#1321 | Link | |
Is the Coding Tech AAC coder OK to use, never heard of it before? Or should I really be using the Nero? |
#1322 | Link |
HDConvertToX author
there are two way of changing the profiles !
first, open the file into \profiles\x264-profiles\zxcvb.xml and edit it with notepad second (and recommed) on advanced profiles editing modify the profile AND (after editing) check USE this Profile in this way automkv will use this EDITED profile about coding tech is better to use Nero (support 5.1ch!) mini how-to load the input file select audio/container/codec/resize/width.... change the profile to crf answer Go Unlimited on advanced profile editing change bitratequantitizer from 18 to 20 check use this profile click start BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
#1324 | Link |
HDConvertToX author
remember that in full package there are even the profiles, so all change you have made will be lost on upgrade!
also, even if you don't copy the \profiles folder remember that some update needs the new profiles (like new muxing mode for xvid) BHH
#1325 | Link | |
Cranky old newbie
WMV AVS encoding -- not fixed in 78b
Again I tried all combinations of the 2 direct show check boxes (could you tell me what settings I should be using for these? ![]() Depending on these checkbox settings I get two movie.avs versions. One has: Code:
movie = directshowsource("C:\videos\MyVideo.avs",audio=false) movie = isRGB(movie) ? ConvertToYV12(movie,interlaced=true) : movie movie = isYUY2(movie) ? ConvertToYV12(movie,interlaced=true) : movie audio = DirectShowSource("C:\videos\MyVideo.avs",fps=30.000299,convertfps = true,video=false) The other version of movie.avs has just one line: Code:
Import("C:\videos\MyVideo.avs") After I select MyVideo.avs as the input file, a file browser comes up asking for an audio file. That is where I select MyAudio.avs. Is this correct? I don't see any other way to input the audio AVS file. This audio AVS then shows in the Audio Track 1 source window. Thanks |
#1326 | Link |
HDConvertToX author
just a little information...
i added the possibility to load avs as audio file... i never said that was supported in wmv.... (as you know wmv has a very different type of avs script since it must include even audio) you could input this as video AND no select audio input AND don't check any directshow usage Code:
LoadPlugin("DGDecode.dll") global movie = directshowsource("1173967360__aaa.mkv",audio=false) global audio = directshowsource("1173967360__aaa.mkv",video=false) audiodub(movie,audio)
#1327 | Link | |
Cranky old newbie
In your example, why is the DGDecode plugin needed? (Sorry if that is a newbie question.) I reported a similar (not identical) case in an earlier post (see #3). I had to check both directshow boxes for it to encode properly. I did not load the DGDecode plugin and I didn't define clips movie and audio as global. Are the plugin and/or the global variables needed so the direct show boxes don't need to be checked? Is it possible to state simple logic that determines whether the directShow boxes should be checked? Thanks for your patience. |
#1329 | Link | |
Playing with MKV files...
#1330 | Link | |||||
HDConvertToX author
@dlflannery
no, there is NO NEED to load dgdecode... i have simply edited a previus script... and havn't trim the load plugin. My mistake ![]() Quote:
When i use GLOBAL i force avisynth to remember what is audio and what is video Quote:
maybe due to not correct dgdecode handling, or you want to use a preprocessing filter using ffdshow, corrupted audio or video.... Quote:
BHH
#1331 | Link |
Emperor building empire
What are the rules for cropping & downsizing ?
I'm encoding the extras of Band of Brothers which always have tons of black space.
