Old 23rd August 2008, 18:00   #3941  |  Link
marc99
@Mercury_22
Use "WMV PowerToy" to enable DXVA and VMR renderer in MPC-HC. With EVR renderer DXVA doesn't work with combination: Vista+MPC-HC+WMVideo Decoder DMO.
Windows 7 RC 64bit, NVidia GF8600GT 190.38
marc99 is offline
Old 23rd August 2008, 18:57   #3942  |  Link
Mercury_22
Originally Posted by marc99 View Post
@Mercury_22
Thanks ! Big improvement but video still not smooth like when I'm using Powerdvd !
Windows 10 x64 CU, HD7790 Crimson 17.6.2, HDMI Full RGB 4:4:4
Mercury_22 is offline
Old 23rd August 2008, 19:51   #3943  |  Link
rica
As far as i understand you can't use Cyberlink filters with VC1files under MPC-HC, do you?
rica is offline
Old 23rd August 2008, 21:05   #3944  |  Link
STaRGaZeR
4:2:0 hater
Any chances about Autoplay for Vista?
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline
Old 23rd August 2008, 21:11   #3945  |  Link
Mercury_22
I can use Cyberlink VC-1 filters with MPC (only if I use Cyberlink's Demux too) but for this file it's not working !
To resume PowerDVD it's playing the video smooth but without sound (DTS-HD 5.1), MPC + any audio filter (internal or FFDshow or AC3Filter) + WMVideo Decoder DMO it's out of sync and a slow video, MPC + any audio filter (internal or FFDshow or AC3Filter) + Cyberlink's Demux + Cyberlink VC-1 filters = the file it's NOT playing !
Old 23rd August 2008, 21:41   #3946  |  Link
rica
You can't listen DTS-HD with Cyberlink filters.
Uninstall haali,
Make Cyberlink Demux's merit 008000FF with Radlight Filter Manager.
Untick "MPEG/PS/TS/PVA" and "Matroska" under "Source Filters" and "VC1 dxva", "VC1 ffdmpeg" under "Transform Filers" of intenal filters option,
Select "Cyberlink VC1 decoder" and "arcsoft audio decoder hd" and set their merits "prefer" under external filters option.
(You can use Arcsoft TMT trial for test)
Don't forget to correct 2 channels to 5.1 on the arcsoft audio decoder HD properties page everytime.
For giving it a go with arcsoft filters only:
http://forum.doom9.org/showthread.ph...17#post1171217
EDIT:
Another tip: If you don't want to use arcsoft filters at all, you can try this:
Register standalone MPC filters:
MPC DTS/ac3 source and MPC mpa decoder..
Make a TS including just vc1 video-without audio.
Put it into the same folder which includes *.dts file (extracted DTS-HD)
Open video with MPC-HC; you will see standalone audio starts playing with the filter chain MPC DTS Source > MPC mpa decoder > Default DS Device.
rica is offline
Old 23rd August 2008, 21:57   #3947  |  Link
clsid
Ignore the "XP only" part (which I have removed yesterday) and you will probably discover that it already works.
clsid is offline
Old 23rd August 2008, 22:08   #3948  |  Link
Mercury_22
Uninstall haali,
EDIT: Another tip: If you don't want to use arcsoft filters at all, you can try this:
I've already tried all that except using arcsoft filters with Cyberlink Demux ! Is your chain Cyberlink Demux + Cyberlink VC1 + arcsoft audio decoder hd working for you with my sample ?
Old 23rd August 2008, 22:30   #3949  |  Link
rica
Now i'm downloading. I'll edit here.
EDIT:
The working graph:
Cyberlink demux doesn't work with arcsoft audio decoder hd with your sample.
But there is something wrong with your file; extract vc1 and audio with eac3to and remux with TSMuxer again.
rica is offline
Old 23rd August 2008, 22:42   #3950  |  Link
STaRGaZeR
4:2:0 hater
I did, but it isn't working. Maybe because I'm using Vista64 and MPC-HC 32? MPC is not listed in autoplay options, and PowerDVD is still used when a DVD is inserted. The option remains checked in MPC.
Old 23rd August 2008, 23:21   #3951  |  Link
rica
Have a look at my previous post.
BTW, eac3to never recognizes your file: (which means your remux is faulty)
C:\>eac3to\eac3to.exe "C:\Users\rica\Desktop\VC1.m2ts" "C:\Users\rica\Desktop\VC1_out.vc1"
The format of the source file could not be detected.
Edit: i've changed your file name to VC1.m2ts...
rica is offline
Old 23rd August 2008, 23:52   #3952  |  Link
Mercury_22
So isn't working for you too !! (Cyberlink Demux + Cyberlink VC1 + any audio decoder )
Other chains are working for me too but like I've said before I need Cyberlink VC1 so I can use DXVA ! and i can't find any demux to which I can connect it except Cyberlink's
Does Arcsoft Video decoder VC-1 support DXVA ? (for Intel )
Old 23rd August 2008, 23:59   #3953  |  Link
rica
First of all you are still missing the reality of your file is faulty.
Not sure for intel but i think you should try at least...
rica is offline
Old 24th August 2008, 01:01   #3954  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic HomeCinema (x86), svn 752
Media Player Classic HomeCinema (x64), svn 752
Supported languages: CN, CZ, DE, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA
Changes log
Rev.(747-752) Remove Playlist form Video Group on "Formats" Page; Update Traditional Chinese translation for command switches and renderer settings; Updated command line parameters Czech translation. Adapted changes from mplayerc.rc, modified the layout of Output dialog (there is not enough space for translation otherwise); Fix : crash on large PGS objects; Fix : incorrect palette management in PGS.
alexins is offline
Old 24th August 2008, 01:07   #3955  |  Link
Mercury_22
I've updated the sample with a cut from the beginning of the file http://rapidshare.com/files/13962309...Test.m2ts.html Let me know if this one is working with Cyberlink's VC1 for you please
Old 24th August 2008, 05:16   #3956  |  Link
Snowknight26
It seems as if the H.264 decoder (DXVA only) has problems with old x264 encodes when the mvs were -512,512 instead of -512,511.75.
Believe it caused the 2nd problem I mentioned here.
Snowknight26 is offline
Old 24th August 2008, 10:17   #3957  |  Link
Casimir666
First public release with fully functionnal subtitles support for M2TS is available here :
http://www.zshare.net/download/175456839b0ae289/
Since i have made heavy modifications in subtitle engine, please let me know if :
- you see broken things in SRT or MKV subtitles for example.
- some BRD subs are not displayed properly
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 24th August 2008, 10:47   #3958  |  Link
Miryan
I tested with some mkv files with subs, and everything is fine. I dont have BRD (?), sorry.
Miryan is offline
Old 24th August 2008, 11:54   #3959  |  Link
STaRGaZeR
4:2:0 hater
SSA/ASS subs are fine it seems. Also, now that you're working on subs, it's possible to "fix" the way MPC handles the subs compared to VSFilter, specially the blurred part, so we can get that kind of subs with DXVA?
Old 24th August 2008, 11:59   #3960  |  Link
Casimir666
Sorry what do you mean by this? Do you have some screenshots with those differences?
Tired of tearing?
dxva, h264, home cinema, media player classic, mpc-hc
