Old 17th October 2009, 14:53   #8721  |  Link
albain
Media Control author
Ooops ! My fault, I uploaded the release instead of debug (and different) version
...This is so slowwww... (75%)
EDIT : done
albain is offline   Reply With Quote
Old 17th October 2009, 14:55   #8722  |  Link
SamuriHL
SamuriHL's Avatar
Ok, when the new release is up I'll take a look. I'm in the middle of a different test right now and will take me about 10 minutes to get back to that configuration when I'm done.
Old 17th October 2009, 15:01   #8723  |  Link
SamuriHL
SamuriHL's Avatar
My test was to check the latest realtek driver. It is not suitable for bitstreaming with ffdshow. This totally blows because in order to properly use my TMT2/bit perfect audio support/ReClock, I need the realtek driver so I can set it to 32 bit when using WASAPI excl mode. Just shoot me.
Old 17th October 2009, 15:07   #8724  |  Link
SamuriHL
SamuriHL's Avatar
http://pastebin.com/pastebin.php?dl=d6069fe54
Receiver did nothing again, but, at least I could connect it in my graph now.
Old 17th October 2009, 15:18   #8725  |  Link
mrcorbo
Same results as Beta 24. No sound, no bitstream detection by receiver and GraphStudio hang on attempting to stop playback.
http://pastebin.com/m47b04793
mrcorbo is offline   Reply With Quote
Old 17th October 2009, 15:18   #8726  |  Link
albain
I fixed a bug this should be better now
Renderer link
Old 17th October 2009, 15:23   #8727  |  Link
SamuriHL
SamuriHL's Avatar
I can't open that file. It's corrupt.
Old 17th October 2009, 15:29   #8728  |  Link
albain
Sorry, I reuploaded it
10kb/sec and connections drops
Old 17th October 2009, 15:31   #8729  |  Link
SamuriHL
SamuriHL's Avatar
No longer hangs GraphStudio, but, still no change on the receiver side. It doesn't even notice that we're sending anything to it.
http://pastebin.com/pastebin.php?dl=d751605e2
Old 17th October 2009, 15:40   #8730  |  Link
albain
And with this one ? (same link)
Old 17th October 2009, 15:43   #8731  |  Link
SamuriHL
SamuriHL's Avatar
The same.
http://pastebin.com/pastebin.php?dl=d2b7c07ff
Old 17th October 2009, 15:45   #8732  |  Link
mrcorbo
No longer hangs, otherwise unchanged.
http://pastebin.com/m7e7499b2
Old 17th October 2009, 15:48   #8733  |  Link
mrcorbo
TrueHD crashes GraphStudio now, though.
http://pastebin.com/d342ce7ea
Old 17th October 2009, 15:48   #8734  |  Link
SamuriHL
SamuriHL's Avatar
It didn't crash graphstudio for me. It just didn't do anything at all, really.
Old 17th October 2009, 15:55   #8735  |  Link
mrcorbo
Actually, even decoded PCM audio crashes graphstudio with this version of the renderer so it could be that mine is attempting to fall back to decoded audio after the format is refused and yours is not (since the format is accepted).
http://pastebin.com/d40a9a8d6
Old 17th October 2009, 15:56   #8736  |  Link
SamuriHL
SamuriHL's Avatar
That's possible I suppose. I honestly don't know.
Old 17th October 2009, 17:02   #8737  |  Link
albain
OK I found a big bug which explains all the regressions
Here is the new build
@mrcorbo : unlike SamuriHl, your audio driver refuse the truehd media type
Old 17th October 2009, 17:04   #8738  |  Link
SamuriHL
SamuriHL's Avatar
I'm watching a movie with my son right now but as soon as it's over in a couple hours I'll try it and get back to you with logs.
Old 17th October 2009, 17:10   #8739  |  Link
albain
No problem take your time with your family
Old 17th October 2009, 17:12   #8740  |  Link
SamuriHL
SamuriHL's Avatar
Well, we just lost power so I guess I can try it out real quick. sigh.
