Old 15th November 2009, 22:22   #1041  |  Link
Abradoks
Originally Posted by jruggle View Post
for any further comparisons you should turn on block switching in Aften since DD does block switching by default.
It was turned on for aften_spec and aften_wide in the first comparison I have posted.
And thank you for your work on aften. I hope we'll see even better results than DD has.
Abradoks is offline   Reply With Quote
Old 17th November 2009, 03:39   #1042  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
How would you clever AC3 encoding folks suggest maximizing the quality of 384kbps AC3 for 3/2 + LFE encoding?
I'm currently using EncWAVtoAC3 4.2, without any modifications to the advanced parameters.
~MiSfit
Old 17th November 2009, 04:30   #1043  |  Link
jruggle
aften -b 384 -exps 32 -s 1 -bwfilter 1
Also, if you can increase the -w parameter without quality going below q=240 then that would be good. The -w -2 (variable bandwidth) option is too experimental to be used generally, but doing a test run with it can give you a good idea of how much you can increase the bandwidth without affecting quality too badly.
jruggle is offline   Reply With Quote
Old 17th November 2009, 08:12   #1044  |  Link
Blue_MiSfit
Thanks, jruggle.
I have two different Dolby encoding systems (Media Encoder Server for Mac, and a DP600 encoder server), and will be comparing the quality of both vanilla AC3 and E-AC3. What software was being used earlier in the thread to generate those pretty spectrographs?
~MiSfit
Old 17th November 2009, 08:13   #1045  |  Link
nurbs
Spectrographs don't tell you anything about the quality.
Old 17th November 2009, 10:35   #1046  |  Link
tebasuna51
tebasuna51's Avatar
The same parameters are recommended when use the max bitrate 640 Kb/s?
Maybe the bwfilter is not necesary when use max banwidth.
Old 23rd December 2009, 21:47   #1047  |  Link
wisodev
New Aften build is available : http://code.google.com/p/wavtoac3encoder/downloads/list
wisodev is offline   Reply With Quote
Old 23rd December 2009, 21:58   #1048  |  Link
TFM_TheMask
TFM_TheMask's Avatar
Originally Posted by wisodev View Post
Can you tell us what has changed in this new version?
The Mask
Developer of The FilmMachine
An easy to use, wizard-like, AVI/MP4/MOV/RMVB/MKV to DVD conversion utility
TFM_TheMask is offline   Reply With Quote
Old 28th December 2009, 22:18   #1049  |  Link
Yobbo
Wisodev, can you just drag & drop these new libaften.dll's over the existing dll's in your Wav to AC3 Encoder? Will you be updating the Encoder soon?
Yobbo is offline   Reply With Quote
Old 29th December 2009, 00:34   #1050  |  Link
wisodev
New version of WAV to AC3 Encoder is available for download , version 4.3 includes libaften.dll version from 20091226 (Git master head snapshot).
Old 29th December 2009, 01:57   #1051  |  Link
tebasuna51
tebasuna51's Avatar
Thanks wisodev.
There are some channel coupling improvement in last Aften version?
Old 29th December 2009, 02:29   #1052  |  Link
jruggle
Thanks wisodev.
There really have not been many changes in a while. Just some tweaks to the exponent strategy decision. There were a few code structure changes in preparation for channel coupling though. And it looks like Prakash has added Windows x64 support while I was away for Christmas.
Old 30th December 2009, 20:53   #1053  |  Link
TFM_TheMask
Isn't it possible to only get 2 aften libraries which can detect the PC's SIMD capabilities (SSE, SSE2, SSE3, MMX). So only libaften_x86.dll and libaften_x64.dll and not 6 or more different libraries?
So what I mean is a compiled libaften library with all SIMD instructions in it and it checks which instructions it can use depending on a PC's capabilities.
The Mask
Old 30th December 2009, 21:21   #1054  |  Link
wisodev
All my libaften.dll builds have enabled ALL Aften SIMD optimizations (if your hardware supports specific SIMD it is enabled on runtime). But additionally the MMX, SSE, SSE2, etc. builds have extra optimization made by Intel C++ Compiler and REQUIRE presence of SIMD support in hardware (else you can expect crushes), so you just can use default builds: libaftendll_x86 and libaftendll_AMD64 most of the time.
Old 30th December 2009, 21:24   #1055  |  Link
TFM_TheMask
Ok thanks, will do that. One little question, the libaftendll_AMD64 is only for AMD x64 processors or also Intel x64 processors?
The Mask
Old 30th December 2009, 22:18   #1056  |  Link
wisodev
It's AMD and Intel CPU compatible (actually it's compiled using Intel C++ Compiler).
Old 30th December 2009, 22:35   #1057  |  Link
TFM_TheMask
Better change the name to x64 instead of AMD64.
The Mask
Old 3rd January 2010, 13:37   #1058  |  Link
raquete
thank you so much wisodev!
(no more 'old problems' running Win2000, changing to Win7)
veru very Happy New year!
search raquete
raquete is offline   Reply With Quote
Old 5th January 2010, 07:55   #1059  |  Link
MrVideo
MrVideo's Avatar
Ya, had me confused. I downloaded the AMD64 versions, only to discover that it is for 64bit OSs. I have the AMD64 dual core, but run 32bit OS.
Old 5th January 2010, 08:12   #1060  |  Link
MrVideo
MrVideo's Avatar
Which x86 version to use?
I've been using an older version of the files found in the aften_x86 directory.
Which is better, to use the files in the aften_x86 directory, or the files in the libaftendll_x86 directory?
If the libaftendll_x86 contents are used, I'm going to assume that they are placed in the same directory as I've previously done with the aften_x86 contents.
There was nothing in the top level readme file about which should be used, and why.
