Old 4th November 2008, 13:00   #4621  |  Link
romanesque
On some mkv's at the bottom of the video the image is distorted:
http://i33.tinypic.com/2ecglg9.jpg
http://i36.tinypic.com/2diismo.jpg
I get this distorsion only when I play the video with mpchc. Is there any way to correct this?
Thank you.
romanesque is offline
Old 4th November 2008, 13:02   #4622  |  Link
Kado
Otaku
Kado's Avatar
Originally Posted by JohnLai View Post
O.o seem like the changelog at sourceforge mentions something about nvidia card supporting L5.1 by matmaul. Is it really work?
Although we would still be limited by the reference frames right?
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline
Old 4th November 2008, 14:03   #4623  |  Link
clsid
Yes, still 11 refs from what I can see in the code.
clsid is offline
Old 4th November 2008, 14:27   #4624  |  Link
Casimir666
Originally Posted by mariner View Post
Any plans for interlaced VC1 DXVA support?
It's on todo list.
@Casimir
There were some improvements to ffdshow recently with regard to H.264 and compatibility with various splitters. It would be worthwhile to implement those in MPCVideoDec.
I know we have a chat with Haruhiko and CinCh on this subject. My patch is not finished yet.
Originally Posted by MatMaul View Post
there is a patch in the ffmpeg-devel ml written by haruhiko which allows libavcodec to parse SEI and retrieve interlaced and field order from SEI. the patch have been reviewed and will hit the trunk very soon.
I think it can be useful to correctly detect interlaced frame and correct field order, especially in MBAFF streams.
I have an 1080i sample rip on a french TNT-HD which is not de-interlace by mpc decoder. The reason for this is that the "field_pic_flag" is not set in the H264 bitstream. Matmaul do you think that :
- frame_mbs_only_flag can be used to detect interlaced video (1=progressive, 0=interlaced)
- what should i do when field_pic_flag is not set? Suppose it's a top field first?
Originally Posted by QuePaso View Post
any update for G45 support? I tried the newest build but no HA yet.
Intel management didn't want to release their specifications because they fears lawsuit about content management (seen answer #15) :
http://software.intel.com/en-us/foru...gy/topic/60703
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 4th November 2008, 15:51   #4625  |  Link
MatMaul
according to specs 0 means progressive or interlaced so it is not very reliable
I think most of MBAFF live streams rely on the SEI layer to signal interlaced content (I haven't check it yet) so the easiest way is I think :
- apply this patch to ffmpeg (or wait a day or two that the patch hit the trunk)
- pass SEI packets to the ffmpeg h264 decoder
- read the libavcodec flags interlaced_frame and top_field_first (and I think it should be done for all the codecs decoded by ffmpeg, not only h264)
MatMaul is offline
Old 4th November 2008, 15:55   #4626  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Thank you.
I also have something like that:
Maybe its because source resolution is even non MOD8? It is 864x434
Keiyakusha is offline
Old 4th November 2008, 16:08   #4627  |  Link
JohnLai
I just tested svn 857 from alexin. It appears that L5.1 is not really well decoded, green line and messy image.
8500GT driver=177.92
Latest DirectX runtime installed
Setting used to encode: cabac=0 / ref=5 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5000 / ratetol=2.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Progressive
frame rate=29.970fps
1920x1080
Main@L5.1
Last edited by JohnLai; 4th November 2008 at 16:15. Reason: add some image and info
JohnLai is offline
Old 4th November 2008, 16:23   #4628  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Also, player is not fit video well, when chacked "AutoZoom: Auto Fit"
UPD: only when DXVA is used.
UPD2: tested on level 3.1 stream
Old 4th November 2008, 16:23   #4629  |  Link
MatMaul
as I said...
just removed the level 4.1 check for nvidia cards as they now support level 5.1 streams.
if you encounter a problem, please update your driver before report it
this is only supported since drivers 178.24
if it doesn't work with those new drivers, please report again.
MatMaul is offline
Old 4th November 2008, 16:42   #4630  |  Link
Jeff Flowerday
So is there any combination of external splitter and decoder that works with m2ts containers containing lpcm audio? I'm pulling my hair out here trying every combination known to man.
I don't want to install Nero showtime if I don't have to...
Jeff Flowerday is offline
Old 4th November 2008, 16:46   #4631  |  Link
JohnLai
OK, after updating the driver,it's works. So, ATI card can't decode L5.1, isn't it? Man, I wish the ref frame problem is fixed by the nvidia.
JohnLai is offline
Old 4th November 2008, 16:47   #4632  |  Link
ash925
I am using MPC-HC for HW acceleration.The problem I have is that some files like GOD OF WAR 3 Teaser in 1080p run smoothly on my HD4850.But files encoded by me in megui DXVA EXTRA Quality profile run with frames dropped but when I play through graphstudio using the same MPC video decoder the files run just fine.
Any help is appreciated.
ash925 is offline
Old 4th November 2008, 16:58   #4633  |  Link
ikarad
It's on todo list.
Casimir one question: are you french?
ikarad is offline
Old 4th November 2008, 17:13   #4634  |  Link
clsid
as I said...
Just an idea...
Is it possible to determine the driver version in MPC? If so, it might be a good idea to use that info to our advantage. For example:
* Limit to level 4.1 if vendor == NVIDIA && driver_version < 178.24
* Disable DXVA if driver_version equals some_known_buggy_version
This would be particularly useful for the average user (typically non Doom9 members). Those will not update their drivers at a regular basis, or at all for that matter. MPC is the first thing they will blame if things don't work. So making it n00b-proof is alwyas useful.
clsid is offline
Old 4th November 2008, 18:13   #4635  |  Link
rack04
Does it not work with MPC-HC internal M2TS splitter?
rack04 is offline
Old 4th November 2008, 18:54   #4636  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic HomeCinema (x86), svn 857
Media Player Classic HomeCinema (x64), svn 857
Supported languages: CN, CZ, DE, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA
Changes log
nvidia cards now support level 5.1 streams
Win10 x64, i7 7700K 5.2Ghz, ASUS MAXIMUS VIII HERO, HyperX Fury 16GB (2x8GB) 3000MHz, ASUS GTX1060-6G,TV Philips 40PFS6909/12, MED1000X3D
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 4th November 2008, 18:56   #4637  |  Link
Casimir666
Just an idea...
Yes : D3DADAPTER_IDENTIFIER9 have a DriverVersion field ;-)
Tired of tearing?
Old 4th November 2008, 18:57   #4638  |  Link
Jeff Flowerday
It works within MPC-HC itself. But I'm trying to get the external filters working so I can use Media Portal for me media center needs.
If I use mpegsplitter.ax externally with dtsac3source.ax or ffdshow's audio decoder I get nothing. I'm probably doing something wrong, I'm a bit of a noob at this.
Old 4th November 2008, 18:59   #4639  |  Link
MatMaul
I need someone with a nvidia card to launch this little program before and after the driver update :
http://www.etud.insa-toulouse.fr/~mv...er_version.exe
MatMaul is offline
Old 4th November 2008, 20:12   #4640  |  Link
rack04
Which update? 178.24 -> 180.43 or pre 178.24 -> 178.24?
rack04 is offline
dxva, h264, home cinema, media player classic, mpc-hc
