Old 7th July 2008, 00:10   #3041  |  Link
rica
Originally Posted by KyleK View Post
Here's a screenshot of the result:
Dragging a H.264 file (.mkv) to the program prompted me to use ffdshow, which I ok'ed. But it shows it as "unsupported".
I'm using the latest ATi Catalyst driver 8.6 and I'm pretty sure I had this one on my previous Vista installation as well.
Your url link doesn't work.
rica is offline
Old 7th July 2008, 00:17   #3042  |  Link
gngn
the hedgehog
gngn's Avatar
maybe a Vista without netFramework 3.0 ?
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 7th July 2008, 00:27   #3043  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Picture corruption with every H264 file with DXVA, without DXVA - all fine, no artefact.
Vista SP1 x64, 8800GT (4318), MPC-HC 637
But all fine playback with MPC-HC 631
Aleksoid1978 is offline
Old 7th July 2008, 00:50   #3044  |  Link
KyleK
Fixed the link: http://img301.imageshack.us/img301/9585/clip000js7.jpg
Every .NET framework from 1.0 to 3.5 is installed.
KyleK is offline
Old 7th July 2008, 01:11   #3045  |  Link
Kado
Otaku
Kado's Avatar
@KyleK
Install the stand alone filters in system32 folder but just "mpcvideodec.ax" from rev 629 and register it then use the program again to see the results, something like this. Right click near the red dxva and use the apropriate renderer, dxva1=vmr9/7 and dxva2=evr.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline
Old 7th July 2008, 01:21   #3046  |  Link
gngn
the hedgehog
gngn's Avatar
Originally Posted by Kado View Post
@KyleK
@suti: you could try the same thing with DXVAChecker: http://bluesky23.hp.infoseek.co.jp/#DXVAChecker , as you already have mpcvideodec.ax registered (verify which version you have, you can simply change the version by overwriting mpcvideodec.ax ). if DXVA works even with standalone filter r629 then its some setting in MPC maybe
gngn is offline
Old 7th July 2008, 03:28   #3047  |  Link
neoufo51
This FLV of the Pixar short, "Presto" makes MPC-HC crash big time as soon as it attempts to play it.
http://rapidshare.com/files/12759662...o_short_HD.flv
Tested with r637.
EDIT: It also makes the stable r604 release crash too
neoufo51 is offline
Old 7th July 2008, 03:34   #3048  |  Link
[-aRcTiC-]
Any help with my earlier post?
http://forum.doom9.org/showpost.php?...postcount=2965
DXVA works in vista x86 but not in xp x64? i had xp sp3 x86 before i installed 64bit and that worked..
[-aRcTiC-] is offline
Old 7th July 2008, 04:21   #3049  |  Link
73ChargerFan
73ChargerFan's Avatar
Version Numbers & Testing Suite
I think a lot of the recent traffic in this thread is due to people jumping onto the latest build version, but those are coming out too fast. Perhaps a rc should be released and tested. I've got movies that worked that now causing mpc-hc to crash.
Maybe a test suite could be made, like videos of different types, and then after a quick run through the playlist, it exits, the .ini file is changed to the next one (to test the next renderer, etc.), and so forth. I think it would require someone to watch it.
73ChargerFan is offline
Old 7th July 2008, 09:25   #3050  |  Link
cca
Anime Otaku
@clsid:
regarding the selection between DXVA or internal FFmpeg, I discovered that it works OK with rev604, but not on the newer revisions where you attempted to seperate the functionality. I guess some work is needed to separate the DXVA completely from the FFmpeg decoder.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit
cca is offline
Old 7th July 2008, 10:01   #3051  |  Link
KyleK
@KyleK
I registered the MPCVideoDec.ax as suggested using "regsvr32 MPCVideoDec.ax", which was confirmed as Success. Unfortunately, DXVAChecker doesn't seem to "see" that filter at all. Nothing happens when dragging a video file to the application.
I then disabled all internal transform filters in MPC-HC, to see if it loads the external filter, but no such luck. When looking at the "External filters" list and hitting "Add Filter...", the external decoder is not listed either.
Playing a H.264 video, MPC falls back to the internal filter (even though it should be disabled), and the problem mentioned earlier is present again.
I'm at a loss. I used to register filters this way all the time. I have no idea why Windows wouldn't properly register the external decoder.
KyleK is offline
Old 7th July 2008, 10:42   #3052  |  Link
ranpha
@developers.
Thanks for fixing that screenshot-taking bug with EVR renderer. Now I can avoid the chroma upsampling bug in EVR custom presenter.
ranpha is offline
Old 7th July 2008, 12:25   #3053  |  Link
clsid
Originally Posted by cca View Post
@clsid:
I can't reproduce it, so I can't fix it.
clsid is offline
Old 7th July 2008, 13:26   #3054  |  Link
cca
Anime Otaku
Fair enough.
cca is offline
Old 7th July 2008, 13:41   #3055  |  Link
JohnLai
Some question here. Did mplayerc has post processing feature?
JohnLai is offline
Old 7th July 2008, 14:21   #3056  |  Link
clsid
No, it does not have postprocessing (not counting the shader functionality).
clsid is offline
Old 7th July 2008, 14:32   #3057  |  Link
gngn
the hedgehog
gngn's Avatar
there was a problem of this sort a while ago:
Originally Posted by Joniii
I'm having some problems.
1)
I think that standalone codecs aren't registered correctly. I registered both mpegsplitter.ax and mpcvideodec.ax (the ones someone compiled awhile ago) with dsfmgr, then tried to play .m2ts files and both WMP11 and VMC gave error that I don't have codecs to play this file.
I then unregistered both codecs and then registered v 1.1.0.0 codecs from sourceforge, then replaced those .ax files with the new versions which didn't work before, after that I was able to play all .m2ts files.
you could try this, register the one from soundfourge, and then overwrite it. and check the codecs tab if H264 is checked.
gngn is offline
Old 7th July 2008, 15:10   #3058  |  Link
CruNcher
CruNcher's Avatar
@Casimir666
As the others allready said between 631 and 634 something bad happened to the DXVA part it's totaly corrupted playback now
Sys:
Windows XP Sp3
GFX: 8800 GT
Driver: 177.41
Renderer: VMR9 (windowed)
631 from XvidVideo.ru is the last version that works for me useing 634 and it's only corruption.
It is about Time
CruNcher is offline
Old 7th July 2008, 15:20   #3059  |  Link
JohnLai
So, is there any plan to add it anytime soon?
Originally Posted by CruNcher View Post
@Casimir666
Sys:
Windows XP Sp3
GFX: 8800 GT
Driver: 177.41
Same here, video corruption on naruto by dattebayo remuxed to mkv. Previously, it will run fine after remux.
JohnLai is offline
Old 7th July 2008, 15:50   #3060  |  Link
cca
Anime Otaku
Does this corruption happen in every file? I tried a few files today with rev638 and did not notice anything.
cca is offline
dxva, h264, home cinema, media player classic, mpc-hc
