Old 1st March 2008, 11:27   #441  |  Link
DonCarlos
Originally Posted by Pelican9 View Post
Try with 24fps. Open the HD DVD sup and click Save bitmaps.
hdsup2bdn put the files to the same folder where you running it.
I tried it with 24fps the was my thought too, but then I get an error in Scenarist because the framerate doesn't fit to the video, so scenarist doesn't want to mux it.
Then I don`t know why hdsup2bdn does not work for me?!
Could you please gie me an example command line on how to configure it for my job?Because it does something an says processing took 20 seconds but Ican't find a file anywhere.
Thank you.
DonCarlos is offline   Reply With Quote
Old 1st March 2008, 11:59   #442  |  Link
Pelican9
Coder
Pelican9's Avatar
If you are not a unix/linux man it is hard to find the help.
D:\util\Projects\SUPread>hdsup2bdn --help
Allowed options:
  --help                produce help message
  --version             print version number
  --original            output PNG images in the original size (suitable for
                        OCR)
  --fullpng             output 1920x1080 PNG images [DEFAULT]
  --nobdnfixtimes       do not divide BDN times by 1.001 (BDN output only)
  --bdnfixtimes         divide BDN times by 1.001 (BDN output only) [DEFAULT]
  --srtfixtimes         divide SRT times by 1.001 (SRT output only)
  --nosrtfixtimes       divide SRT times by 1.001 (SRT output only) [DEFAULT]
  --framerate arg       frame rate [DEFAULT: 29.97]
  --input-file arg      input file
  --srt                 output SRT file
  --xml                 output Scenarist HDMV BDN file
  --forcedsubs          make all subtitles forced (BDN output only)
  --dropframes          flag all subtitle times as drop frames (BDN output
                        only)
  --nopng               don't generate any PNGs
hdsup2bdn file.sup --xml --framerate 23.976
Pelican9 is offline   Reply With Quote
Old 1st March 2008, 12:21   #443  |  Link
Pelican9
Coder
Pelican9's Avatar
New beta (v0.51b6)
I've found a bug and fixed it. The new SUPread generate the same xml as hdsub2bdn.
Old 1st March 2008, 12:40   #444  |  Link
DonCarlos
Ok thank you very much I will try it.
Old 1st March 2008, 16:33   #445  |  Link
jamos
Hey Now!
jamos:
Could you try to input a HD DVD subtitle stream -> export PNGs -> import in Scenarist?
If i had one. i have no hd dvd subtitles (only bluray) if someone could link one i would try.
edit: I just tried 1080p bluray subtitles and they are fine. so its the conversion of 1080 to 720p that is causing the issue with the blank white screen.
Like I said the 720p fonts have holes in them and the font color bleeds to the background.
jamos is offline   Reply With Quote
Old 1st March 2008, 17:04   #446  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
Here you go.
http://www.divshare.com/download/3923820-5d3
B4tm4n is offline   Reply With Quote
Old 1st March 2008, 17:55   #447  |  Link
jamos
Hey Now!
Originally Posted by B4tm4n View Post
Thanks Bat,
yes HD dvd subtitles work fine with scenarist in 1080p.
Old 1st March 2008, 18:08   #448  |  Link
jamos
Hey Now!
720p subtitles now work! although the font is a bit messed up from downconverting.
Old 1st March 2008, 18:24   #449  |  Link
Pelican9
Coder
Pelican9's Avatar
What happened?
Old 2nd March 2008, 02:39   #450  |  Link
jamos
Hey Now!
sorry 720 subtitles look fine but they are out of sync for 23.976 video.
Old 2nd March 2008, 02:40   #451  |  Link
jamos
Hey Now!
What happened?
I am not sure whatever you changed in the last release fixed it. but like i said the sync is now off.
Old 2nd March 2008, 02:42   #452  |  Link
jamos
Hey Now!
something broke the sync for 23.976 non drop not sure what it was but they were in sync before this version. about a 12 second delay on the subtitle.
xml output from previous version of supread <Events Type="Graphic" FirstEventInTC="00:02:08:07"
output from current version from same sup file <Events Type="Graphic" FirstEventInTC="00:02:19:22"
Old 2nd March 2008, 06:15   #453  |  Link
jamos
Hey Now!
Pelican is there anyway we can download older versions of supread? would like to use older version to check this sync error.
edit: ok it seems that using xport i get the correct timings, the sup i was testing that had the wrong timings was demuxed with tsremux. I suggest everyone use xport to demux m2ts streams.
nice photos btw.
