Old 10th September 2010, 03:45   #14581  |  Link
neo_sapien
Thank you for creating this awesome player! I don't know what I'd do without it.
With the latest release, 2499, I was astonished to find that my Radeon 5850 now uses DXVA for profile 5.1 h.264 files. I've tried it on a 1080p video with 8 ref frames, and another 1080p video with 13 ref frames. It's a miracle!
On my Radeon 5450-equipped HTPC, however, DXVA still only works with normal DXVA-compatible videos. 1080p, profile 4.1, with 4-5 reference frames. It won't do 1080p profile 5.1 with 8 reference frames like the 5850 will.
Both PCs are using the same catalyst drivers, 10.8. Any idea why the Radeon 5850 is now able to use DXVA for profile 5.1 files with high reference frames, but not the Radeon 5450?
Edit~Nevermind, it turns out that the Radeon 5450 does do DXVA in profile 5.1 with even 16 ref frames, just not over Remote Desktop Connection. My mistake. You guys are miracle workers, I never thought these non-compliant videos would work with DXVA!
neo_sapien is offline
Old 10th September 2010, 04:06   #14582  |  Link
Alexander01
Is there any option in MPC-HC to reclock the frame rate of a video file (like the ReClock program does)? At the moment I use the 'Autochange full screen monitor mode' option to change my display to 24Hz output when opening a MKV/H264 video file with MPC-HC. This is because the MKV/H264 files have frame rates of 23.976. I want to reclock this frame rate to 24 to avoid stutters on my display. Is there an option within MPC-HC that can do this?
Alexander01 is offline
Old 10th September 2010, 07:35   #14583  |  Link
lych_necross
ZZZzzzz...
lych_necross's Avatar
Originally Posted by tetsuo55 View Post
... Also i need a noob proof instruction, i have never backed up only 1 string out of the registry by hand before.
What about adding an option under the help menu to dump settings to a text file? You could call it 'Generate Support Information'. It would dump the settings, along with general system info to a file in the user's desktop folder (or some other folder). That would make it pretty noob proof.
lych_necross is offline
Old 10th September 2010, 08:29   #14584  |  Link
Mercury_22
I have some problems with MPC-HC & my Tuner = "VideoMate TV SAA7134 Hybrid Capture Device" on analog
1. Every time I "Open Device" it defaults to SVideo instead off Tuner. Can't MPC-HC remember "last input mode" used or default to Tuner ?
2. Although I have a Pal Tuner I can only get 29.97 FPS
3. If I change any Video setting from the capture options (e.g. manually change to 25fps) MPC-HC it's crashing and the change "it sticks" only for the next time I "Open Device" the second time I "Open Device" it defaults again to the initial settings = YUY2 320x240@29.97
It's just me (my Tuner) or this happens to everyone (again on analog "side")
Edit: I don't have this problems with other software e.g. Windows Media Center
Windows 10 x64 CU, HD7790 Crimson 17.6.2, HDMI Full RGB 4:4:4
Mercury_22 is offline
Old 10th September 2010, 08:53   #14585  |  Link
bur
Originally Posted by Snowknight26 View Post
You probably have something improper selected in the Video Frame options.
Thanks!
It was set to Zoom2 for unknown reasons...
bur is offline
Old 10th September 2010, 11:41   #14586  |  Link
shahed26
MPC HC has now replaced my slow buggy wintv 7 software. I use DVB viewer for DVB-S, but i look forward to more future updates in that DVB T/(Hopefully DVB-S aswell in future) category. The best media player ever !
Thank you to all MPC HC Team. Will report if any bugs found
shahed26 is offline
Old 10th September 2010, 11:48   #14587  |  Link
Underground78
Underground78's Avatar
What kind of updates do you hope for DVB-T ? If there are things not too difficult, I may have a look to it and I am quite sure XPC would be interested in having users feedbacks too .
About DVB-S, have a look to this post.
Underground78 is offline
Old 10th September 2010, 12:09   #14588  |  Link
DMD
DMD's Avatar
Good morning.
Wonder if in future releases you can update the skin of this magnificent player, the current time seems designed for W98.
THANKS
DMD is offline
Old 10th September 2010, 13:36   #14589  |  Link
Superb
Originally Posted by DMD View Post
Good morning.
THANKS
+1.
Could be a wonderful upgrade for the next official version. (keeps the clean look, but looks much better)
http://forum.doom9.org/showthread.ph...60#post1431460
Superb is offline
Old 10th September 2010, 13:49   #14590  |  Link
nevcairiel
Thats a skin for it that i actually like.
nevcairiel is offline
Old 10th September 2010, 15:04   #14591  |  Link
NikosD
@ tetsuo55 and all the others
I've just updated the thread of DXVA benchmarks here:
http://forum.doom9.org/showpost.php?...80&postcount=1
Waiting for your comments.
NikosD is offline
Old 10th September 2010, 16:01   #14592  |  Link
Mercury_22
+1
(@tetsuo)
Since from MPC-HC GUI Discussion Thread result that (almost?) everybody prefer this one to the old one what are we waiting for ?
Old 10th September 2010, 16:10   #14593  |  Link
Alexander01
Anyone?
How does everyone here watch content with 23.976 fps smoothly on their TV's?
Old 10th September 2010, 16:15   #14594  |  Link
Mercury_22
Anyone?
Enable 23.976 for your tv (for ATI go to HDTV Support and add 1080p24 format)
Old 10th September 2010, 16:23   #14595  |  Link
Alexander01
Yes, but this is the same as configuring 24hz in Windows. If I do this my TV says 1080p/24, so i assume it's the same. Still not good enough to play MKV files with 23.976 fps completely stutter-free. If I use reclock to turn up the frame rate to 24 fps the movie plays smoothly and completely stutter-free! But I would like to see such option within MPC-HC. Mainly because MPC-HC also has the option to change the refresh rate when playing in full screen. It would be very nice if this could be combined with an option to reclock the frame-rate!
Old 10th September 2010, 16:30   #14596  |  Link
XPC
Originally Posted by alex_3d42 View Post
Thank you ! It works with "Microsoft Network Provider" instead of "Microsoft DVBT Network Provider".
But I can't find any channels
All intenal filters activated, Windows 7 Pro 64 bits
Edit : Checked with 1.4.2511, no channels found.
Check the scan parameters, they could be different depending on your area. And make sure the antena and the tunner are working properly.
We need to know as well list of filters you get (right click filters).
XPC is offline
Old 10th September 2010, 16:42   #14597  |  Link
Mercury_22
At least for ATI when you enable 24p in HDTV you'll have 23.976 (in windows monitor's settings you'll see a 23 Hertz option) in MPC-HC use Ctrl+j and you'll see you have 23.976
Old 10th September 2010, 17:04   #14598  |  Link
HCuser
Hello and greetings. I have troubles with DVD playback decoding since few updates. One of the last who works properly is 1.3.2283. Please see the screenshot taken with 1.4.2523.
Can you tell me what are the real differences between MSVC2010(SSE2) and MSVC2008?
Thanks a lot. Bye.
HCuser is offline
Old 10th September 2010, 18:01   #14599  |  Link
Superb
Difference: different compiler. Different binary code produced. The 2010 requires a newer CPU (that supports SSE2).
Regarding the DVD decoding issue... right click and go into Filters while playing. Give us a screenshot.
Superb is offline
Old 10th September 2010, 18:24   #14600  |  Link
HCuser
Thank you. Here is another screenshot (I hope this is what you asked). I dont use any codec packs, only internal MPC HC.
HCuser is offline
dxva, h264, home cinema, media player classic, mpc-hc
