Old 5th December 2008, 17:24   #1681  |  Link
Can't look at it until tonight as my firewall blocks media sites. Can you put it on an FTP?
Guest is offline
Old 5th December 2008, 18:35   #1682  |  Link
@canTsTop
OK, got it from the link you PM'ed me.
Found and fixed the problem. Will be in the release. Thank you for your test results.
Guest is offline
Old 6th December 2008, 00:47   #1683  |  Link
I've updated the ZIP file with the fixed test version:
http://neuron2.net/misc/dgavcindex108test.zip
Guest is offline
Old 8th December 2008, 22:46   #1684  |  Link
opieant
don: Do you still plan to release the source code for DGAVCIndex in the future? I seem to remember you saying it would be released when more stable versions were out, but that was back in the "alpha" days.
Just curious about this since it would be interesting to modify DGAVCIndex to output details similar to those in D2V files such as field-related flags. That would make it possible detect pulldown patterns and pattern transitions, and ultimately convert 1080i to 1080p for a lot of source material, using an external application to analyze the picture/field info. This method works very well for MPEG-2 and would probably work nicely for H.264 video as well.
opieant is offline
Old 8th December 2008, 22:56   #1685  |  Link
That information is in the DGA file already. I've no plans at this time to release the source code.
Guest is offline
Old 9th December 2008, 05:14   #1686  |  Link
opieant
Blind I am. Thanks for the help.
Looks like I'm dealing with highly inefficient encodings since the data in the DGA file indicates each and every field is coded separately (PIC 1 and PIC 2 only), even if the source material (MPEG-2) made use of the RFF flag. D'oh!
opieant is offline
Old 27th December 2008, 15:57   #1687  |  Link
Chumbo
Chumbo's Avatar
@neuron2,
I ran into some errors with a tile. I've put the clip here for you if you have time to look at it please.
http://rapidshare.com/files/177250361/clip.h264.html (IF YOU'RE NOT NEURON2, PLEASE DON'T DOWNLOAD THIS AS THERE IS A 10-DOWNLOAD LIMIT).
Plays clean in MPC HC and via directshow, but causes errors to pop up and then garbage in the image. I'm using 1.0.7.
Chumbo
Chumbo is offline
Old 27th December 2008, 16:11   #1688  |  Link
It plays clean in DGAVCDecNV, so I conclude that it's a problem in the version of libavcodec that is used in DGAVCDec. The same problems appear in VLC.
Guest is offline
Old 27th December 2008, 16:59   #1689  |  Link
Chumbo
Chumbo's Avatar
Aha. Thanks for checking it out so quick. I have an ATI card in my system so I assume I can't use the nVidia version right?
Chumbo
Chumbo is offline
Old 27th December 2008, 23:17   #1690  |  Link
That's right, it runs only on the Nvidia cards.
Guest is offline
Old 28th December 2008, 10:29   #1691  |  Link
G_M_C
Neuron2:
ffdshow_tryouts project just released a new beta (23 dec 2008). Would an update of DGAVCIndex using libavcodec from that new beta6 be worthwhile ?
G_M_C is offline
Old 28th December 2008, 15:39   #1692  |  Link
Not until the regressions for random access are fixed.
Guest is offline
Old 28th December 2008, 15:58   #1693  |  Link
I've made some changes to improve audio delay detection and to properly detect and demux the new audio on BD, i.e., DTS Master Audio, TrueHD, EAC3. I would appreciate testing of this DGAVCIndex build:
Note that I ignore DTS Express audio because I cannot find anything that will play it, and it is never used for the main audio tracks.
I will port this to the NV tools when it is stabilized.
Guest is offline
Old 28th December 2008, 16:14   #1694  |  Link
nautilus7
nautilus7's Avatar
DTS express can be decoded by nero dts decoder. eac3to uses it to decode such tracks.
nautilus7 is offline
Old 28th December 2008, 23:10   #1695  |  Link
canTsTop
canTsTop's Avatar
tested few recordings with new test version, audio/video synchronization is correct
canTsTop is offline
Old 1st January 2009, 15:14   #1696  |  Link
Version 1.0.8
* Added support for the new audio types found on BluRay disks.
* Improved the audio delay calculation.
* Removed the Treat I as IDR option as it is now always enabled.
http://neuron2.net/dgavcdec/dgavcdec108.zip
Guest is offline
Old 1st January 2009, 17:28   #1697  |  Link
Chumbo
Chumbo's Avatar
Thank you and Happy New Year!!!
Chumbo
Chumbo is offline
Old 3rd January 2009, 01:12   #1698  |  Link
Chefkoch_ico
Hi!
I have a problem concerning my Canon HF100 AVCHD camcorder.
I can set it to 24p recording, but too bad, it puts the 24p stream somehow into a 29,97 fps stream. There is no good way to retrieve the original frames, at least no that I know of.
Here are some details on this:
http://forum.corecodec.com/viewtopic...3&p=6947#p6793
http://forum.corecodec.com/viewtopic.php?t=817.0#p5007
Is there a way to sole this problem with DGAVCDec(NV) and AVISynth?
Best regards
Chefkoch_ico is offline
Old 3rd January 2009, 13:33   #1699  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
can you upload sample to www.mediafire.com
Atak_Snajpera is offline
Old 3rd January 2009, 14:12   #1700  |  Link
Chefkoch_ico
Done
http://www.mediafire.com/file/tnzgyh...817152150.m2ts
Thx
