Old 15th October 2006, 18:01   #21  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
lol sounds to me like the hosting provider needs a swift kick to danuts
ChronoCross is offline   Reply With Quote
Old 15th October 2006, 18:52   #22  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
No files huh? Shucks. Well thanks for letting me/us know Sharktooth.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 16th October 2006, 12:39   #23  |  Link
kharan5876
I've used all the files that were posted. When I try to rip subtitles using MeGUI it complains that there is no vobsub.dll in my system 32 directory. Does anyone have this file?
kharan5876 is offline   Reply With Quote
Old 16th October 2006, 12:46   #24  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
ahh, forgot about that one too. You need vsfilter - the latest version is 2.37, from here: http://www.free-codecs.com/download/DirectVobSub.htm
Don't extract to your system32 directory (that's evil), stick it into your avisynth plugins directory.
check is offline   Reply With Quote
Old 16th October 2006, 14:33   #25  |  Link
kharan5876
Thanks again!
Old 16th October 2006, 22:24   #26  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
I've uploaded all of check's files to the server, but I'm not sure they're in the correct directory structure. Sharktooth should be able to fix it from there.
Richard Berg is offline   Reply With Quote
Old 17th October 2006, 05:49   #27  |  Link
Adub
Adub's Avatar
Great! Thanks mate!
Site:Adubvideo
Old 17th October 2006, 11:07   #28  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
thanks
Old 17th October 2006, 12:01   #29  |  Link
netsnake
thanks~!~
netsnake is offline   Reply With Quote
Old 17th October 2006, 12:25   #30  |  Link
shadowchen
Master inferno+
shadowchen's Avatar
thanks!
shadowchen is offline   Reply With Quote
Old 17th October 2006, 13:53   #31  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm... well... the auto-update structure was completely different.
All "packages" were a separate zip file... so it seems i must re-upload everything.
There's a problem though... im switching ISP so it will take some time until i get a decent DSL connection and you know how slow is a 56k modem...
Uploading about 50 megs is a pain in the...
Old 18th October 2006, 04:24   #32  |  Link
Richard Berg
developer wannabe
Sharktooth or someone else, PM me the correct file/folder structure and I will fix it.
Old 18th October 2006, 05:10   #33  |  Link
kharan5876
I installed vsfilter and it still says there is a missing vobsub.dll
The vsfilter package only installed VSfilter.dll
Old 18th October 2006, 23:11   #34  |  Link
Chainmax
Huh?
Chainmax's Avatar
Thanks Richard .
[edit]By the way, Sharktooth, while we're at it, do you think it would be possible to add AutoGK's ESS-based standalones and MTK/Sigma based standalones Xvid standalone compatibility options?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 19th October 2006, 06:11   #35  |  Link
Richard Berg
developer wannabe
Should work now...
Old 19th October 2006, 08:26   #36  |  Link
shadowchen
Master inferno+
shadowchen's Avatar
Thanks Richard
Old 19th October 2006, 08:46   #37  |  Link
Thunderbolt8
still does not, it doesnt give an error at least, but keeps saying that there are 0 files to be available for update and since x264 r578-1 is my version there, but sharktooth has 593cli already there must be something wrong i guess.
Old 19th October 2006, 12:38   #38  |  Link
shadowchen
Master inferno+
shadowchen's Avatar
Error: neroaacenc could not be found on the server
Old 19th October 2006, 12:45   #39  |  Link
buzzqw
HDConvertToX author
megui use xvid encraw... i think that in Teegedeck profiles should add profiles for SAP compatibility
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 19th October 2006, 13:03   #40  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
http://mewiki.project357.com/wiki/Me...oad_neroaacenc
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
