Old 24th December 2006, 15:15   #561  |  Link
ehushagen
What are people's experiences with using dvr-ms files? I tried loading one this morning, and it just made BAutoDeint hang at 18% although the hard drive was still crunching away on it.
ehushagen is offline
Old 24th December 2006, 15:45   #562  |  Link
weaver4
Originally Posted by SeeMoreDigital View Post
What playback method did you use to determine this... A software or hardware media player
SMD: DivX player and Media Player Classic
weaver4 is offline
Old 24th December 2006, 19:38   #563  |  Link
lolo_htpc
Thanks for this excellent GUI.
After many tests, I could not manage to get autoMKV to autocrop without using the resize function.
I am using the fixed bitrate option for all my encoding. I have the impression that it works with fixed file size but not with specified bitrate.
Thanks,
lolo_htpc is offline
Old 24th December 2006, 20:11   #564  |  Link
buzzqw
HDConvertToX author
just set width to full width... usually 720... anyway with next update will be possible to select in width list "AutoCrop Only"
about bitrate problem: could you please post a log ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 24th December 2006, 20:17   #565  |  Link
buzzqw
HDConvertToX author
@ehushagen
once you know how to deinterlace it you can apply in deinterlacer text box the deinterlacer used string
BHH
EDIT: here the Xmas Edition www.64k.it/andres/data/a/AutoMKV063h.exe
changelog
0.63h XMas Edition
FIXED: Mispelled "espisodic dvd" (thanks to ottar)
FIXED: Unknow language ???, would be translated to "und" (thanks to ottar)
ADDED: Added "AutoCrop Only" to width list (thanks to lolo_htpc)
buzzqw is offline
Old 25th December 2006, 04:39   #566  |  Link
AMED
AMED's Avatar
Hi buzzqw,
I'm trying to convert POTC dead mans chest and it keeps failing at the compression test.
15:15:48 0.63h XMas Edititon  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
15:15:48 Selected Input file:     D:\DEAD_MANS_CHEST1\VIDEO_TS\VTS_01_0.IFO
15:15:48 Selected Output dir:     D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\
15:15:48 Selected Container type: MKV
15:15:48 Selected Encoder:        X264
15:15:48 Selected Size:           1/3 DVD-R
15:15:48 Selected Slice:          1
15:15:48 Selected Profile:        HQ-Insane.xml
15:15:48 Selected Width:          Automatic
15:15:48 Selected Resizer:        LanczosResize
15:15:48 Selected Filters:        Undot()
15:15:48 Selected Deinterlacer:   AUTO
15:15:48 NeroAACEnc.exe not present
15:15:48 Enabled CRF/CQ autoresize with value 18
15:15:48 Track Language 1:        English (AC3 6ch, 0xBD 0x80) [0]
15:15:48 Audio Codec 1:           Copy Original
15:15:48 Audio Quality 1:         0.35
15:15:48
15:15:48 Starting Indexing
15:15:48 Dgindex CMD: J:\Video\AutoMKV063\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[D:\DEAD_MANS_CHEST1\VIDEO_TS\VTS_01_1.vob] -OF=[D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie] -exit -minimize
15:18:18 Finished indexing
15:18:18 Starting fixing audio delay on track number 1
15:18:18 DelayCut CMD: J:\Video\AutoMKV063\exe\dgindex\Delaycut.exe -auto -out "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\fixed1.ac3" "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie T01 3_2ch 448Kbps DELAY 0ms.ac3"
15:18:41 Original 1' Audio Size:  485549568 bytes
15:18:42 Finished fixing audio delay
15:18:42 Renamed file fixed1.ac3 to audio.ac3
15:18:42 Encoded 1' Audio Track:  485549568 bytes
15:18:45 Number of Frames:        216821
15:18:45 Framerate:               25.000000
15:18:45 Movie lenght in Seconds: 8673
15:18:45 Movie Width:             720
15:18:45 Movie Height:            576
15:24:51 Processing completed. Type is determined to be interlaced.
15:24:51 BFF:                     845
15:24:51 TFF:                     7
15:24:51 Order:                   bff.
