Old 25th July 2009, 17:46   #8721  |  Link
ar-jar
Originally Posted by tetsuo55 View Post
Anyone with compiling capabilities,
Does MPC-HC still function(or even fully compile) if you compile with these settings:
x86: "/SAFESEH /O2 /GS /arch:SSE2 /EHa"
x64 AMD: "/favor:AMD64 /O2 /GS /EHa"
x64 INTEL: "/favor:INTEL64 /O2 /GS /EHa"
x64 universal(SLOW): "/favor:blend /O2 /GS /EHa"
This is what I get when plugging in the options from the first line (x86):
3>Linking...
3>dsutilRU.lib(a_yuv2rgb.obj) : error LNK2026: module unsafe for SAFESEH image.
3>dsutilRU.lib(convert_a.obj) : error LNK2026: module unsafe for SAFESEH image.
3>d2vsourceRU.lib(idctmmx.obj) : error LNK2026: module unsafe for SAFESEH image.
3>Mpeg2DecFilterRU.lib(motion_comp_mmx.obj) : error LNK2026: module unsafe for SAFESEH image.
3>Mpeg2DecFilterRU.lib(idct_mmx.obj) : error LNK2026: module unsafe for SAFESEH image.
3>MpaDecFilterRU.lib(lpc_asm.obj) : error LNK2026: module unsafe for SAFESEH image.
3>MpaDecFilterRU.lib(bitreader_asm.obj) : error LNK2026: module unsafe for SAFESEH image.
3>MpaDecFilterRU.lib(cpu_asm.obj) : error LNK2026: module unsafe for SAFESEH image.
3>MPCVideoDecRU.lib(CompilatorVersion.o) : error LNK2026: module unsafe for SAFESEH image.
3>MPCVideoDecRU.lib(mpc_helper.o) : error LNK2026: module unsafe for SAFESEH image.
3>MPCVideoDecRU.lib(parser.o) : error LNK2026: module unsafe for SAFESEH image.
... and so on with a whole bunch of other .o files in MPCVideoDecRU.lib.
Without the /SAFESEH option to the linker, everything seems to work ok.
-A
ar-jar is offline
Old 25th July 2009, 18:13   #8722  |  Link
gngn
the hedgehog
gngn's Avatar
Originally Posted by Casimir666 View Post
New test build with all this changes available from here : http://www.zshare.net/download/6313488079dc9738/
the problems with XP+nvidia+DXVA introduced in r1141 ( post #8320) are now fixed.
only that the max ReFrames for XP seems to be now 14. videos with ReFrames=15 or above wont play.
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 25th July 2009, 18:16   #8723  |  Link
The1n
@The1n
Could you try again with new test build (if not ok would you post your screenshot on imageshark or something your previous attachement is still waiting validation)?
Hi Casimir666 , when trying out your latest test build it looked a little better but still error frames with original bluray films, here is a zshare link for you.
http://www.zshare.net/download/63146496f464ec2b/
The1n
The1n is offline
Old 25th July 2009, 18:36   #8724  |  Link
Casimir666
@ Mercury
I fixed the True HD and LPCM mapping. The Eac3 is still 5.1 instead of 7.1 because ffmpeg return only 6 channels! Back and side surround channel are out on back.
Cannot fix the DTS, because it's decoded by libdts that didn't support 7.1.
I didn't understand for the AC3 sample : are you sure it's wrong? Can you try with original mpc because the original mapping is used in this case and i would be surprise if it's wrong. Your file is 5.1 and not 7.1?
@ All
I fixed other small issues on DXVA, and if no major bugs are detected this build will became next stable release :
http://www.zshare.net/download/6314672884c0d9d9/
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 25th July 2009, 18:41   #8725  |  Link
tetsuo55
MPC-HC Project Manager
3>Linking...
-A
Those command tell the compiler to : Prefer speed over size, and security over both.
Those erroring files need to be recompiled with this setting enabled using VS2008SP1
tetsuo55 is offline
Old 25th July 2009, 19:09   #8726  |  Link
hoborg
@ All
Casimit, just tryed and bad news - no changes at all Still get wrong frames order on all h.264 MKV i have :/
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline
Old 25th July 2009, 20:11   #8727  |  Link
Mercury_22
@ Mercury
@ All
Yes I'm sure about AC3 ! Also MPC 6.4.9.0 (original mpc) has the same WRONG mapping ! If it helps FFDShow has the correct mapping for Ac3 (Dolby Digital)
Yes the TEST file is 5.1 ! AFAIK AC3 (Dolby Digital) has MAX 6 channels http://en.wikipedia.org/wiki/Ac3 or http://www.dolby.com/consumer/techno...y_digital.html
Ac3 (Dolby Digital) wrong mapped channels:
1 - REAR RIGHT wrong mapped to FRONT RIGHT
2 - REAR LEFT wrong mapped to FRONT LEFT
= No rear channels!
Test 5.1 AC3 (Dolby Digital)
I can confirm TrueHD and LPCM (and E-AC3 since "ffmpeg return only 6 channels" ) now are working correct !
About DTS, please can't you at least make it like E-AC3 : "Back and side surround channels are out on back." ?
DTS (-HD HR MA) wrong mapped channels:
1 - SIDE RIGHT wrong mapped to FRONT RIGHT
2 - REAR RIGHT wrong mapped to FRONT RIGHT
3 - SIDE LEFT wrong mapped to FRONT LEFT
4 - REAR LEFT wrong mapped to FRONT LEFT
Test 7.1 DTS-HD HR
P.S. PLEASE can you compile a x64 version too ?
