Old 11th March 2006, 16:53   #61  |  Link
Originally Posted by Tima
I can provide a sample, but I don't know good tools for cutting VOB files
Without a sample that shows the problem I can't help you. Get a VOB splitter on the Doom9 full download page.
Anyway, you have a VOB with one frame in it? Where did that come from?
Also, try navigating with the single step feature. Maybe the GOP stepping is getting confused. It appears to be entirely a cosmetic issue, yes?
Guest is offline
Old 11th March 2006, 22:20   #62  |  Link
Tima
I couldn't find appropriate tool even on full download page. Could you tell me the name of this prorgam?
It's a part of big file VTS_01_4.VOB of DVD 'Help!' (starring The Beatles).
Yes, it's cosmetic, but cosmetic bugs are bugs too..
Sigle step also doesn't work properly..
Tima is offline
Old 11th March 2006, 22:40   #63  |  Link
Tima
I found Chopper XP, but I had to use manual extraction, because normal way failed..
Here's a sample:
http://rapidshare.de/files/15268900/test.vob.html
Tima is offline
Old 12th March 2006, 18:53   #64  |  Link
How did you rip it?
Guest is offline
Old 12th March 2006, 20:13   #65  |  Link
Tima
How did you rip it?
Jusp opened VTS_01_4.VOB directly from DVD..
Sample was made by 'manual extraction' feature of Chopper XP.
Tima is offline
Old 12th March 2006, 20:23   #66  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Wouldn't the VOB still have the copy protection intact and that might cause the problem with ChopperXP?
Boulder is offline
Old 12th March 2006, 21:27   #67  |  Link
Tima
Maybe.. but DGIndex had a proplem even with non-trimmed file.
Tima is offline
Old 13th March 2006, 01:19   #68  |  Link
Maybe..
You don't know? I'm hearing rule 6 tunes in my head again.
Run DVD Decrypter on it and see if it is CSS protected.
Guest is offline
Old 13th March 2006, 10:33   #69  |  Link
Tima
DVD Decrypter says 'Copyright Protection System Type: None'.
Tima is offline
Old 13th March 2006, 10:42   #70  |  Link
frank
Originally posted by Tima:
When navigating forward over vob 10, there's no indication about it in window's title -- there are 'vob 9' and then 'vob 11'...
The number of VOBs in a titleset is limited to 9 because of the name length of 8 characters! (old DOS convention)
VTS_01_10.VOB has 9 characters in the name and is out of specs, therefore there is no tool to manage it properly.
On PC you can copy the remaining VOBs to _9.VOB (more than 1 GB), then a PC can access properly. After editing you have to shrink to 9 regular VOBs, or create a new titleset for the rest.
frank is offline
Old 13th March 2006, 14:46   #71  |  Link
acrespo
Brazilian Anime Ripper
I didn't understand why dgindex can't pass audio to dgdecode. Is this not possible or not implemented? Is there interest to implement this feature?
Capture cards:
Compro VideoMate Gold+ (Philips SAA7134 based) (not active)
Hauppauge PVR 150MCE (not active)
ATI TV Wonder Elite (active)
acrespo is offline
Old 13th March 2006, 15:25   #72  |  Link
Why pass it to DGDecode, which is a video decoder? The Quick Start guide explains how to serve video and audio together.
Guest is offline
Old 13th March 2006, 15:37   #73  |  Link
Rockas
Ridendo Castigat Mores
Rockas's Avatar
@neuron2
This may sound like a stupid question but here it goes:
- Any plans for supporting AVI files (Uncompressed, MPEG4, DV, etc)?
None is as blind as those that don't listen.
www.dvdrebuilder.com
RME
Rockas Software
Rockas is offline
Old 13th March 2006, 15:42   #74  |  Link
acrespo
Other plugins can open video and audio (DirectShowSource, AviSource) why not MPEG2Source too? It would be more easy to compress audio in virtualdub.
My audio source is MPA and I always need to convert in WAV to use WAVSource. If MPEG2Source can open audio too, my life would be more easy.
Capture cards:
acrespo is offline
Old 13th March 2006, 15:52   #75  |  Link
Rockas
Rockas's Avatar
@acrespo
you can use nicaudio.dll to load every "usuall" mpeg2 audio formats into the avs script.
RME
Rockas Software
Rockas is offline
Old 13th March 2006, 16:04   #76  |  Link
acrespo
I am suggesting this feature to make all things more easy. One plugin less (nicaudio).
Capture cards:
acrespo is offline
Old 13th March 2006, 17:05   #77  |  Link
How so?
Guest is offline
Old 13th March 2006, 18:08   #78  |  Link
acrespo
I usually use Besweet to convert MPA files to WAV. Then I open AVS in virtualdub and load the WAV file to compress in MP3 format. I do other way too: convert MPA to WAV, load WAV in the script with WAVSource and compress in virtualdub.
I think it's too many passes to do. When I compress AVI files I only use AVISource and load in virtualdub to compress both audio and video. I don't need to do dgindex project and besweet conversion. I am trying to make all process more fast. I did too many videos and I don't have much time.
I am thinking other thing: If dgdecode.dll could manipulate the mpeg2 (video and audio) files directly without do d2v project in dgindex, the process will be more easy yet!! Why not?
Capture cards:
acrespo is offline
Old 13th March 2006, 18:22   #79  |  Link
Rockas
Rockas's Avatar
I'm not a VirtualDub expert but... would'nt it work with a script like:
loadplugin("d:\tests\dgdecode.dll")
loadplugin("d:\tests\nicaudio.dll")
v=MPEG2Source("D:\Tests\teste3.d2v")
a=DelayAudio(NicMPASource("D:\Tests\teste3 -40ms.mpa", 2),-0.040)
AudioDub(v,a)
I'm not sure about this... but it would be easier to neuron2 if he "supports" the audio through the AVS template (if it doesn't support already )
RME
Rockas Software
Rockas is offline
Old 13th March 2006, 18:46   #80  |  Link
@acrespo
Please consider the "wrapper" solutions like GK, etc., if ease of use is your primary goal.
There is a perfectly adequate process to avoid multiple passes. It is just as given in the Quick Start guide and as Rockas has shown. If you set up your AVS template correctly, you won't even have to think about it.
DGDecode needs the index information from DGIndex to work. Putting all the DGIndex functionality into DGDecode has been suggested (see Development list).
Guest is offline