15:24:51 Starting X264 AutoResize with WIDTH of Automatic and wanted size of 1537212416 bytes
15:24:51 CRF encoding X264:       J:\Video\AutoMKV063\exe\encoder\x264.exe --pass 1 --crf 18 --stats "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --no-fast-pskip --mixed-refs --trellis 2 --ref 16 --filter -2,-1 --subme 6 --direct auto --vbv-maxrate 25000 --me umh --weightb --b-pyramid --b-rdo --bime --analyse  p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads 3  --output "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\resmovie.mp4" "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\resmovie.avs"
15:24:54 Tested total movie:      5%
15:24:54 AutoResize movie size:   0 bytes
15:24:54 Movie Width suggested based on sample size: 0
15:24:54 Warning !!! - Too low resolution. Set witdh to 240
15:24:54 Starting  X264
15:24:54 Command Line 1' Pass X264: J:\Video\AutoMKV063\exe\encoder\x264.exe --pass 1 --bitrate 969 --stats "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\.stats" --ref 0 --no-b-adapt --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --no-fast-pskip --mixed-refs --trellis 2 --ref 16 --filter -2,-1 --subme 6 --direct auto --vbv-maxrate 25000 --me umh --weightb --b-pyramid --b-rdo --bime --analyse  p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads 3  --output NUL "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.avs"
15:24:54 Command Line 2' Pass X264: J:\Video\AutoMKV063\exe\encoder\x264.exe --pass 2 --bitrate 969 --stats "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --no-fast-pskip --mixed-refs --trellis 2 --ref 16 --filter -2,-1 --subme 6 --direct auto --vbv-maxrate 25000 --me umh --weightb --b-pyramid --b-rdo --bime --analyse  p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads 3  --output "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.mp4" "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.avs"
15:25:00 J:\Video\AutoMKV063\exe\matroska\mkvmerge.exe -o "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.mkv" --aspect-ratio 1:2.415094 --chapters "J:\Video\AutoMKV063\exe\chapters.txt" "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.mp4" --language 0:eng "D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\audio.ac3"
15:25:00 Final Muxed size:        -1 bytes
15:25:00 Encoding finished:       00:09:12 elapsed time
15:25:00 -----------------------------------------------------------------------
15:25:00 Script AutoCrop.log
15:25:00
15:25:00 Crop(6,78,708,424)
15:25:00 Script Resmovie.avs
15:25:00
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\autocrop.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\blockbuster.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\cnr2.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\ColorMatrix.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Convolution3D.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\corrector.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\DctFilter.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Decomb.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Deen.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\degrainmedian.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\DGDecode.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\EEDI2.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\fft3dfilter.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\FluxSmooth.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\frfun7.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\hqdn3d.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\LeakKernelDeint.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\MaskTools.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\medianblur.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\MipSmooth.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\mt_masktools.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\mvtools.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\NicAudio.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\RemoveGrain.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Repair.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\SangNom.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\SimpleResize.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TBilateral.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TDeint.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TIVTC.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TomsMoComp.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TTempSmooth.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\UnDot.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\UnFilter.dll")
15:25:00 LoadPlugin("J:\Video\AutoMKV063\exe\filter\VSFilter.dll")
15:25:00 #loadpluginstart
15:25:00
15:25:00 #test1
15:25:00
15:25:00 Import("J:\Video\AutoMKV063\exe\filter\MCBob_v03c.avsi")
15:25:00 Import("J:\Video\AutoMKV063\exe\filter\mvbob.avsi")
15:25:00 Import("J:\Video\AutoMKV063\exe\filter\QMF.avsi")
15:25:00 Import("J:\Video\AutoMKV063\exe\filter\seesaw.avsi")
15:25:00 Import("J:\Video\AutoMKV063\exe\filter\spresso.avsi")
15:25:00 #importstart
15:25:00
15:25:00 #test2
15:25:00
15:25:00 movie = mpeg2source("D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.d2v")
15:25:00 function getOrder(clip c) {
15:25:00 order = GetParity(c) ? 1 : 0
15:25:00 Return order }
15:25:00 #filter1start
15:25:00
15:25:00 #test3
15:25:00
15:25:00 #cropstart
15:25:00
15:25:00 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
15:25:00 fixed_aspect = 1.422222
15:25:00 c_width = width(cropclip)
15:25:00 c_height = Round(height(cropclip) / fixed_aspect)
15:25:00 input_par = float(float(c_width)/float(c_height))
15:25:00 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
15:25:00 out_width = 704
15:25:00 out_height = Round(float(out_width) / input_par)
15:25:00 hmod = out_height - (floor(out_height / 16 ) * 16)
15:25:00 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
15:25:00 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
15:25:00 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
15:25:00
15:25:00 LeakKernelDeint(order=bff.,sharp=true)
15:25:00 #resizestart
15:25:00
15:25:00 #test4
15:25:00
15:25:00 LanczosResize(out_width,out_height)
15:25:00 #filter2start
15:25:00
15:25:00 #test5
15:25:00
15:25:00 Undot()
15:25:00 function Comptest(clip c, float percent)
15:25:00 {
15:25:00 frange=floor(14./(percent/100.))
