Old 10th March 2006, 01:20   #1  |  Link
mikemcc
Audio delay / lip sync
Can anyone please tell me the best way to measure audio delay accurately during / before a DVD rip ? I'd happily use DVD Decrypter but, eg, it says the delay is 371 ms whereas I have to enter a 200 ms adjustment in Tmpg Xpress to create an mpeg2 file which has perfect lip sync using PowerDvd or WMP.
Perhaps I need to understand what audio delay is a function of. Thanks for any help.
mikemcc is offline   Reply With Quote
Old 11th March 2006, 05:25   #2  |  Link
plomon
123kid
rip a small part of audio using Rejig(download here). it tells you the audio delay in it's file name itself.
Have a nice day !!! :cool:
plomon is offline   Reply With Quote
Old 11th March 2006, 13:49   #3  |  Link
mikemcc
Thanks Plomon. Looks like good advice; I've used ReJig once and it worked fine. You don't even have to start the rip - it specifies the delay immediately you specify the VOB. I'll update this thread only if I find it doesn't work all the time. Hope you're enjoying the cricket.
Old 12th April 2006, 21:24   #4  |  Link
j7n
j7n's Avatar
I have the same problem. Audio is usually delayed by 2-8 video frames or smth like that. Where does exactly ReJig display the delay? Do I need the full DVD to detect it, is there a way I can do it from MPEG2 without the *.ifo files?
j7n is offline   Reply With Quote
Old 12th April 2006, 21:38   #5  |  Link
mikemcc
Sorry, I should have posted back, saying that ReJig *doesn't always* provide the answer, but did help me. I can't get back into it now, but my notes tell me that in ReJig I selected:
File mode, add, select VOB, done
and it showed me the audio delay.
I have always *imagined* that you need to read from the DVD to find the delay, as the delay "emerges" only when you rip from a DVD. But I'm no great expert.
Hope that helps a bit.
Old 12th April 2006, 22:03   #6  |  Link
j7n
j7n's Avatar
Forgive me if I missed something but I can't see the delay value.
The VOB files I have play fine with Elecard + AC3Filter. So I assume all the required information is already in the MPEG-2 stream.
After conversion to X264 with VirtualDubMod 1.5.10.2.2542 a random negative audio delay is introduced. It's like there was no audio for a few frames at the beginning. There was one example where no delay ocurred (I don't know why), AC3 bitrate was 192 kBit/s in this case.
I don't mind using a hex editor and a calculator rather than a one click solution. It'll be alot faster that delaying the audio a bit, testing carefully, delaying again, etc.
Thanks for any comments in this matter.
Old 3rd May 2006, 13:56   #7  |  Link
mikemcc
Sorry not to get back sooner. In ReJig:
Select file mode, add
Select VOB with audio, done
See the audio delay
Hope that helps
Old 20th June 2006, 23:11   #8  |  Link
j7n
j7n's Avatar
You were right, MikeMCC.
It appears that the delay I was talking about was caused by VFW compatibility mode for H.264. I read about it here:
http://forum.doom9.org/showthread.php?t=99033
