Old 21st March 2007, 11:07   #41  |  Link
Schrade
Schrade's Avatar
Originally Posted by Leak View Post
Could you explain that one further? I really doubt reading the registry is noticeably faster than reading a miniscule file from disc...
I've noticed the slowness when using the .ini as well. I'm not sure what is causing the slowness but it's pretty annoying. The slowness I experience is in running MPC or it trying to save its settings. Just gets really slow.
Using the registry instead of the .ini I have never experienced the problem.
Schrade is offline
Old 21st March 2007, 12:25   #42  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
I thought wtf too, so I tried it and watched with process monitor. Opening MPC performs synchronous I/O hundreds of times because of a naive system. Reg keys are made to be opened, locked, read, unlocked, and closed thousands of times a second with no problem, but doing that with real files gets you in trouble. Every operation, like opening a file, causes dozens more reads plus a single write. If it was asynch I/O it probably wouldn't be a problem, but MFC is so amazingly inept that it doesn't. CMPlayerCApp::Settings::UpdateData would all have to be rewritten to use a custom ini/registry handler to fix that, unless there's a way to override MFC functions.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
foxyshadis is offline
Old 21st March 2007, 18:25   #43  |  Link
Delerue
I noticed that using the .ini can cause some incompatibilities sometimes. Once, I could open a divX file with almost all players, but MPC couldn't. After trying a lot of things I discovered that the .ini was the problem. So I deleted it and everything goes fine.
Delerue is offline
Old 22nd March 2007, 20:08   #44  |  Link
chros
chros's Avatar
small improvement in the internal subtitle engine
Can somebody make a patch that MPC's internal subtitle engine can remember the last chosen "language" (like VSFilter or DirectVobSub) ?
eg.:
temp.avi
temp.eng.srt
temp.hun.srt
temp.esp.srt
Now, it always select the first in alphabetical order (eng), and drives me totally crazy
(Why don't I use VSFilter? Because I'm using RGB output of ffdshow that flips the picture, but not always: just if a subtitle is present)
chros is offline
Old 23rd March 2007, 12:46   #45  |  Link
madshi
One little request: The built in AC3/DTS file source filter tries to handle E-AC3 but fails. It would be great if that could be fixed. I can see 2 possible fixes:
(1) Just tell the filter to not handle E-AC3. Or:
(2) Add E-AC3 support to the filter.
FWIW, orbitlee has made a mod which enables E-AC3 support. Here's the download with source code:
http://www.sendspace.com/file/lwvvmi
He didn't get AC3/DTS to work properly after the mod, though, so he disabled AC3/DTS in his modded filter now.
madshi is offline
Old 23rd March 2007, 17:52   #46  |  Link
hdboy
Originally Posted by thuan View Post
I don't like the ini options because it's slower. With registry options you can back up your settings too. Just go to HKCU\Software\Gabest and back up the whole thing. As B.F. said MPC is useless without external codec not like mplayer or kmplayer and most of the included is useless for me anyway beside those used for DVD decoding. I don't care about the binary size but I just see those filters as "eyesore".
and it's harder to back up an ini file?
I'm grateful someone is still updating MPC. Let them use their time putting in things people want and supporting the new codecs rather than making special builds for various groups.
You're of course welcome to make your own minimal build of MPC if you're technically inclined.
hdboy is offline
Old 24th March 2007, 00:06   #47  |  Link
trueimage
I usually just use a mplayerc.exe file. Can someone tell me what these .patch and .ax files are and where do i put them or how do i use them? I just have them all in the same folder as mplayerc.exe right now.
trueimage is offline
Old 24th March 2007, 00:10   #48  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
.ax files are DirectShow filters. You can register them with the command "regsvr32 file.ax" and unregister with "regsvr32 /u file.ax". After a filter has been registered, DirectShow players can use them. AFAIK you won't need to use those .ax files at all, in case you using MPC. That's because those are just 'external' versions of MPC's built-in filters. The external filters are there, so other DirectShow players, such as WMPlayer, can use MPC's filters too. MPC itself won't need any of those .ax files.
