Old 24th April 2007, 00:18   #1081  |  Link
haruhiko_yamagata
Originally Posted by wozio View Post
Isn't it VIDEOINFOHEADER2 set for each media sample passed to renderer?
Yes.
So only thing to do for decoder is to pass flags from encoded stream.
ffdshow pass interlacing flags only when "HW deinterlacing" is checked. Otherwise ffdshow sets the flag progressive. Most of DirectShow decoders have this kind of option.
It is up to renderer (or in fact drivers if we are talking about VMR) to detect correct deinterlacing mode.
Decoders can choose weave and bob.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 24th April 2007, 02:16   #1082  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
Originally Posted by haruhiko_yamagata View Post
Yes.
Correct. In most cases "weave" is the same as progressive (or no VIH2) since it instructs the renderer to simply leave the frames weaved as is. "Weave" basically means "don't touch".
Most decoders will signal AMINTERLACE_DisplayModeBobOnly when they want the renderer to deinterlace the video, but this doesn't imply that bobbing must be used. Depending on the VMR and its mode (VMR7 acts differently in regular vs YUV Mixing mode), same-framerate deinterlacing or double-framerate bobbing might occur. That part's up to the renderer and the video HW.
Furthermore, I've noticed that most GPU deinterlacers do a good job of detecting true interlaced vs progressive signaled as interlaced and adapting the renderered framerate on the fly. I encoded a video once of a 1-minute source where the first half was truly interlaced, and then the second half was the same as the first half but deinterlaced. The first half was encoded in VC-1 as field interlaced, and the second half was encoded as progressive - but the whole ASF file was signaled as interlaced. When decoded back via DXVA and VMR9, the first half was played back at 59.94 fps, and then at the midpoint the framerate started dropping until it reached 29.97 fps. I think I tested this on an Nvidia 6600 GPU.
zambelli is offline   Reply With Quote
Old 24th April 2007, 07:02   #1083  |  Link
wozio
I noticed the same for VMR9 but I think it is not regular mixing vs YUV mixing but more non mixing vs mixing mode (as far as I can tell yuv mixing is almost the same as rgb mixing but without last step of converting to RGB and passing it as a output, but I'm trying it only with one HW and only in my own app so I probably messed something).
Modern GPUs can do even more, for example regular film telecined material broadcasted with scrolling text in regular ntsc frame rate can be properly deinterlaced to maintain both ivtc and smooth text movement
One more thing to add here. On my HW (ATI X1650) renderer (VMR9) input colorspace must be set to NV12 for advanced deinterlacing to work. With other colospaces driver does simple bob. So I have to disable all other colorspaces in ffdshow to force NV12 output. It would be good to add some kind of list with possibility to prioritize proposed colorspaces. This is really done well in coreavc, there is a list with colorspaces and they are proposed downstream in order (it is possible to move colorspaces on list as weel as disabling some of them).
Anyway for me this HW deinterlacing setting in ffdshow is not needed and confusing.
wozio is offline   Reply With Quote
Old 24th April 2007, 08:35   #1084  |  Link
alter4
I cannot reproduce.
What is your CPU? Which build do you use?
What is the size (width, height) of the video?
My CPU is pentium 4 (model 631) video size 540x300
which build is not important, bug appears in all builds
alter4 is offline   Reply With Quote
Old 24th April 2007, 12:43   #1085  |  Link
iron2000
Questioning User
Wow, sure did confuse me.
So when checked the next filter after ffdshow will know if the video is interlaced or not and when unchecked ffdshow will mark all videos as deinterlaced?
What if the driver has more method other than weave and bob, does it mean that ffdshow restricts it only to the 2 methods?
The guide at MeWiki is a pretty good start, hope that it will cover all the options in the future or maybe put them up on a ffdshow-tryouts wiki.
iron2000 is offline   Reply With Quote
Old 24th April 2007, 15:15   #1086  |  Link
haruhiko_yamagata
Yes. As a hint for downstream. But downstream filter may detect the stream interlaced (or telecined DVD) and try to deinterlace (IVTC). It's downstream's choice.
It's just flag. Downstream filters may ignore the flag. You can force the downtream filter to ignore the upper stream's flag, if the filter supports the configuration.
Old 24th April 2007, 16:38   #1087  |  Link
vlada
As zambelli already said, weave is not a deinterlace method. It means, that the renderer treats the video as if it was progressive (no matter if it really is). So the only choice for an interlaced video is (smart) bob. There are usually no other deinterlace methods. But if you had for example a graphic card with more deinterlace algorithms, you'd have to choose them in driver properties. There's no way how ffdhsow could control it.
vlada is offline   Reply With Quote
Old 24th April 2007, 19:51   #1088  |  Link
cc979
Curious BetaTester
on ffdshow svn version 1122 is there a typo on
line 124 of makefile_c.inc
should it be this ?