15:25:00 Return SelectRangeEvery(c, frange, 14)
15:25:00 }
15:25:00 Comptest(5)
15:25:00 ColorMatrix("Rec.709->Rec.601",hints=false)
15:25:00 Script movie.avs
15:25:00
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\cnr2.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\ColorMatrix.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Convolution3D.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\corrector.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\DctFilter.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Decomb.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Deen.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\degrainmedian.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\DGDecode.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\EEDI2.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\fft3dfilter.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\FluxSmooth.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\frfun7.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\hqdn3d.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\LeakKernelDeint.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\MaskTools.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\medianblur.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\MipSmooth.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\mt_masktools.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\mvtools.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\NicAudio.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\RemoveGrain.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\Repair.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\SangNom.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\SimpleResize.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TBilateral.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TDeint.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TIVTC.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TomsMoComp.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\TTempSmooth.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\UnDot.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\UnFilter.dll")
15:25:01 LoadPlugin("J:\Video\AutoMKV063\exe\filter\VSFilter.dll")
15:25:01 #loadpluginstart
15:25:01
15:25:01 #test1
15:25:01
15:25:01 Import("J:\Video\AutoMKV063\exe\filter\MCBob_v03c.avsi")
15:25:01 Import("J:\Video\AutoMKV063\exe\filter\mvbob.avsi")
15:25:01 Import("J:\Video\AutoMKV063\exe\filter\QMF.avsi")
15:25:01 Import("J:\Video\AutoMKV063\exe\filter\seesaw.avsi")
15:25:01 Import("J:\Video\AutoMKV063\exe\filter\spresso.avsi")
15:25:01 #importstart
15:25:01
15:25:01 #test2
15:25:01
15:25:01 movie = mpeg2source("D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\movie.d2v")
15:25:01 function getOrder(clip c) {
15:25:01 order = GetParity(c) ? 1 : 0
15:25:01 Return order }
15:25:01 #filter1start
15:25:01
15:25:01 #test3
15:25:01
15:25:01 #cropstart
15:25:01
15:25:01 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
15:25:01 fixed_aspect = 1.422222
15:25:01 c_width = width(cropclip)
15:25:01 c_height = Round(height(cropclip) / fixed_aspect)
15:25:01 input_par = float(float(c_width)/float(c_height))
15:25:01 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
15:25:01 out_width = 352
15:25:01 out_height = Round(float(out_width) / input_par)
15:25:01 hmod = out_height - (floor(out_height / 16 ) * 16)
15:25:01 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
15:25:01 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
15:25:01 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
15:25:01
15:25:01 LeakKernelDeint(order=bff.,sharp=true)
15:25:01 #resizestart
15:25:01
15:25:01 #test4
15:25:01
15:25:01 LanczosResize(out_width,out_height)
15:25:01 #filter2start
15:25:01
15:25:01 #test5
15:25:01
15:25:01 Undot()
15:25:01 ColorMatrix("Rec.709->Rec.601",hints=false)
15:25:01 -----------------------------------------------------------------------
15:25:01 Script mkvmaudio.avs
15:25:01
15:25:01 NicAC3Source("D:\DEAD_MANS_CHEST1\VIDEO_TS\temp\fixed1.ac3")
15:25:01 EnsureVBRMP3Sync()
15:25:01 ConvertAudioTo16bit()
15:25:01 #Applyed ORIGINAL downmixing routines
15:25:01 Normalize()
15:25:01 Script mkvmaudio.bat
15:25:01
15:25:01 Script mkvmaudio2.avs
15:25:01
15:25:01 Script mkvmaudio2.bat
15:25:01
15:25:01
15:25:01 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
When i try and manually play the Resmovie.avs it gives me this error
Script Error: expected function name following '.'
