Old 9th January 2010, 16:08   #10161  |  Link
XhmikosR
cd "/mydiskletter/myfolder"
My Specs
XhmikosR is offline   Reply With Quote
Old 9th January 2010, 16:09   #10162  |  Link
clsid
If you use my custom MinGW installer then you don't need to use MSYS. You can just run make from the windows command-line.
In MSYS you can use this command for changing dirs:
cd /c/path/to/ffdshow/source
MPC-HC 2.2.1
Old 9th January 2010, 17:31   #10163  |  Link
albain
Media Control author
Originally Posted by Jeremy Duncan View Post
I'm building ffdshow using mingw but it's been a while since I worked with mingw msys and don't know how to go to the directory where the makefile is.
Can you please tell me how to go to where the makefile is if I use msys?
I don't recommend using mingw to build ffdshow, besides the gain in performance will be imperciptible. You will get better performances with ICL.
However, mingw is required to build ffmpeg and other stuff around, the makefile is located in src directory
EDIT : okay, I didn't understand
albain is offline   Reply With Quote
Old 9th January 2010, 18:04   #10164  |  Link
deets
the holy grail for me would be ffdshow that can handle DXVA on the BBC HD and ITV HD live streams. sadly the beta just plays a couple of seconds then dies on the recorded files i have.
I would kill to just have one thing for my live satellite and recordings
deets is offline   Reply With Quote
Old 9th January 2010, 18:27   #10165  |  Link
_xxl
ffdshow user
_xxl's Avatar
From trunk/src dir type in Msys make and compile with MinGW GCC.
_xxl is offline   Reply With Quote
Old 9th January 2010, 21:16   #10166  |  Link
dann23
nothing is working with dxva since beta 3. I tried build 3190 and the same problem. I attached the debug log. Maybe you'll find something usefull in there.
http://www.mediafire.com/download.php?nzyznmmj4mj
dann23 is offline   Reply With Quote
Old 9th January 2010, 21:28   #10167  |  Link
crlorentzen
Audio Video Enthusiast
Originally Posted by albain View Post
Can you uncheck "Connect as PCM first" in the output section of FFDShow audio.
I think that should solve your problem.
In that case SPDIF will be initialized first and FFDShow won't have to do a dynamic format change (PCM to SPDIF) which fails as your audio driver will refuse it.
@Seb : thank you, maybe you can tell me if DXVA decoding is working for you ?
Without connect as PCM first DTS pass-through does not work. My receiver does not seem to want to change to DTS without first hitting PCM. If I disable all pass-through, start a DTS track then select the DTS pass-through it works. The receiver shows that at the start we have PCM (as it uses my surround mode for that), then immediately shifts to DTS when I select that pass-through option.
some testing with small data collection
http://ffdshow-tryout.sourceforge.ne...hp?p=4791#4791
I am tired and will take a break on this, go back to 3154 for now.
sorry albain. Thanks for being so willing to help. Hopefully I will come back to this in a week or two.