.patch files are used to "patch" source code files. This way you don't need to download the complete source codes. You just apply the .patch files to the 'official' source codes and you get the fixed version. If you don't compile MPC yourself, then those files won't be of any interest for you. The .patch files are *not* intended to patch the compiled (.exe) file!
Just download mplayerc.exe and you have all you need:
http://mulder.dummwiedeutsch.de/home...&mirror=brhack
LoRd_MuldeR is offline
Old 24th March 2007, 08:46   #49  |  Link
LigH
LigH's Avatar
My english is not the best, I might have missed it in this thread, or in another somewhere...
Why did you decide to create a modified version?
a) Gabest is not (very) active anymore? (like Milan)
b) You wanted to include libavcodec?
Please point me to the thread where you explained your reasons, people in the german doom9/Gleitz board are wondering too.
__
A possible reason why INI files are "slower": Parsing for possible chapters.
The Registry is already hierarchical.
LigH is offline
Old 24th March 2007, 11:20   #50  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I guess he mostly did it because there's a handful of patches to MPC floating around on the web and the last MPC release was ages ago...
Where did you get the idea he was going to include libavcodec, though? ffdshow does that very well already, but I can't see ffdshow getting integrated into MPC...
now playing: [artist] - [track] ([album])
Leak is offline
Old 24th March 2007, 14:02   #51  |  Link
MatMaul
Originally Posted by drevil_xxl View Post
Originally Posted by MatMaul View Post
hello !
I have a problem with this MPC build.
when I want to play an ac3 file, it doesn't play : ligos MPEG splitter is charged as filter (??) and ffdshow (which is my ac3 decoder) isn't charged.
With last celtic_druid build, no problem, ffdshow is charged and the file is playing fine.
I''ll compile soon a new build.
Any news ?
MatMaul is offline
Old 24th March 2007, 14:41   #52  |  Link
clsid
Gabest is to busy with his regular work at the moment to work on MPC.
This build of MPC is not really a modified version. It is a plain SVN build (rev.611) with a handful of small patches thrown in. A few patches to update some of the external libs and a few small bugfixes.
Don't expect any developments. However, anyone is free to submit patches to fix/improve things in MPC.
clsid is offline
Old 25th March 2007, 11:14   #53  |  Link
_xxl
ffdshow user
_xxl's Avatar
New unicode mpc build:
updated dtsac3source
_xxl is offline
Old 25th March 2007, 12:11   #54  |  Link
wyrd
wyrd's Avatar
Thank you for your works
mirrored here
wyrd is offline
Old 25th March 2007, 12:20   #55  |  Link
MatMaul
thanks, it works fine !
MatMaul is offline
Old 26th March 2007, 12:46   #56  |  Link
3ngel
@ drevil_xxl:
Can you do a little modification and do a new build?
The modification resides simply in adding to the dialogs of this window (on the "Browse" buttons)
Adding the ".avs" to the filters of "Open" dialog,
and ".ac3" to the "Dub" open dialog.
It's really a 2 min modification but it would be REALLY useful.
Thank you very much.
3ngel is offline
Old 30th March 2007, 23:32   #57  |  Link
anonova
What exactly does YUV mixing in the VMR setting do? It doesn't have a tooltip over it explaining what it is.
anonova is offline
Old 31st March 2007, 05:47   #58  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
There's some speedup by doing certain operations in YUV prior to conversion to RGB instead of afterward, since there's less data involved. There are a lot of restrictions on this mode, but for the most part they don't impact MPC, which only uses one output stream anyway. The main restriction you'd care about is that it doesn't work with ffdshow's queuing.
For more information: http://msdn2.microsoft.com/en-us/library/ms788177.aspx
Old 5th April 2007, 15:13   #59  |  Link
freeman3
full screen problem
other applications can cause mpc to quit from full screen. can someone fix this?
freeman3 is offline
Old 11th April 2007, 22:01   #60  |  Link
Carpo
Carpo's Avatar
im giving this prgram a go as i am finding that all windows wmp are slow and mem hugry as is powerdvd 7.3 - thing is can you open a dvd from the hard drive like you could with powerdvd ? folder -> audio_ts video_ts ? also how do you get nvidia puervide dvd decoder to work woth mpc ?
sorry if this has been covered before
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline
dxva, h264, home cinema, media player classic, mpc-hc
