Thread Tools Display Modes
Old 10th December 2001, 21:30   #1  |  Link
smok3
videographer
smok3's Avatar
* Sound Blaster Live! Player 5.1 & dolby prologic
is there a way to 'decode' mp3 soundtrack to feed the 'sb liveplayer 5.1' with 3 or 4 channels of good old prologic?
smok3 is offline   Reply With Quote
Old 10th December 2001, 22:02   #2  |  Link
MaTTeR
AC3 5.1 Addict
MaTTeR's Avatar
Back in the days when I used this card, I recall the Live software allowing you to emulate surround sound. Look through some of your seetings and you should see a "Virtual 4 Speaker" setting or something similar. Can't help anymore, that's all I rememeber.
MaTTeR is offline   Reply With Quote
Old 10th December 2001, 23:58   #3  |  Link
Doom9
clueless n00b
actually.. due to licensing costs no sblive supports dolby pro logic decoding.. what matter was refering to was a dolby-like 4 channel mode that's not compatible with dolby pro logic. So.. all you can do is output 2 channel audio and have your receiver do the job. Dolby surround decoding never really took off inside the pc
Doom9 is offline   Reply With Quote
Old 13th December 2001, 16:22   #4  |  Link
smok3
videographer
smok3's Avatar
tnx
Old 13th December 2001, 21:12   #5  |  Link
dragonlz
Does anyone know if you can use the prologic decoder built into PowerDVD4 to process mp3 files? I figured it would be almost the same as using WinDVD's audio filter, but maybe not if Cyberlink did not make them directshow filters.
-=\=[DRaGoNLz]=/=-
dragonlz is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