crlorentzen is offline   Reply With Quote
Old 9th January 2010, 23:23   #10168  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
I used the ffdshow custom mingw from the ffdshow wiki and built these dll's using msys:
libmplayer.dll
ff_liba52.dll
ff_libdts.dll
ff_libfaad2.dll
ff_libmad.dll
ff_realaac.dll
ff_samplerate.dll
ff_tremor.dll
xvidcore.dll
libavcodec.dll
ffmpegmt.dll
ff_theora.dll
ff_x264.dll
I cannot build these dll's below though. Here is a sample of the code I use in msys:
cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/imgFilters/KernelDeint"
make
here is the error codes:
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/ffS
pkCfg
$ make
gcc -c -I. -w -DWIN32 -D_WIN32 -D__MINGW32__ -mno-cygwin -mdll -mthreads -pipe -
DNDEBUG -UDEBUG -fno-rtti -fno-exceptions -O3 -march=i686 -mmmx -fno-common -fno
-tree-vectorize -fomit-frame-pointer -MMD -o ffSpkCfg.o ffSpkCfg.cpp
gcc.exe: CreateProcess: No such file or directory
make: *** [ffSpkCfg.o] Error 1
pkCfg
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/imgFilters/Kerne
lDeint"
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/img
Filters/KernelDeint
$ make
gcc -c -I. -DWIN32 -D_WIN32 -D__MINGW32__ -mno-cygwin -mdll -mthreads -pipe -DND
EBUG -UDEBUG -fno-rtti -fno-exceptions -O3 -march=i686 -mmmx -fno-common -fno-tr
ee-vectorize -msse -mfpmath=sse -fomit-frame-pointer -MMD -o ff_kernelDeint.o ff
_kernelDeint.cpp
make: *** [ff_kernelDeint.o] Error 1
Filters/KernelDeint
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/unrar"
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/unrar
$ make
gcc -c -I. -I../.. -DRARDLL -DNOCRYPT -DSILENT -DNOVOLUME -DSFX_MODULE -DSHELL_E
XT -DWIN32 -D_WIN32 -D__MINGW32__ -mno-cygwin -mdll -mthreads -pipe -DNDEBUG -UD
EBUG -UUNICODE -U_UNICODE -fno-rtti -fexceptions -O3 -march=i686 -mmmx -fno-comm
on -fno-tree-vectorize -fomit-frame-pointer -MMD -o archive.o archive.cpp
make: *** [archive.o] Error 1
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/codecs/libmpeg2"
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/cod
ecs/libmpeg2
$ make
gcc -c -I. -Iinclude -DWIN32 -D_WIN32 -D__MINGW32__ -mno-cygwin -mdll -mthreads
-pipe -DNDEBUG -UDEBUG -x c++ -O3 -march=i686 -mmmx -fno-common -fno-tree-vector
ize -msse -mfpmath=sse -fomit-frame-pointer -MMD -o libmpeg2/alloc.o libmpeg2/al
loc.c
make: *** [libmpeg2/alloc.o] Error 1
ecs/libmpeg2
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/rebase"
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/rebase
$ make
ee-vectorize -fomit-frame-pointer -MMD -o rebase.o rebase.cpp
make: *** [rebase.o] Error 1
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/imgFilters/TomsM
oComp"
Filters/TomsMoComp
$ make
ee-vectorize -msse -mfpmath=sse -fomit-frame-pointer -MMD -o TomsMoComp.o TomsMo
Comp.cpp
make: *** [TomsMoComp.o] Error 1
Filters/TomsMoComp
$ cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/verinc"
jeremy@jeremy-A0DCBD577E3 /c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/verinc
$ make
ee-vectorize -fomit-frame-pointer -MMD -o verinc.o verinc.cpp
make: *** [verinc.o] Error 1
edit,
here is the full list of dlls I tried to make but couldn't. this code was run in msys
cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/ffSpkCfg"
cd "/c/Documents and Settings/jeremy/Desktop/ffdshow-tryout/src/imgFilters/TomsMoComp"
Once I go to each directory I then type Make and press Enter. This is how I made those other dll's in msys, but these ones I added in this edit won't work.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Jeremy Duncan is offline   Reply With Quote
Old 9th January 2010, 23:24   #10169  |  Link
tal.aloni
DXVA 1.0 will start working starting from rev. 3194
tal.aloni is offline   Reply With Quote
Old 9th January 2010, 23:30   #10170  |  Link
SamuriHL
SamuriHL's Avatar
Don't have spaces in the path for your build environment.
Old 9th January 2010, 23:48   #10171  |  Link
Jeremy Duncan
Didée Fan
I added the code I use in my prevous post. May I ask you to look at it and post the correct code I should use?
Old 9th January 2010, 23:51   #10172  |  Link
SamuriHL
SamuriHL's Avatar
I wouldn't have the first clue on those errors. I just remember when I was setting up ffdshow to compile there was a warning not to have spaces in the build path. I ended up moving the project to my main C drive. I haven't built any of the ffmpeg stuff as I don't have mingw set up on my machine right now. But, I would start by moving it to somewhere where there's no spaces in the path for starters.
