Old 29th January 2010, 20:44   #10541  |  Link
tal.aloni
Originally Posted by buletti View Post
sharpening and denoising operations could probably work and would be greatly appreciated.
HeadlessCow was right on the money.
the DXVA decoded frame ends up being written to USWC memory,
which was not designed for fast reading operations.
sharpening and denoising can be made to work with the beta 2, but you'll learn that it's unstable, and the CPU usage is greater than software decoding.
tal.aloni is offline   Reply With Quote
Old 29th January 2010, 20:51   #10542  |  Link
dann23
do you plan to add MPEG2 to be decoded using DXVA?
dann23 is offline   Reply With Quote
Old 29th January 2010, 21:01   #10543  |  Link
tal.aloni
I think that albain would share my view that if casimir (MPC-HC) will implement it, we will import it as well, but I don't really think it's worth the effort. mpeg2 decoding does not require much cpu power.
Old 29th January 2010, 21:02   #10544  |  Link
albain
Media Control author
Yes, also MPEG2 does not consume a lot of CPU
And MPEG2HD is a dead end (HDDVD)
albain is offline   Reply With Quote
Old 29th January 2010, 21:35   #10545  |  Link
hoborg
Hi.
By some reason i am not able to make DXVA + subtitles (and OSD) work.
Haali <-> FFDShow DXVA decoder Pin is connected, but no subtitles are displayed (EVR as renderer).
No problem in "normal" FFDShow.
Win7 + ATI 4770
EDIT:
Same result on XP:
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline   Reply With Quote
Old 29th January 2010, 22:14   #10546  |  Link
tetsuo55
MPC-HC Project Manager
We already added it in http://sourceforge.net/apps/trac/mpc-hc/changeset/1552
tetsuo55 is offline   Reply With Quote
Old 29th January 2010, 22:38   #10547  |  Link
dann23
Originally Posted by tetsuo55 View Post
yes thank you. hope that albain will change his mind
Old 29th January 2010, 22:43   #10548  |  Link
tal.aloni
Originally Posted by hoborg View Post
Hi.
have you enabled post-processing? (configuration > hardware acceleration)
Old 29th January 2010, 23:08   #10549  |  Link
Mr VacBob
On a related note, libavcodec and ffmpeg-mt should give better performance now compared to any 2009 build. The gain is supposed to be a few %. It would be interesting to see some benchmarks.
It should be more than 10% so far (it's not done yet). r21455 should improve high bitrates, but I didn't push it into mt yet.
There's also some MMX/SSE/2 inlined directly into the decoder now, so you'll see further improvements (~3%) if you can build with --cpu=i686 or higher.
Mr VacBob is offline   Reply With Quote
Old 29th January 2010, 23:13   #10550  |  Link
hoborg
Nope, i miss that option, thanks!
My HTPC.
Old 30th January 2010, 00:02   #10551  |  Link
MatLz
I often say "maybe"...
MatLz's Avatar
Hi!
I've updated to 3237 but I'm in trouble with gamma correction:
A capture speaks more than a thousand words
What's the hell?
MatLz is offline   Reply With Quote
Old 30th January 2010, 00:26   #10552  |  Link
tal.aloni
Originally Posted by MatLz View Post
Hi!
Edit:
I see it now, modifying contrast triggers it.
starts with rev. 3233
Old 30th January 2010, 00:38   #10553  |  Link
MatLz
MatLz's Avatar
I'm also in trouble with sourceforge and mediafire....I can just say I think 3207 was ok.
Old 30th January 2010, 01:46   #10554  |  Link
thuan
Originally Posted by HeadlessCow View Post
thuan: could you do me a favor and try out the beta1 or beta2 build with the full processing mode to see if it drops frames like crazy? If the Intel guy wrote his code with an Intel graphics card, maybe you'll have better performance than the rest of us did. That would at least explain why he was able to get performance that is so much better than when tal.aloni used the code in ffdshow.
I will, on Monday as the computer with G45 is my computer at work. By full processing mode you meant Surface Overlay Post Processing mode right? And what did you mean by beta2? The last ffdshow-tryouts version is beta 6. I haven't used ffdshow for far too long (been using MPC-HC internal filter).
thuan is offline   Reply With Quote
Old 30th January 2010, 04:15   #10555  |  Link
onomatopellan
@thuan:This is beta1 http://forum.doom9.org/showthread.ph...14#post1364814
and this is the beta 2 http://forum.doom9.org/showthread.ph...03#post1365503
Originally Posted by albain View Post
I think this comes from the media types
I removed uncompress mediatypes but this is not a good idea because I guess that FFDShow DXVA may not be consulted for subtitles connection
I have done more tests and these are the results using ffdshow DXVA rev3237 in MPC-HC:
In my PC with Windows 7 32bits -> embedded subs of most files (sample) aren't detected. Subs are not shown
In the laptop Windows 7 64 bits -> embedded subs of most files aren't detected. Subs are not shown
In a PC with Windows Xp 32 bits -> All the embedded subs of my files are detected flawlessly. Subs are shown without problem
So maybe the problem is in the way Text input pin is connected in Windows 7? Can please somebody with Windows 7 confirm this?
onomatopellan is offline   Reply With Quote
Old 30th January 2010, 04:42   #10556  |  Link
thuan
Originally Posted by thuan View Post
Thanks to albain and tal.aloni that implemented DXVA and sub rendering with DXVA in ffdshow. I still have 2 problems with it though.
Sub bleeding and blocky
And broken image when seeking that happens sometimes
Tested at work on Intel G45, Windows Vista 64bit up to date BTW. I view my videos with Haali splitter. I also have the 9800GT with Windows 7 64bit at home and the 2nd problem happens there, too. I will check whether the first problem happens at my home computer configuration after work.
Thank you guys for the continuous development.
At home, the blocking problem when seeking is still the same. As for sub with DXVA, it simply does not work on my 9800GT . Driver is 196.21 on Windows 7 64bit.
Old 30th January 2010, 09:05   #10557  |  Link
tal.aloni
what do you mean by "does not work"?
did you enable "post processing"? (see above)
Old 30th January 2010, 09:29   #10558  |  Link
CiNcH
CiNcH's Avatar
But this is only MPEG-2 Bitstream which only works for some nVIDIA GPU's, right? Think most GPU's still only do MPEG-2 MC and iDCT.
Bye
CiNcH is offline   Reply With Quote
Old 30th January 2010, 09:36   #10559  |  Link
albain
Thanks, I didn't test your sample but if you say that it works on XP this confirms my thoughts : on XP directshow consults filters for uncompressed formats, not on vista/7
Here is a test build to confirm this
Please tell me if this solves the problem
Old 30th January 2010, 10:34   #10560  |  Link
tal.aloni
Hi!
should be fixed in rev. 3241