I used Dr DivX to preview and test the autocrop facility... which gave a preference for 6-Left & 4-Right... and the encode worked fine. I thought 9-Left and 7-Right looked better (also a multiple of 16) and my encode crashed after doing the 'de-interlace check'... what gives ? I downsized the main episodes to 720x400 but this extra I'm taking downto 640x368 (1024x576 Orig)... IF I choose the 640 width option (drop down menu)... does it automatically crop and then downsize ? ![]() @weaver4 Nice to see your quantizer encoding is coming together... you've always been into very much better quality encoding allbeit at low-res where most guys want to compress 10 movies onto 1 DVD at really poor quality levels. ![]() ![]() ![]() Pascal |
#1332 | Link | ||
HDConvertToX author
could you post the log ? BHH
#1333 | Link | |
20:52:56 0.78 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 20:52:56 Selected Input file: H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\The Men of Easy Company.VOB 20:52:56 Selected Output dir: H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\ 20:52:56 Selected Final Name: The Men of Easy Company 20:52:56 Selected Container type: MKV 20:52:56 Selected Encoder: X264 20:52:56 Selected Size: Don't care about size 20:52:56 Selected Slice: 1 20:52:56 Selected Profile: ConstantQuality-CRF.xml 20:52:56 Selected Width: 640 20:52:56 Selected Resizer: Lanczos4Resize 20:52:56 Selected Filters: RemoveGrain(mode=2) 20:52:56 Selected Deinterlacer: AUTO 20:52:56 Selected Field Order: AUTO 20:52:56 Manual Crop: Enabled 20:52:56 Left Crop: 9 20:52:56 Top Crop: 0 20:52:56 Right Crop: 7 20:52:56 Botton Crop: 0 20:52:56 Manual Width: 640 20:52:56 Manual Height: 368 20:52:56 Enabled CRF/CQ AutoRes at 18 value 20:52:56 Track Language 1: NONE 20:52:56 Audio Codec 1: Nero AAC 20:52:56 Audio Quality 1: 0.25 20:52:56 Audio Channel 1: Stereo 20:52:56 Advanced Audio Settings DUMP Track 1 20:52:56 Nero Option Profiles: AUTO --- Encoding Mode: Quality 20:52:56 CCT Option Profiles: AUTO --- Channel Options: AUTO 20:52:56 Lame Settings: ABR 20:52:56 Audio Normalization: 1 20:52:56 Frequency: AUTO --- Tempo : NONE 20:52:56 Pitch: NONE --- Other Add : 20:52:56 Advanced Audio Settings DUMP Track 2 20:52:56 Nero Option Profiles: AUTO --- Encoding Mode: Quality 20:52:56 CCT Option Profiles: AUTO --- Channel Options: AUTO 20:52:56 Lame Settings: ABR 20:52:56 Audio Normalization: 1 20:52:56 Frequency: AUTO --- Tempo : NONE 20:52:56 Pitch: NONE --- Other Add : 20:52:56 20:52:56 Dgindex CMD: F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\dgindex\dgindex.exe -FO=0 -OM=0 -YR=2 -If=[H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\The Men of Easy Company.VOB] -OF=[H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\movie] -exit -minimize 20:56:30 Starting fixing audio delay on track number 0 20:56:30 Finished fixing audio delay 20:56:37 Number of Frames: 116365 20:56:37 Framerate: 25.000000 20:56:37 Movie lenght in Seconds: 4655 20:56:37 Movie Width: 720 20:56:37 Movie Height: 576 21:01:36 Processing completed. Type is determined to be partly interlaced. 21:01:36 Processing completed. Type is determined to be partly interlaced. 21:01:36 BFF: 50 21:01:36 TFF: 333 21:01:36 Order: var 21:01:36 Starting X264 21:01:36 CRF encoding X264: F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\encoder\x264.exe --pass 1 --crf 24 --stats "H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 3 --filter -2,-1 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads 3 --output "H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\movie.mp4" "H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\movie.avs" 21:01:39 Accepted values are between 31876710400 and 33889976320 bytes (movie+audio) 21:01:39 Got a file of size: 0 bytes + audio size -2 bytes (-2) 21:01:39 "F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\matroska\mkvmerge.exe" -o "H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\The Men of Easy Company.mkv" --track-name -1:"The Men of Easy Company" --aspect-ratio 1:1.777778 "H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\movie.mp4" --title "Done with AutoMKV 0.78 http://forum.doom9.org/showthread.php?p=854221 " 21:01:39 Final Muxed size: -1 bytes 21:01:39 Encoding finished: 00:08:43 elapsed time 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script AutoCrop.log 21:01:40 21:01:40 Crop(10,0,700,576) 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script Resmovie.avs 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script movie.avs 21:01:40 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\autocrop.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\BicublinResize.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\blockbuster.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\cnr2.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\ColorMatrix.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\Convolution3D.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\corrector.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\DctFilter.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\Decomb.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\Deen.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\degrainmedian.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\DGDecode.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\EEDI2.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\fft3dfilter.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\FluxSmooth.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\frfun7.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\hqdn3d.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\LeakKernelDeint.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\MaskTools.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\medianblur.