Old 9th January 2010, 23:55   #10173  |  Link
whurlston
Add the GCC bin folder to your PATH if you haven't already. And move the project the "C:\ffdshow-tryout" so there is no space in the project path as SHL mentioned.
whurlston is offline   Reply With Quote
Old 10th January 2010, 00:10   #10174  |  Link
Jeremy Duncan
Didée Fan
I put the project folder in the c:\ as directed and in system, advanced, environment variables, system variables, this is my path:
C:\Program Files\Intel\Compiler\11.1\054\tbb\ia32\vc9\bin;C:\Program Files\Intel\Compiler\11.1\054\ipp\ia32\bin;%ICPP_COMPILER11%lib\ia32;C:\Program Files\Intel\Compiler\11.1\054\mkl\ia32\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Intel\DMIX;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\TortoiseSVN\bin;C:\MinGW32\bin;C:\MinGW32\MSYS\bin
here is a picture of my path:
I get this error:
jeremy@jeremy-A0DCBD577E3 ~
$ cd "/c/ffdshow-tryout/src/imgFilters/KernelDeint"
jeremy@jeremy-A0DCBD577E3 /c/ffdshow-tryout/src/imgFilters/KernelDeint
$ make
_kernelDeint.cpp
Old 10th January 2010, 00:10   #10175  |  Link
VipZ
Thanks DXVA working for me now, I get corruption on seeking sometimes though.
VipZ is offline   Reply With Quote
Old 10th January 2010, 00:13   #10176  |  Link
SamuriHL
SamuriHL's Avatar
It doesn't appear to be finding gcc.exe. I'm not sure why this would be the case.
Old 10th January 2010, 00:39   #10177  |  Link
whurlston
Are you sure your project path is correct and doesn't have the trunk folder?
/c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint
If it's correct, I'm not sure what the issue is.
Old 10th January 2010, 01:03   #10178  |  Link
deets
would it help if i uploaded a 50mb unprocessed TS clip of BBC HD in the hope it could be made to work?
Old 10th January 2010, 01:44   #10179  |  Link
Jeremy Duncan
Didée Fan
It doesn't have the trunk folder. Here is what I did to get the ffdshow package downloaded to my hard drive.
step 1. i installed tortoise svn, as the ffdshow wiki linked to.
step 2. I opened windows explorer, file, svn checkout.
step 3. I used this url: https://ffdshow-tryout.svn.sourcefor...w-tryout/trunk
Fully recursive.
Revison, showlog, I checked the newest build.
I press ok and it downloads the files to my hard drive.
Edit,
I deleted the previous ffdshow files I downloaded and redownloaded it. This time I downloaded both the trunk and branches, and the directory used trunk this time and it still had a error.
I tried both cmd and msys, and beta 1 kerneldeint, and the newest trunk kerneldeint.
here is the error I get:
$ cd cd "/c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint"
sh: cd: cd: No such file or directory
$ cd "/c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint"
jeremy@jeremy-A0DCBD577E3 /c/ffdshow-tryout/trunk/src/imgFilters/KernelDeint
$ make
_kernelDeint.cpp
$ cd "/c/ffdshow-tryout/branches/beta1/src/imgFilters/KernelDeint"
jeremy@jeremy-A0DCBD577E3 /c/ffdshow-tryout/branches/beta1/src/imgFilters/KernelDeint
$ make
gcc -c -I. -I../.. -mno-cygwin -mdll -mthreads -pipe -mmmx -msse -mfpmath=sse -D
NDEBUG -UDEBUG -DWIN32 -D_WIN32 -fno-rtti -fno-exceptions -O2 -march=pentium-mmx
 -mtune=i686 -fomit-frame-pointer -finline-functions -finline -frename-registers
 -fweb -funit-at-a-time -MMD -o ff_kernelDeint.o ff_kernelDeint.cpp
Old 10th January 2010, 02:57   #10180  |  Link
roytam1
Firefox User
ffdshow DXVA in XP looks strange:
comparing with MPC-HC's:
and when I use ffdshow DXVA in DVBViewer for watching HDTV, ffdshow DXVA crashes.
roytam1 is offline   Reply With Quote
