Thread Tools Display Modes
Old 19th April 2009, 12:28   #7261  |  Link
nijiko
Green Hand
Why the madVR of my MPC here is gray?
How to enable it?
nijiko is offline   Reply With Quote
Old 19th April 2009, 12:31   #7262  |  Link
Steveo08
how can i be sure, that mpc-hc is using madVR?
when i look for filters, during a movie is running, i only see video renderer, is that madVR?
Steveo08 is offline   Reply With Quote
Old 19th April 2009, 12:41   #7263  |  Link
nijiko
Green Hand
And... When seek on PSS file which with PS2 ADPCM Audio, the audio track will lose.
I wonder when it will be solved?
Old 19th April 2009, 13:06   #7264  |  Link
tetsuo55
MPC-HC Project Manager
I guess you still need to install madVR yourself.
Get it here:
http://forum.doom9.org/showthread.ph...ighlight=madvr
tetsuo55 is offline   Reply With Quote
Old 19th April 2009, 13:17   #7265  |  Link
nijiko
Green Hand
Get it here:
Thank you very much!!!
I just consider the madVR is included in new MPC.
Aha. Sorry!
I now using it.
But... I found the madVR doesn't support for subtitles???
And MPC now is screening out the VSFilter.
Faint...
Old 19th April 2009, 13:38   #7266  |  Link
Phaser
I'm not too happy with the Beliyaal branch merge... At least until the bugs are ironed out...
I tried Beliyaal builds before but I always had some problems like stuttering, tearing, strange lines appearing with bicubic resizer (with EVR custom renderer).
Phaser is offline   Reply With Quote
Old 19th April 2009, 13:38   #7267  |  Link
tetsuo55
Aha. Sorry!
I now using it.
Faint...
madVR is far from finished, subtitles are not supported, but read the thread there are some tricks to get subtitles
Old 19th April 2009, 13:48   #7268  |  Link
tetsuo55
Hello everyone,
I would like to ask for you help in confirming that the bugs in the list are all fixed.
These are all DXVA bugs, so i need DXVA users with different hardware to confirm.
Please use the following settings when confirming:
Internal splitters + internal decoders
Haali splitters + internal decoders.
(and any variation in the bug reports)
here is the link (13 bugs)
https://sourceforge.net/tracker/?lim...annedresponse=
Please use 1048 or newer when testing (some of these bugs probably require 1053)
Old 19th April 2009, 14:02   #7269  |  Link
GTPVHD
Should there be a new stable release build from before 1048 merge? The last 908 official stable release is very old and some of the fixes and improvements since then can be helpful for those users who don't keep up with the SVN builds.
Also the copyright in the Help, About should be updated to say 2002-2009.
GTPVHD is offline   Reply With Quote
Old 19th April 2009, 14:05   #7270  |  Link
tetsuo55
Originally Posted by GTPVHD View Post
Should there be a stable release build from before 1048 merge? The last 908 official stable release is very old and some of the fixes and improvements since then can be helpful for those users who don't keep up with the SVN builds.
We're moving towards a stable build, beliyaal's changes fixes too many bugs to not include them in the next stable,
The copyright should be updated, thanks
Old 19th April 2009, 14:08   #7271  |  Link
tetsuo55
Hello everyone,
We have 2 batches left, most or all of these bugs should be fixed in 1053.
Subtitle problems(13):
Renderer problems(12):
Please check and confirm as many as possible.
Thank you!
Old 19th April 2009, 14:19   #7272  |  Link
DigitalDeviant
DigitalDeviant's Avatar
OK, I think I have some sort of bug related to CoreAVC and disabling disable desktop compostiton.
First off, disable desktop composition is giving me bad tearing at the beginning of playback and after seeking. Once it's disabled, I get a glitch in AVC mkvs where the file plays back OK for a random period of time (random between files, usually the same spot in each file) then the file speeds up to about as fast as it will go with 100% CPU useage, the audio stops and the playback controls stop functioning. Sometimes it doesn't happen at all but it usually does depending on what splitter is used.
It seems related to CoreAVC. Switching to the internal decoder seems to fix it but I'm still testing. It happens much more frequently with haali's splitter over the internal one but the internal one does exhibit the problem sometimes. I'm still testing this too.
I'm using the latest build (obviously). I'm using EVR-CP on Vista home basic with a Geforce 9600GT.
"Do everything by hand, even when using the computer." - Hayao Miyazaki
DigitalDeviant is online now   Reply With Quote
Old 19th April 2009, 14:43   #7273  |  Link
nijiko
Green Hand
I now change the codes to rebuild an MPC svn for not screening out VSFilter.dll.
But there is another problem.
The subtitles can't be loaded when clips start playing.
The subtitles must be closed and opend once, it just can be displayed.
Old 19th April 2009, 14:45   #7274  |  Link
Casimir666
Hello everyone,
Thank you!
1948031 Subtitles synchronisation lost with VMR9/EVR
This one should be fixed with Beliyaal changes i think
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline   Reply With Quote
Old 19th April 2009, 15:14   #7275  |  Link
nijiko
Green Hand
I wonder to ask how to config the settings for madVR?
The default settings, I found it lose many more frames than VMR9.
Old 19th April 2009, 15:16   #7276  |  Link
madshi
Please ask such questions in the madVR thread. Thanks.
Old 19th April 2009, 15:20   #7277  |  Link
clsid
Bug: the stats seems to be scaled against the screen resolution instead of the output video resolution. So in windowed mode, not all stats are visible.
[ ffdshow SVN builds | ffdshow SVN changelog ]
Old 19th April 2009, 15:28   #7278  |  Link
mark0077
BUG: Was playing some dvd's from a scratched disk lastnight. I know certain sections of the movie jump / skip because of the bad data but when this happens audio and video go out of sync by about 1 second, sometimes returning on future skips.. Maybe this could be looked into?
mark0077 is offline   Reply With Quote
Old 19th April 2009, 15:29   #7279  |  Link
Gleb Egorych
Small feature request: please add OSD for "Next AR preset" function.
Gleb Egorych is offline   Reply With Quote
Old 19th April 2009, 16:26   #7280  |  Link
alexins
alexins's Avatar
Media Player Classic HomeCinema (x86/x64), svn 1056
Supported languages: BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA
Changes log
Updated Czech translation;
Updated ffmeg;
Fixed : crash on seek with True HD tracks;
Fixed : MpcVidecDec output MediaType incorrectly filled to 1088 instead of 1080 for software decoding of 1080 material;
Fixed : Gpu Control checkbox appears on "Recent files" menu items;
Updated Copyright;
Fixed : duplicate include.
Win7 Ultimate x64, AMD Phenom II 955BE, ATI Radeon HD 4850, Catalyst 10.1 (8.70rc2)
MPC-HC rev. 1623
ffdshow rev. 3255
XviD-1.3.0 (CVS)-091025.03.29 VAQ x86/x64 (MTK, DivX profiles)
alexins is offline   Reply With Quote
dxva, home cinema, media player classic, mpc-hc
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
