Old 24th March 2006, 11:47   #21  |  Link
hanfrunz
hanfrunz's Avatar
we want that filter A (pget) reads the rgb values of a given pixel. These values should be stored in script-variables (r,g,b). Then other filters can use these values to do whatever you wish.
hanfrunz is offline   Reply With Quote
Old 24th March 2006, 14:45   #22  |  Link
IanB
Avisynth Developer
Probably you want
int n = 42;
env->SetGlobalVar("name", (AVSValue)n);
PushContext/PopContext would have to be involved but I am not quite sure why in this case. Are you env->Invoke'ing a 2nd chain? A single GetFrame chain should all be in the same context.
You may have to debug trace your way thru the code chain from the child->GetFrame() call in filterB down thru to the Set(Global)Var call in filterA::GetFrame.
There be dragons in that there code
IanB is offline   Reply With Quote
Old 2nd April 2006, 16:03   #23  |  Link
jmac698
Other people need this
How is the plugin coming?
I noticed:
http://forum.doom9.org/showthread.ph...982#post674982
HighInBC: Is there a way for avisynth to return the color of a specific pixel into an int?
Someone wants to use it for a whitebalance script. It proves my point that this is a needed function, as there's people with great ideas that can only script and not write a full plugin.
jmac698 is offline   Reply With Quote
Old 3rd April 2006, 10:54   #24  |  Link
hanfrunz
hanfrunz's Avatar
I noticed:
I still think, that it is not possible to for a filter to change a scriptvariable, but i will investigate if i have time. A new version with a preview-window will be uploaded the next days!
hanfrunz
Old 4th April 2006, 04:40   #25  |  Link
jmac698
I don't understand the problem, but I asked IanB to give you a hand, has his suggestions not helped? If you can explain clearly I'm sure you can get help....
There's also the source code I left for you.
Old 4th April 2006, 11:01   #26  |  Link
hanfrunz
hanfrunz's Avatar
The main problem is time, i hope i find some time the next days to analyse all that stuff...
Old 7th August 2006, 09:39   #27  |  Link
Backwoods
ReMember
Backwoods's Avatar
Have you found any time to work on this filter hanfrunz?
Backwoods is offline   Reply With Quote
Old 7th August 2006, 19:55   #28  |  Link
hanfrunz
hanfrunz's Avatar
i worked a little bit on the pget() filter, but it's too buggy right now. I try to release a new version in a few days.
hanfrunz
Old 8th August 2006, 16:04   #29  |  Link
windcool
my English is very poor
I can't download this filter.
Please check the adress,.
windcool is offline   Reply With Quote
Old 10th August 2006, 10:58   #30  |  Link
hanfrunz
hanfrunz's Avatar
@windcool: please try again, works fine for me. Geocities is sometimes down...
Old 24th September 2006, 06:07   #31  |  Link
yashar
are you still working on this filter hanfrunz?
yashar is offline   Reply With Quote
Old 25th September 2006, 10:51   #32  |  Link
hanfrunz
hanfrunz's Avatar
sometimes, i will release a new version soon.
Old 17th September 2007, 00:05   #33  |  Link
Wilbert
@jmac698,
Something like this:
LoadPlugin("F:\CompilingPlugins\PixelValue\Release\PixelValue.dll")
w = ColorBars(pixel_type="RGB32")
#w = ScriptClip(w, """Subtitle(String(RGB(200, 40, "B")))""")
#w = ScriptClip(w, """Subtitle(String(RGB(500, 40, "BGR")))""")
w = ScriptClip(w, """Subtitle(String(RGB(500, 40, "R")))""")
return w
See readme for further information and examples.
http://www.geocities.com/wilbertdijk...lValue_v01.zip
Old 26th February 2015, 17:32   #34  |  Link
Anybody got the source for either PixelInfo or PixelValue, Geocities closed down.
Thought it might be handy to have a v2.6 colorspace compatible version.
Old 26th February 2015, 17:40   #35  |  Link
feisty2
I'm Siri
feisty2's Avatar
could be done by simple scripts
yv12 - pointresize to yuy2
yv16 - converttoyuy2
yv24 - mergergb (y,u,v)
y8 - mergergb (last, last, last)
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is online now   Reply With Quote
Old 26th February 2015, 17:48   #36  |  Link
I believe PixelInfo has a GUI.
Old 26th February 2015, 17:56   #37  |  Link
feisty2
I'm Siri
feisty2's Avatar
if you are interested, avspmod got a pixelinfo like function, available for all avisynth supported colorspaces, it very self is a GUI program, just put your mouse pointer at any pixel and it will show its info at the status bar
Old 26th February 2015, 18:37   #38  |  Link
Reel.Deel
Here you go: pixelinfo0_3.zip
archive.org does not seem to have PixelValues archived. Maybe Wilbert still has it?
Old 26th February 2015, 19:47   #39  |  Link
Many thanks rd, you seem to have a copy of everything.
Old 26th February 2015, 22:02   #40  |  Link
Reel.Deel
Actually I got PixelInfo from Wilbert's plugin package here: http://forum.doom9.org/showthread.ph...hlight=package
