Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Thread Tools Display Modes
Old 29th January 2007, 04:41   #1  |  Link
ad25
Adobe Premiere Pro 2.0 and Avisynth AVS scripts
Is anyone able to open .avs files in Premiere Pro 2.0? I have tried the plugin available here: http://videoeditorskit.sourceforge.net/ but it doesn't seem to work.
I have also tried using VFapiConv to create a dummy avi file and open that in PPro 2.0. This method does work, however Premiere will stop responding if I shift the focus away from it, making this method impractical to use.
The only reliable method I have found is to open the avs file in VurtualDub and save to an avi file. This sort of defeats the purpose since I have to create the intermediate file, but this is the only working method I have found.
Does anyone have any suggestions for working with avs files in Premiere Pro 2.0? Thanks in advance.
ad25 is offline   Reply With Quote
Old 29th January 2007, 05:27   #2  |  Link
neuron2
_
neuron2's Avatar
Found on the web:
"download the zip file of the plugin from
http://sourceforge.net/projects/videoeditorskit
and copy the IM-Avisynth.prm file to the Adobe/Premiere Pro 2.0/Plug-Ins/en_US/ folder. see if that works... "
neuron2 is offline   Reply With Quote
Old 29th January 2007, 08:25   #3  |  Link
Blue_MiSfit
fit 10 in 5
Blue_MiSfit's Avatar
I've tested, and it works! Amazing! This is kind of a big deal for me, it really allows integration of AviSynth into a Premiere workflow.
If only there was a decent plugin for avisynth that could frameserve from a premiere pro project file! How cool would that be?
~MiSfit
I require bits. More bits!
Old 29th January 2007, 09:24   #4  |  Link
krisq
I'm using this plugin in premiere 2.0 for a couple of months now without any problems. Excellent stuff
(!sig)
krisq is offline   Reply With Quote
Old 29th January 2007, 10:35   #5  |  Link
Chipstra
I use premiere 6.5 with the Matrox RT2500, but I only have TV output by the Matrox break-out-box when I use Matrox codecs.
Is there a way to:
- Hook the avs/vDub output to the the RT2500 break-out-box ?
- Hook premiere output to the Maxtrox break-out-box when using non Matrox codecs?
Thnx
Chipstra is offline   Reply With Quote
Old 29th January 2007, 19:09   #6  |  Link
ad25
Found on the web:
I had already done this, but I assumed that since I was unable to open my test.avs file, it wasn't working.
After reading the responses here, I made a sample avs file with just ColorBars() and it works in PPro. So then I started trying different things to see what works and what doesn't. I discovered that I can open most avs files in PPro 2.0, but I can't open scripts that use MPEG2Source and don't include ConverttoRGB() or ConverttoYUY2(). So it appears that my problem is with opening YV12 avs files in Premiere Pro 2.0.
I then tried the problem scripts in other apps. They open fine in VirtualDub, but will not open in Windows Media Player. I am not very up on all of this, but I think this means that I have a problem with DirectShow and YV12.
Can anyone point me in the right direction towards resolving this problem? Thanks.
Edit: It appears that I have found the solution to my problem. After reading this thread:
http://forum.doom9.org/showthread.php?threadid=56972
I downloaded the Helix YV12 codec and installed it and everything seems to be working okay.
Last edited by ad25; 29th January 2007 at 20:10. Reason: Found the answer to my question
Old 26th May 2007, 03:22   #7  |  Link
SealTooGreat
Plugin was reporting that my AviSynth is old...When importing AVS to Premiere Pro 2.0 there was no video, only audio.
I've just installed AviSynth 2.5.7 (January 7, 2007) - problem is solved. I thought it might be helpful if someone confront the same issue.
SealTooGreat is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