(D:\dead_mans_chest1\video_TS\temp\Resmovie.avs, line 72, column 27)
it seems that this line is causing the problem,
i have tried to remove the . in the the above line, then the error changes to
i don't know what "bff" means
(D:\dead_mans_chest1\video_TS\temp\Resmovie.avs, line 72)
Is there any chance you could have the compression test added to the simple error checking as you have done with if the audio encoding fails, if AutoResize movie size: = 0, ERROR Message problem with avs.
A Man Eating Duck
AMED is offline
Old 25th December 2006, 08:54   #567  |  Link
buzzqw
HDConvertToX author
@AMED
the problem is fixed www.64k.it/andres/data/a/AutoMKV063i.exe
about error checking avs... it shouldn't needed... but i will think about it
BHH
buzzqw is offline
Old 25th December 2006, 12:41   #568  |  Link
AMED
AMED's Avatar
Thanks for the quick fix, all working well now.
LeakKernelDeint(order=0,sharp=true)
A Man Eating Duck
AMED is offline
Old 25th December 2006, 13:25   #569  |  Link
fogbav
Hi buzzqw ...
Cli seems to be again broken in the new Versions ...
I will try to search for the reason ...
Happy XMAS to all !
fogbav is offline
Old 25th December 2006, 19:03   #570  |  Link
ottar
Converting an episodic DVD to MKV only gets chapters for the first title on the DVD.
Input has three episodes, the first with 14 chapters, and the other two with seven chapters each. Output has the first 14 chapters correct, but no chapters for the rest of the file.
Merry Christmas!
ottar is offline
Old 25th December 2006, 19:03   #571  |  Link
buzzqw
HDConvertToX author
@fogbav got it ! (wrong path)
fixed
www.64k.it/andres/data/a/AutoMKV063j.exe
BHH
buzzqw is offline
Old 25th December 2006, 19:06   #572  |  Link
buzzqw
HDConvertToX author
@ottar
are you encoding all episodes in one file only or several file (one for each episodes) ?
BHH
buzzqw is offline
Old 25th December 2006, 19:09   #573  |  Link
ottar
All in one file. I don't know how to do one file for each episode, but I would like to.
ottar is offline
Old 25th December 2006, 20:00   #574  |  Link
buzzqw
HDConvertToX author
so you have three ifo file ? if so please check on advanced settings episoding dvd and choose the ifo corrispondenting to your episodes
BHH
buzzqw is offline
Old 25th December 2006, 21:15   #575  |  Link
ottar
Just one IFO file. There are four PGCs, length 0:21, 1:30:59, 45:01, and 44:44. The MKV I get out has the right length (3:01:17), but the chapter points are the ones for the longest title (the 1:30:59 one). The chapter points are wrong, though, because they start from 00:00, not from 0:21.
ottar is offline
Old 25th December 2006, 21:56   #576  |  Link
buzzqw
HDConvertToX author
please PM where to download the ifo
BHH
buzzqw is offline
Old 25th December 2006, 22:11   #577  |  Link
fogbav
@buzzqw : You are the best ...!
Tomorrow i will test the button left from about ...8)
Thanx
FoGBaV
Edit : First run didn't worked ... will test tomorrow morning ...
fogbav is offline
Old 26th December 2006, 05:20   #578  |  Link
weaver4
Anyone know how to make a file for Zune with AutoMKV? The specification says it will play a H.264 format in a .m4v file.
So, I have tried to make a *.mp4 file in the using CE-mainprofile and then renaming it *.m4v. But the Zune it won't load it.
weaver4 is offline
Old 26th December 2006, 08:16   #579  |  Link
buzzqw
HDConvertToX author
@fogbav.... some more information ???
@weaver what are the specifics (width/height/bitratre/level...) of Zune ?
BHH
buzzqw is offline
Old 26th December 2006, 10:08   #580  |  Link
fogbav
d2v file is not build normal ... its zero sized ...