--def $(GCCDEF) $(GCCDLLENTRY) -o $@ $(OBJS) -lpthread $(GCCLIBS)
as it did not compile before i changed it
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT
Tools: ProcessExplorer & ProcessMonitor - BatchCompressor
Guide: MinGW Compiling GCC
cc979 is offline   Reply With Quote
Old 25th April 2007, 05:58   #1089  |  Link
_xxl
ffdshow user
_xxl's Avatar
I would like to uncheck TomsMoComp,kernelDeint and x264 from msvc 2003(2005) solution files.
TomsMoComp,kernelDeint should be compiled by ICL and x264 by GCC.
_xxl is offline   Reply With Quote
Old 25th April 2007, 08:28   #1090  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
I have a question regarding the Audio Decoder Configuration option under Output named "Don't use WAVEFORMATEXTENSIBLE header when not needed"...
Would it be possible to make this into a dropdown list with options:
* Never use WAVE_FORMAT_EXTENSIBLE
* Don't use WAVE_FORMAT_EXTENSIBLE when not needed
* Always use WAVE_FORMAT_EXTENSIBLE
As it is right now, I can prevent Ffdshow from outputting WAVE_FORMAT_EXTENSIBLE headers, but I can't force it to output WAVE_FORMAT_EXTENSIBLE headers.
Old 25th April 2007, 09:21   #1091  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
The second option would be better worded "Only use when needed". Double negatives suck :P
check is offline   Reply With Quote
Old 25th April 2007, 10:36   #1092  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
No argument about x264 from me, but what about us folks who only have MSVC (and of course GCC, since it's free)?
And isn't there a separate ICL9 project anyway?
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 25th April 2007, 11:34   #1093  |  Link
clsid
ICL9 binaries for TomsMoComp and kernelDeint are in the SVN. So there is no need to compile them.
I agree that they should be removed (not just unchecked) from the main msvc solution files. There are separate project files present for them anyway.
Old 26th April 2007, 00:13   #1094  |  Link
TheShadowRunner
TheShadowRunner's Avatar
2 little suggestions:
- for the installer: if it could remember the language used during previous ffdshow installations.
- for ffdshow: for the "logoaway" feature, if we could have a feature for setting the position easily. Like a preview either in red or as negative image, to set the position accurately, and then we would disable it for the normal processing.
Hope you see what i mean ^^;
Later,
TSR
TheShadowRunner is offline   Reply With Quote
Old 26th April 2007, 10:59   #1095  |  Link
clsid
That is not possible with the install software that we use.
Old 26th April 2007, 16:11   #1096  |  Link
haruhiko_yamagata
Thank you. Now I can reproduce the bug.
The debug may be hard because it's random and rare.
Old 26th April 2007, 16:24   #1097  |  Link
Seb.26
20-35 a win for Revolver.
Seb.26's Avatar
Hi world !
is there a way to disabling the TV->PC level remapping done when input is YV12/YU2 and output is RGB32 ?!
( = just output same level in RGB32 ... )
Thanks !
Seb.
Seb.26 is offline   Reply With Quote
Old 27th April 2007, 09:01   #1098  |  Link
_xxl
ffdshow user
_xxl's Avatar
I have added SSE3 & SSSE3 detection code:
Patch
http://rapidshare.com/files/28159079/ssse3.rar.html
Bin
http://rapidshare.com/files/28158873..._test.exe.html
Yasm 0.6.0 is needed.
If anybody is interested in testing and helping me to fix it.
This will be used in xvidcore 1.2 and x264.
Old 27th April 2007, 13:31   #1099  |  Link
Px
>>^^__^^<<
Px's Avatar
Patch
Bin
Intel E6300
Intel P3-450
Also small speedup compared to 1090 icl9
Null
User: 44s, kernel: 0s, total: 44s, real: 46s, fps: 26.4, dfps: 25.5
o/m
User: 45s, kernel: 0s, total: 45s, real: 46s, fps: 26.1, dfps: 25.6
1124
Null
User: 43s, kernel: 0s, total: 43s, real: 44s, fps: 26.9, dfps: 26.3
o/m
User: 44s, kernel: 0s, total: 44s, real: 45s, fps: 26.5, dfps: 25.9
Px is offline   Reply With Quote
Old 27th April 2007, 19:38   #1100  |  Link
_xxl
ffdshow user
_xxl's Avatar
Intel E6300 doesn't have 3dnow! ext.
3dnow! ext can't be disabled...
