Thread Tools Display Modes
Old 29th September 2006, 03:40   #321  |  Link
pjay
Thanks mayang, I thought it was the wrong keys on those files. Because sometimes different keys will come up for files I tried to undrm before with the first keys, but with no luck, then I try the second keys and they work.
pjay is offline
Old 29th September 2006, 04:33   #322  |  Link
Sx66gns
Sx66gns's Avatar
thanks folks
/Salute.
Sx66gns is offline
Old 29th September 2006, 06:49   #323  |  Link
Pulp Catalyst
just wanted to say really, you may already do this, but hey just in case, as microsoft are obviously reverse engineering you program to no end, you should make it more harder for them, and encrypt your executable as much as possible, i.e. Armadillo, as this would make it very hard for them, and help protect your code from prying eye's, as your finding holes in there software, but by looking at your code, will help feel there holes,
just thought it would be great if you could make there task forever difficult of reverse engineering your fine work,
armadillo is good, but you need to knit the protection as much as possible in your source code, and create 1000's of jmp calls,
but of course you maybe doing this already, and if you are, then don't listen to me,
p.s. not sure if armadillo is the best, but if used wisely can be very powerful, but of course this logic works the opposite to,
Pulp Catalyst is offline
Old 29th September 2006, 06:54   #324  |  Link
Pulp Catalyst
1 more thing, untill the lawsuit blows over, it may be a good idea to upload the file from a public terminal, cybercafe for example, as i.p. tracing will start, and changing the name of the file may help aswell, sorry to go on, but i'm sure everyone here agrees that extra methods to keep you safe should be deployed,
also go to different terminals aswell (different terminal sites), this will in effect spoof your i.p., can't trace a i.p. if it's always different, this is all great what your doing, but it's more paramount to protect your self, then to risk getting caught, great work has been achieve from great people in history because they never got caught,
i know i know, i'll shut up now....just worried about you that's all, after all they caught up with DVD jon in the end, he was lucky, but you may not be so lucky, just protect your self, and leave no traces,
maybe a good idea to encrypt your hard drive or at the very least all references to the source code with AES encryption with 50 no make that 80 character long (a famous passage, or a sequence for password, but just keep doubling it up so it becomes 80 characters long)
i heard that drive crypt is suppose to be good, but the thing about commercial software is you never know if there is a backdoor, go with 7zip with AES 256bit key.
i hear you....i'll shut up now.
Old 29th September 2006, 10:17   #325  |  Link
ross_MoHaX
Hi! Is there any detailed description how MS-DRM v.2 work and what vulnerability was used to remove DRM protection?
ross_MoHaX is offline
Old 29th September 2006, 12:51   #326  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
the "ultimate" distribution method: http://freenet.sf.net
Sharktooth is offline
Old 29th September 2006, 13:58   #327  |  Link
CruNcher
CruNcher's Avatar
Originally Posted by protectyoursources View Post
Microsoft must have signed up to Doom 9
There were allready Microsoft Employers from the Media Division registered here on Doom9, before Fairuse4WM has been posted here.
current Main XviD PSNRLab version 1.1
current XviD PSNRLab update 1.1.3
MT1389xx Player Infos
XviD EDP Build CVS (CruNchers Visual System ©) V 1.4 new with predefined profiles ;)
Olivera: "We're expendable assets"
         "and we've just been expended"
"It's not a trick it's a Sony Rootkit" pwnz :devil: :angry: :rolleyes:
CruNcher is offline
Old 29th September 2006, 14:47   #328  |  Link
rjamorim
Blah!
My arse. Using freenet is a huge pain. I'd rather use Tor or bittorrent or eMule (the latter ones are not as anonymous, but "anonymous enough").
Get latest LAME, Vorbis and more binaries at RareWares:
http://www.rarewares.org
rjamorim is offline
Old 29th September 2006, 15:35   #329  |  Link
protectyoursources
The TOR network is sufficent enough to upload FU4WM to mirror sites and if you install the TORpark browser its sets up TOR and Firefox automaticly and dont use your regular email adress if the site requires registration .
http://www.torrify.com/
protectyoursources is offline
Old 29th September 2006, 18:05   #330  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
It's a pain but its completely anonymous...
Old 29th September 2006, 19:58   #331  |  Link
Boost
Power user
Protect the future
Originally Posted by viodentia View Post
FairUse4WM has been my own creation, and has never involved Microsoft source code. I link with Microsoft's static libraries provided with the compiler and various platform SDK files.
You could ofcause protect the future of FairUse4WM and proove to everybody that that is infact so by releasing the source to the public. Should you go under by Microsoft thugs they have no way of attacking the software as anyone could continue to develop it.
Boost is offline
Old 29th September 2006, 20:17   #332  |  Link
Pulp Catalyst
don't release the source, if you do that and they catch up with you, your arse will be fried, and not only that, MS would love to look at your source file, if any think i think you should protect your source like i said before, if you know that you have not used there source code of any kind, well then you have nothing to prove.
innocent until proven guilty mate, the ball is in there court (so to speak),
let them show there hand first, and keep your self hidden, unless of course your a billionair and can stand up to them through the system, if not, then like old school, be invisible,
Old 29th September 2006, 20:47   #333  |  Link
Rrrough
Rrrough's Avatar
For those who don't know:
http://www.theregister.co.uk/2000/06...l_gates_roots/
This is why M$ thinks viodentia must have used their sourcecode
cheers
Rrrough is offline
Old 29th September 2006, 21:21   #334  |  Link
rjamorim
Blah!
Dude, Microsoft doesn't need the source file. They surely have enough resources to support a reverse engineering effort. Sources would only make their job slightly easier.
It's not about proving anything, it's about avoiding that FU4WM has the same sad fate as DVDDecrypter.
That won't help him when he is dragged to court and is forced to start shelling out big bucks for lawyers and court procedures and the like.
rjamorim is offline
Old 29th September 2006, 21:43   #335  |  Link
Boost
Power user
Exactly my point
Boost is offline
Old 30th September 2006, 00:53   #336  |  Link
blutach
Country Member
blutach's Avatar
Let us hope that viodentia has protected himself and leave him to make his own decision regarding his code. He is clearly no fool.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline
Old 30th September 2006, 01:13   #337  |  Link
LANjackal
A.I. hosted by human body
Does anyone have any idea how to deal with the truncation issue? It appears like this in my case:
K:\My Music\Quicksand\Slip\Quicksand_Slip_Fazer_160kbps.WMA UNABLE TO DECRYPT: Size Error: 9957960910 cannot be truncated to 1368026318.
The question has been asked by several other users, but no definitive answer has been forthcoming. Thanks.
LANjackal is offline
Old 30th September 2006, 02:44   #338  |  Link
protectyoursources
I got the truncation error when one of the partitions on my hard drive was full.
Old 30th September 2006, 03:21   #339  |  Link
LANjackal
Thanks, but I have plenty of space on this end so that's not it.
Old 30th September 2006, 09:43   #340  |  Link
vice101
so i finally was able to converted some of the files but there are still some left that gave me error messages
UNABLE TO DECRYPT: Unsupported Error correction (ad) at packet offset 0.
UNABLE TO DECRYPT: Packet truncated, 60085 needed, 220 remains, at offset 24
UNABLE TO DECRYPT: Packet truncated, 32302 needed, 138 remains, at offset 19
these are the errors i've got. can anyone fix it ??
ps thanks for the program tho
vice101 is offline
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
