Old 6th August 2006, 05:32   #161  |  Link
jruggle
Originally Posted by Rockaria
Hi boys and gentlemen,
One last(for somewhile) stats of the -m mode for the stereo clips only(again as I started it) looking for successive useful analysis from anybody.
I was unable to experience the shoking advantage of 'stereo rematrixing' with 41_30sec.wav, partially because of the less common factors and mostly because of the v0.04?
Thanks. I was just using the algorithm in the specification, but I did some modifications, and now the stereo rematrixing works a little bit better. The changes have been committed to SVN.
Also, I have created a cron job which will upload daily builds. They can be accessed at:
http://jbr.homelinux.org/aften/daily/
the .zip files are win32 binaries
the .bz2 files are source files
The job is set to run every day at 4:50AM EST. I already made some builds for today (6th) and yesterday (5th) as a test. The ones for the 6th will be overwritten at 4:30.
jruggle is offline   Reply With Quote
Old 6th August 2006, 10:17   #162  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
1st post and GUI updated.
@Raquete : AftenGUI 1.1 doesn't work with aften 0.03-dev and higher due to the bitrate tweaking (bps --> kbps). It should be fine now with the 1.2.
Originally Posted by BigDid
We have had that kind of exchange in the past but you're the expert, so I will try to argument:
C'est pas gagné...
I'm ok for #2 but this depends of your source. Regarding #1, this doesn't make sense, sorry. "Reencode an ac3 stream to have multichannel playback"...It's really funny imho. If it's not a pleasure for you, well don't reencode them. Don't waste your time with this, it's really precious for other things.
Old 6th August 2006, 19:31   #163  |  Link
Inc
Squeeze it!
Inc's Avatar
Then the Besweet-azid seems to perform kinda 'rebuilding' on decoded ac3 encoded originally clipped area(or some other interpretations on the streams).
I am less familiar with the behappy wrapper than the original open avisynth environment.
So you can regard I am well aware of the avisynth's wide range capability of the bit sizes.
However, in the older(20060226) source of the AvisynthWrapper.cpp I read :
  if (inf.HasAudio())
   *originalSampleType = inf.SampleType();
   if( *originalSampleType != SAMPLE_INT16)
    res = pstr->env->Invoke("ConvertAudioTo16bit", res);
    pstr->clp = res.AsClip();
    infh = pstr->clp->GetVideoInfo();
    if(infh.SampleType() != SAMPLE_INT16)
     strncpy(pstr->err,"Cannot convert audio to 16bit",ERRMSG_LEN-1);
     return 6;
which forces any audio stream process beyond 16bit not that useful including aften ac3 encoder through pipe.
There might be some reasons for this restriction or already excluded(which I cannot confirm) that behappy users with aften certainly want?
(I am not sure if this issue is discussed already)
[edit] I confirm the latest cpp source dated 05/09/2006 is unchanged in the mentioned area.
That one was implemented by the orig author 'mobileHackerz' of avsredirect.dll on which avisynthwrapper does base on.
Its kinda forcing a compatibility as its original purpose was to serve avs frameservingdata to ffmpeg. Just alter that section or even mark it using "//", compile the dll using VSC++ Express 2005 and see what happens when using in Behappy etc.
Inc is offline   Reply With Quote
Old 6th August 2006, 20:02   #164  |  Link
BigDid
Actually in reserve
Thanks for the new release(s), thanks for the compatibility with Behappy, thanks for the new GUI.
Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first
Want to exchange on AutoGK? try doom10.org
In reserve (inactive) for an undefined period of time.
BigDid is offline   Reply With Quote
Old 6th August 2006, 21:16   #165  |  Link
Rockaria
nobody's nobody
Thanks, I am forwarding it to tebasuna. The reasons explained.
And thanks gents, I will check the daily builds whenever possible and demanding.
u know everything in the end, or now if aligned... no right(x).right(y) pls. it's confusing... : phase-shift /Jun.2006
Rockaria is offline   Reply With Quote
Old 7th August 2006, 00:30   #166  |  Link
raquete
(AftenGUI v1.1 is working with aften 0.03-dev(24-07-06),i posted "samples" with this version today)
woo...thanks so much,the new AftenGUI is working fine( of course..you build it!)
now is full of features and adjusts ... ...i need one "guide" Kurt. (not kiddin)
someone please help me!
raquete is offline   Reply With Quote
Old 7th August 2006, 06:04   #167  |  Link
DSP8000
Doom9 Member
DSP8000's Avatar
Tnx. to everyone's effort in developing this encoder.
Here's an installer for Aften AC3 Encoder v0.5 Incl.GUI v1.2 by kurtnoise.
Keep up the good work
DSP8000
EDIT: UPDATED TO v0.5
DSP8000 is offline   Reply With Quote
Old 9th August 2006, 07:05   #168  |  Link
jruggle
I invite anyone who is interested in the development side of Aften to join the aften-devel mailing list.
Old 11th August 2006, 11:02   #169  |  Link
Kurtnoise
Kurtnoise's Avatar
Actually, you have just to concentrate on the "General" Tab for *Normal* encodes. All others depend of your needs.
Old 21st August 2006, 23:51   #170  |  Link
jruggle
Version 0.05 released today.
Biggest improvement: 30-50% speed increase (depending on platform & CPU)
http://sourceforge.net/projects/aften/
Old 22nd August 2006, 13:07   #171  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
haha! that makes it ~ 15x faster than soft encode
Old 22nd August 2006, 13:46   #172  |  Link
dragongodz
dragongodz's Avatar
jruggle - do you have any plans to try and get some of these changes in to ffmpeg/libavcodec ? that would be nice.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1)
dragongodz is offline   Reply With Quote
Old 23rd August 2006, 04:13   #173  |  Link
raquete
anyone is using short-block 256-point MDCT?
jruggle, for the news.
Old 23rd August 2006, 04:32   #174  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
i'm using short blocks. haven't done any ABX'ing yet, but some samples with crackle, castanets and heavy brass don't sound obviously bad.
Old 23rd August 2006, 14:07   #175  |  Link
jruggle
Yes, the recent speed-ups can be ported back to ffmpeg. Also there are a couple bug fixes.
Old 26th August 2006, 08:39   #176  |  Link
raquete
Originally Posted by DSP8000
Here's an installer for Aften AC3 Encoder v0.5 Incl.GUI v1.2[/URL] by kurtnoise.
DSP8000
thanks.
ps: i was lucky finding the update.don't deserve a new post after each new version?
Old 26th August 2006, 12:08   #177  |  Link
DSP8000
Doom9 Member
DSP8000's Avatar
Yes, sure, no probs
DSP8000
Old 27th August 2006, 03:37   #178  |  Link
Chainmax
Huh?
Chainmax's Avatar
That sounds great, hopefully an organized listening test comparing Aften to commercial encoders will take place at HA soon.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 27th August 2006, 13:04   #179  |  Link
DSP8000
Doom9 Member
DSP8000's Avatar
Hi Guys,
Can someone make HTML Guide for Aften? I'd like to include it in my installer as a reference guide for Aften.
Also, @kurtnoise,
can you send me your GUI with 48x48 or higher res icon? Check your mail as well .
IMO, excellent AC3 encoder like Aften deserves a bit more attention, meaning,
avearge Joe will not understand short blocks, dialg norm,mid-side stereo...
We need full on guide with all of the settings explained.
From my tests so far I think Aften produces very good output .
DSP8000
Old 28th August 2006, 10:19   #180  |  Link
Kurtnoise
Kurtnoise's Avatar
@kurtnoise,
64x64 is ok ? :> http://kurtnoise.free.fr/cr64.png