Windows 10 x64 CU, HD7790 Crimson 17.6.2, HDMI Full RGB 4:4:4
Mercury_22 is offline
Old 25th July 2009, 20:40   #8728  |  Link
73ChargerFan
73ChargerFan's Avatar
Sorry for OT, but my HTPC is getting old, and I'm tired of tearing with my BD rips. This is the only application I run on it, except for Opera.
Current: AMD 4600X2, 2gb DDR memory, ATI 4850, Windows XP MCE 2005.
I purchased a Athlon 2 X2 250 to upgrade, with 4gb DDR2, re-use my ATI 4850, Windows 7 (x86 or 64). $185.
Will this be blazing fast, enough that I can ignore DXVA? Or should I return it and upgrade to the AMD max, a Phenom 945? This would be $300. Money is a consideration...
73ChargerFan is offline
Old 25th July 2009, 22:28   #8729  |  Link
_xxl
ffdshow user
_xxl's Avatar
What part of mpc-hc could benefit from those compiler optimizations?
_xxl is offline
Old 25th July 2009, 22:31   #8730  |  Link
tetsuo55
Overall optimization could mean the difference between jittering and stable playback on slower systems.
some parts are very system intensive like the internal subtitle renderer, this can use any optimization it can get.
Mostly it's for security though, to prevent any exploits from things like malformed avi/wmv/mkv files or http links.
tetsuo55 is offline
Old 25th July 2009, 22:34   #8731  |  Link
_xxl
ffdshow user
_xxl's Avatar
I get some crashes with internal avi spitter and xvid avi files. If avi spitter is disabled no crash. This is happening also with Haali's avi splitter, but not with MS one.
_xxl is offline
Old 25th July 2009, 22:36   #8732  |  Link
_xxl
ffdshow user
_xxl's Avatar
Maybe I should add a vc project file that uses all optimizations?
_xxl is offline
Old 25th July 2009, 22:40   #8733  |  Link
tetsuo55
Yes the project file should be updated, but only after we confirm no new problems arise, and any new warnings have to be fixed too.
these warnings point to possible exploitable security problems.
Also if you use the ARCH:SSE2 by default anyone with a CPU that does not have SSE2 will not be able to use MPC-HC
tetsuo55 is offline
Old 25th July 2009, 23:24   #8734  |  Link
Casimir666
Be careful playing with optimisation, it's really hard to know if it improve things or not and could have side effect. I prefer not to commit theses tests in SVN
Tired of tearing?
Old 26th July 2009, 00:20   #8735  |  Link
_xxl
ffdshow user
_xxl's Avatar
Be careful playing with optimization, it's really hard to know if it improve things or not and could have side effect. I prefer not to commit theses tests in SVN
True, stability is more important than speed.
_xxl is offline
Old 26th July 2009, 03:11   #8736  |  Link
thuan
@73ChargerFan:
If you don't want to rely on DXVA then that CPU will not be enough in some cases, as mine, a Xeon E3110 (equal the Core 2 Duo E8400), isn't enough in some cases either, with libavcodec from ffdshow or MPC-HC internal. I mostly use DXVA now with my nvidia card (9500GT), and it works nearly perfect with MPC-HC. DXVA from ATI card I owned previously (HD2400XT) was really erratic, not to mention the chroma upsampling problem. I wonder if the latter problem is fixed now?
thuan is offline
Old 26th July 2009, 05:54   #8737  |  Link
Snowknight26
r1179 doesn't downmix AC3 or DTS anymore. Even though I have both filters set to decode to stereo, the audio renderer shows 6 channels.
And on a separate note, I've noticed that several Blu-rays of mine show subtitles only in the MPEG PS splitter but not in the Subtitles menu, so subsequently they can't be enabled.
Samples on request.
Snowknight26 is offline
Old 26th July 2009, 07:07   #8738  |  Link
73ChargerFan
Thanks thuan, hc & tetsuo55 - I decided to exchange the Athlon II X2 250 for a Phenom II X3 720 BE.
Old 26th July 2009, 08:04   #8739  |  Link
tetsuo55
Yes we have to be absolutely sure first.
Please not that:
/arch:[SSE|SSE2] Without this command SSE and other features of chips supporting this are completely unused (unless hand coded into the source). Also for the X64 builds the SSE2 option is enabled by default. (so we can be relatively sure that this works)
/favor (Optimize for x64) This option should provide an increase in speed by dropping backwards compatibility with x86 (this should have been enabled by default )
/GS This is purely a security feature, buffer protection, it can be and should be enabled by default.
/EHa this is a security feature too, exeption handling, this actually changes code and could lead to breaks.
/O2, enabled by default on release builds, slightly different meanings between x86 and x64, could break things.
/SAFESEH security feature that is enabled by default on x64
As you can see, almost all of it should be safe, and a lot of it has been tested on the x64 builds (or has been causing some of the x64 build bugs!)
tetsuo55 is offline
Old 26th July 2009, 09:28   #8740  |  Link
Spec-Chum
Revision: 1188
Fixed : support for custom mmco, improved ATI multislice (this rev is broken on ATI+XP)
Links:
x64
x86
Spec-Chum is offline
dxva, h264, home cinema, media player classic, mpc-hc
