 40PFS6909/12, MED1000X3D
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 29th December 2010, 09:47   #15570  |  Link
LigH
LigH's Avatar
@ alexins, Thunderbolt8:
How about adding some kind of "Preferred directory", or even "Media library" (quick access to a few directory tree branches), to MPC-HC?
__
Oops ... there are already "Favourites". Sounds useful for you, Thunderbolt8, if they could be extended by "Folders" too, in addition to "Files" and "DVDs".
German Gleitz board
LigH is offline
Old 29th December 2010, 14:53   #15571  |  Link
SamuriHL
SamuriHL's Avatar
    Patch by Sebastiii;
Way to go Seb! I hope the seamless branching stuff is finall fixed for good. Awesome!!
HTPC1:W10 Creator Edition, I7 3770k, GTX 1060, Pioneer Elite SC-65, Panasonic 65" 1080p Plasma
Laptop: MSI GT70 Dominator
SamuriHL is offline
Old 29th December 2010, 15:08   #15572  |  Link
dleach
What does "Fix: playback seamless BD" mean?
  • update ffmpeg;
    Patch by Sebastiii;
dleach is offline
Old 29th December 2010, 17:15   #15573  |  Link
mark0077
For me it seems to fix this audio desync problem with multi m2ts blu-ray playlist files, eg Toy Story 3. Thanks a million guys!
http://sourceforge.net/apps/trac/mpc-hc/ticket/1010
tetsuo55 can this ticket be closed please? Perhaps devs could have a quick search through the bug tracker after they provide a fix, to see if any bug reports can be closed?
mark0077 is offline
Old 29th December 2010, 17:57   #15574  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Thanks, closed #1010
In last few days namaiki closed several forgot-to-close fixed tickets. There are couple of 'easy' to implement tickets but we need someone to step up and do it :P
vBm is offline
Old 30th December 2010, 02:30   #15575  |  Link
rica
Hi guys,
shall i hope MPC-HC will support 3D BD play in 2011?
Happy new year btw.
rica is offline
Old 30th December 2010, 16:08   #15576  |  Link
stasi
stasi's Avatar
What about an option to show the cover of a MKV file in the main window for a few seconds when starting playback? And an option to darken the picture when a movie is paused for ~5 minutes?
stasi is offline
Old 30th December 2010, 21:14   #15577  |  Link
leeperry
Kid for Today
patches are welcome
leeperry is offline
Old 30th December 2010, 21:19   #15578  |  Link
Steveo08
i have a question to this ticket:
http://sourceforge.net/apps/trac/mpc-hc/ticket/589
is a fix possible?
Steveo08 is offline
Old 31st December 2010, 11:03   #15579  |  Link
god_md5
i try this ver ,the dvb subtitles can't work
Media Player Classic HomeCinema (x86), 1.4.2808, MSVC2010 (SSE2)
sample
http://www.mediafire.com/?1m52gp7imo1ua7c
god_md5 is offline
Old 31st December 2010, 15:46   #15580  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Happy new 2011 YEAR to ALL
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
dxva, h264, home cinema, media player classic, mpc-hc