Old 2nd March 2008, 07:16   #454  |  Link
jamos
Hey Now!
ok so now I can confirm that the current version of supread works with scenarist hdmv with both bluray and hd subtitles in both 1080p and 720p.
Old 2nd March 2008, 08:04   #455  |  Link
hm10
you can give me the data.pas that you did?
to comapre with i do you well
hm10 is offline   Reply With Quote
Old 2nd March 2008, 08:18   #456  |  Link
Pelican9
Coder
Pelican9's Avatar
Glad to hear!
And big thanks for the test.
You can download from my site.
Send it to me with your png and I will check it.
Old 2nd March 2008, 10:20   #457  |  Link
hm10
you mean this?
http://pel.hu/down/data.pas
i need to put my new letters in the end of the letdat (after 256) and than in the end of letdati (after 256)?
line, x pos', width, dec after, dec before (from left to right)?
(0, 0, 0, 0, 0), //1 ?
Old 2nd March 2008, 11:30   #458  |  Link
Pelican9
Coder
Pelican9's Avatar
Yes.
Yes. Yes.
You have to put your data here (line 292-):
290:       (0,    0,  0, 0, 0))
291://   ,( // put the new data here (normal)
292://     (0,    0,  0, 0, 0),
293://             ...
294://     (0,    0,  0, 0, 0))
295:       );
and here (line 556-):
554:       (0,    0,  0, 0, 0))
555://   ,( // put the new data here (italic)
556://     (0,    0,  0, 0, 0),
557://             ...
558://     (0,    0,  0, 0, 0))
559:       );
But you can put your data anywhere, I will correct it.
Old 2nd March 2008, 11:41   #459  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
here the code the palette defintion in BDN xml project.
                <xs:element name="Palettes" minOccurs="0">
                    <xs:complexType>
                        <xs:sequence>
                            <xs:element name="Palette" maxOccurs="unbounded">
                                <xs:annotation>
                                    <xs:documentation>ID: Alphanumeric ColorSpace: RGB/YCrCb</xs:documentation>
                                </xs:annotation>
                                <xs:complexType>
                                    <xs:sequence>
                                        <xs:element name="Entry" maxOccurs="256">
                                            <xs:annotation>
                                                <xs:documentation>(R,G,B,A) or (Y,Cr,Cb,T) See Sec 9.11.4.2.3 in BD-ROM Spec 0.89r3 for constraints</xs:documentation>
                                            </xs:annotation>
                                            <xs:complexType>
                                                <xs:attribute name="Index" use="required">
                                                    <xs:simpleType>
                                                        <xs:restriction base="xs:int">
                                                            <xs:minInclusive value="0"/>
                                                            <xs:maxInclusive value="254"/>
                                                        </xs:restriction>
                                                    </xs:simpleType>
                                                </xs:attribute>
                                                <xs:attribute name="Y_R" use="required">
                                                    <xs:simpleType>
                                                            <xs:maxInclusive value="255"/>
                                                        </xs:restriction>
                                                    </xs:simpleType>
                                                </xs:attribute>
                                                <xs:attribute name="Cb_G" use="required">
                                                    <xs:simpleType>
                                                        </xs:restriction>
                                                    </xs:simpleType>
                                                </xs:attribute>
                                                <xs:attribute name="Cr_B" use="required">
                                                    <xs:simpleType>
                                                        </xs:restriction>
                                                    </xs:simpleType>
                                                </xs:attribute>
                                                <xs:attribute name="T_A" use="required">
                                                    <xs:simpleType>
                                                        </xs:restriction>
                                                    </xs:simpleType>
                                                </xs:attribute>
                                            </xs:complexType>
                                        </xs:element>
                                    </xs:sequence>
                                    <xs:attribute name="PaletteID" type="xs:string" use="required"/>
                                    <xs:attribute name="ColorMode" use="required">
                                        <xs:simpleType>
                                            <xs:restriction base="xs:string">
                                                <xs:enumeration value="RGB"/>
                                                <xs:enumeration value="YCrCb"/>
                                            </xs:restriction>
                                        </xs:simpleType>
                                    </xs:attribute>
                                </xs:complexType>
                            </xs:element>
                        </xs:sequence>
                    </xs:complexType>
                </xs:element>
1) Perhaps good way to close HDDVD subtitles support
2) Perhaps better way to import palette from m2ts and export directly in xml file
3) Possible to make xml BDN file with direct srt import?
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 2nd March 2008, 12:21   #460  |  Link
hm10
just save this data file and do png?
and i can add bold style? or don't need
edit: how i do the y coordinates bottom (green in u'r picture) in big ABC letters? the bottom and the base same
supread, suprip