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\MipSmooth.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\mt_masktools.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\mvtools.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\NicAudio.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\RemoveGrain.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\Repair.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\SangNom.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\SimpleResize.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\SoundOut.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\TBilateral.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\TDeint.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\TIVTC.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\TomsMoComp.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\TTempSmooth.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\UnDot.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\UnFilter.dll") 21:01:40 LoadPlugin("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\VSFilter.dll") 21:01:40 #loadpluginstart 21:01:40 21:01:40 #test1 21:01:40 21:01:40 Import("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\MCBob_v03c.avsi") 21:01:40 Import("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\mvbob.avsi") 21:01:40 Import("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\seesaw.avsi") 21:01:40 Import("F:\Movies\_DIVX Program Files\Associate Progs\AutoMKV078_NORIP\exe\filter\spresso.avsi") 21:01:40 #importstart 21:01:40 21:01:40 #test2 21:01:40 21:01:40 movie = mpeg2source("H:\Movies\To Be Encoded\Band of Brothers\Extras\Extras 01 - The Men of Easy Company\temp\movie.d2v") 21:01:40 function getOrder(clip c) { 21:01:40 order = GetParity(c) ? 1 : 0 21:01:40 Return order } 21:01:40 #filter1start 21:01:40 21:01:40 #test3 21:01:40 21:01:40 last = movie 21:01:40 TDeint(full=false) 21:01:40 crop(movie,9,0,-7,-0) 21:01:40 #resizestart 21:01:40 21:01:40 #test4 21:01:40 21:01:40 Lanczos4Resize(640,368) 21:01:40 #filter2start 21:01:40 21:01:40 #test5 21:01:40 21:01:40 RemoveGrain(mode=2) 21:01:40 ColorMatrix("Rec.709->Rec.601",hints=false,threads=3) 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script mkvmaudio.avs 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script mkvmaudio.bat 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script mkvmaudio2.avs 21:01:40 ----------------------------------------------------------------------- 21:01:40 Script mkvmaudio2.bat 21:01:40 21:01:40 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - ![]() ![]() ![]() Pascal |
#1334 | Link |
Automkv .78 suggestions after a bit of use:
1) Windows Media Encoder has failed to find the length on 3 out of 3 movies so far, even via the alternate method it tries. 2) I can't type a path in the "Select output folder" ? I like to throw these movies I encode into temp files, where ever. 3) I don't want a nero encoder popup everytime I start AutoMKV. Put a check box on the message window saying "Do not show on startup", or "do not show again". 4) When using a queue, what is the difference between the "Start Encoding" and the "Start Queue" button? 5) If the main drop-down for "Audio Track 2" is set to none, why not disable the remaining controls in that group (i.e containter drop down, channel drop down, slider) Same thing can apply to any control group where the main control essentially negates the others. 6) After I start an encode, and then I go back to AutoMKV and look at my settings (maybe adjust something to see what it does), do NOT change the Encoding status based on what I just looked at. It's confusing. ![]() thanks Buzzqw. Last edited by Shark_jlc; 16th March 2007 at 04:04. |
#1335 | Link |
Cranky old newbie
@buzzqw
I've been able to get H264 encodings (MKV or MP4 containers) using separate video-only and audio-only AVS input files. As we already discussed, I now know that this will not work with wmv encodings.
How aboue XVID/AVI ? I haven't been able to get it to work. I can't get AVS inputs to work at all for audio input with XVID, including also: 1. inputing a video+audio AVS as the video file and nothing as an audio file and selecting "all audio tracks" 2. inputing this same AVS as both the video file and the track 1 audio file. I get encodings with no audio. Is there any way to get audio from an AVS input into an AVI/XVID encoding? |
#1336 | Link | |||||||
HDConvertToX author
@delacroixp
you can't crop by odd number , change crop(movie,9,0,-7,-0) to crop(movie,10,0,-8,-0) @Shark_jlc Quote:
@dlflannery i will do some test, but the workflow should be the same... BHH
#1337 | Link |
HDConvertToX author
update
http://www.64k.it/andres/data/a/AutoMKV078c.exe 0.78c FIXED: AACgain doesn't work proprely on AAC/MP4 done by Coding Tech. AAC, apply an AmplifydB(7) to audio script FIXED: Some bugs on AVS input (thanks to dlflannery) @dlflannery use avs like this for video Code:
LoadPlugin("DGDecode.dll") mpeg2source("movie.d2v") for audio Code:
LoadPlugin("NicAudio.dll") NicAC3Source("audio.ac3") BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 16th March 2007 at 11:01. |
#1338 | Link | |||
Batch GUInterface
@buzzqw
#1339 | Link | |
![]() I've got a request: I'm using Lame for audio on this encode, and after the normalize ran I was warned that applying +2 gain may cause audio clipping, but I wasn't aware it was going to ask for my confirmation and only saw it because I got back on the machine to check my email. Can we get a timeout added so if no user input a choice is automatically selected? That way the rest of the job is not held up by the question of whether to add gain or not on audio. I realize this is probably someone else's project doing this and not AutoMKV itself. |