DGINDEX is not coming up ....
log :
10:03:02 Selected Input file: D:\ACE4.0\tmp\film.m2v
10:03:02 Selected Output dir: D:\ACE4.0\tmp\temp\
10:03:02 Selected Container type: MP4
10:03:02 Selected Encoder: XviD
10:03:02 Selected Size: 55
10:03:02 Selected Slice: 1
10:03:02 Selected Profile: XviD_Normal.xml
10:03:02 Selected Width: 688
10:03:02 Selected Resizer: LanczosResize
10:03:02 Selected Filters: Spresso()
10:03:02 Selected Deinterlacer: AUTO
10:03:02 Enabled CRF/CQ autoresize with value 2.5
10:03:02 Using Matrix: Sharktooth's EQM v3LR.cqm
10:03:02 Track Language 1: All Audio Tracks
10:03:02 Audio Codec 1: Nero AAC
10:03:02 Audio Quality 1: 0.35
10:03:02 Track Language 2:
10:03:02 Audio Codec 2: Nero AAC
10:03:02 Audio Quality 2: 0.35
10:03:02
10:03:02 Not fixing audio files
10:03:03 ERROR - There are some problem with movie lenght! Try parsing D2V file
10:03:03 Number of Frames: 0
10:03:03 Framerate:
10:03:03 Movie lenght in Seconds: -2147483647
10:03:03 Movie Width:
10:03:03 Movie Height:
10:03:06 Order: unk
10:03:06 FIRST pass XviD: "D:\ACE4.0\exe\encoder\xvid_encraw.exe" -pass1 -progress -bitrate 0 -turbo -threads 1 -max_bframes 2 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_ratio 162 -chigh 15 -clow 5 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "D:\ACE4.0\profiles\XviD-profiles\matrix\Sharktooth's EQM v3LR.cqm" -i "D:\ACE4.0\tmp\temp\movie.avs" -type 2 -avi "D:\ACE4.0\tmp\temp\movie_firstpass.avi"
10:03:06 SECOND pass XviD: "D:\ACE4.0\exe\encoder\xvid_encraw.exe" -pass2 -progress -bitrate 0 -threads 1 -max_bframes 2 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_ratio 162 -chigh 15 -clow 5 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "D:\ACE4.0\profiles\XviD-profiles\matrix\Sharktooth's EQM v3LR.cqm" -i "D:\ACE4.0\tmp\temp\movie.avs" -type 2 -avi "D:\ACE4.0\tmp\temp\movie.avi"
10:03:06 Starting First Pass
10:05:21 Starting Second Pass
10:05:24 D:\ACE4.0\exe\matroska\mp4box.exe -add "D:\ACE4.0\tmp\temp\movie.avi"ar=-1.#IND00 -chap "D:\ACE4.0\exe\chapters.txt" -fps 25.00000 "D:\ACE4.0\tmp\temp\movie.mp4"
10:05:25 Final Muxed size: -1 bytes
10:05:25 Encoding finished: 00:02:23 elapsed time
Directory Structure :
Datentr„ger in Laufwerk D: ist Data
Volumeseriennummer: XXXX-XXXX
Verzeichnis von D:\ACE4.0\tmp\temp
26.12.2006 10:05 <DIR> .
26.12.2006 10:05 <DIR> ..
26.12.2006 10:03 0 AutoCrop.log
26.12.2006 10:03 209 createautodeintmovie.avs
26.12.2006 10:03 574 createautodeintmovie.avs.bautodeint_temp.avs
26.12.2006 10:03 126 deint.bat
26.12.2006 10:03 4.766 deint.log
26.12.2006 10:03 0 frame.txt
26.12.2006 10:05 0 mkvmaudio.avs
26.12.2006 10:05 0 mkvmaudio.bat
26.12.2006 10:05 0 mkvmaudio2.avs
26.12.2006 10:05 0 mkvmaudio2.bat
26.12.2006 10:03 2.971 movie.avs
26.12.2006 10:03 0 movie.d2v
26.12.2006 10:03 0 movielenght.mp4
26.12.2006 10:05 170 muxing.bat
26.12.2006 10:05 0 resmovie.avs
26.12.2006 10:03 1.252 time.avs
26.12.2006 10:03 393 xvidfirstpass.bat
08.12.2006 20:16 2.457 xvidprofile.xml
26.12.2006 10:03 376 xvidsecondpass.bat
19 Datei(en) 13.294 Bytes
2 Verzeichnis(se), 14.705.438.720 Bytes frei
with 063d evrything is fine ...
fogbav is offline
