Old 8th January 2006, 03:01   #21  |  Link
Doom9
clueless n00b
Add a "just mux" feature for the audio similar to what Gordian Knot does.
That already exists.. auto mode is your friend.
Doom9 is offline
Old 8th January 2006, 04:50   #22  |  Link
willie1
Thanx. I wasn't aware.
willie1 is offline
Old 8th January 2006, 18:58   #23  |  Link
The Link
The Link's Avatar
1. I would suggest a send to tray button so you can visually hide MeGUI while it's doing its job.
2. Furthermore I would suggest to make the Status window a child of the main MeGUI window so there's only one item in the taskbar (but that's probably a matter of preference).
3. Something I'd like to see is Ogg Vorbis support as it's the only good free low bitrate codec at the moment (FAAC isn't tuned and afaik generally worse than Vorbis and the Nero AAC codec isn't free. Itunes AAC codec is for free and quite good imho but not very well supported via cli.). The obvious drawback: You can only sanely use it in mkv.
Just some suggestions from my side. I hope I didn't miss some already existing features which would already cover my feature requests.
edit: grammar
When birds burp, it must taste like bugs! (Calvin&Hobbes)
The Link is offline
Old 8th January 2006, 20:53   #24  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Load Defaults button (not only the button but the function too )
Just a simple load defaults button with a pop-up asking you yes/no, because sometimes people click the wrong button and all previous set options will be gone.
bob0r is offline
Old 8th January 2006, 20:58   #25  |  Link
Teegedeck
Moderator, Ex(viD)-Mascot
Teegedeck's Avatar
errr... Exporting it to a Mono project?
It's a man's life in Doom9's 52nd MPEG division.
"The cat sat on the mat."
ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl!
Teegedeck is offline
Old 8th January 2006, 21:15   #26  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it requires some adjustments for the *nix platform.
Sharktooth is offline
Old 8th January 2006, 21:25   #27  |  Link
Teegedeck
Teegedeck's Avatar
Yes, and I have no idea how it would be possible for a Mono-application to open AviSynth-scripts via Wine. Just regard it as a desperate cry for a decent encoding GUI on Linux. And I mean 'decent'.
Perhaps it will happen just in time for AviSynth 3...
Old 8th January 2006, 22:00   #28  |  Link
berrinam
berrinam's Avatar
@bob0r: Defaults across the entire GUI? What you want has the same effect as removing the settings.xml file?
berrinam is offline
Old 8th January 2006, 22:13   #29  |  Link
The Link
The Link's Avatar
I'd like "reload defaults" buttons in every codec settings preferences or alternatively for every codec/encoder a default preset which is not deletable.
edit: making more sense
The Link is offline
Old 8th January 2006, 22:24   #30  |  Link
Doom9
clueless n00b
AviSynth isn't the only problem for making this run on Linux.. there's also a dgdecode dependency in the avisynth script creator. And Linux has no proper multimedia API that's available on a kernel level (so it would be in every distro), has it?
Basically if you need both the AviFile API and DGDecode, and there are other things. For instance environment variables (number of CPUs, path), a Linux BeSweet, etc.
I'd like "reload defaults" buttons in every codec settings preferences.
That sounds reasonable and is easy to implement in just a few lines of code.
Doom9 is offline
Old 9th January 2006, 00:29   #31  |  Link
jmk
move the profile selection drop down list in the config dialog window to the bottom of that window, so that it will be visible and accessible in all tabs.
jmk is offline
Old 9th January 2006, 05:23   #32  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
codec defaults. same thing The Link proposed.
Old 9th January 2006, 08:37   #33  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
I've implemented one of the simple requests:
- progress window now has a Hide button
- View -> Progress menu item is now a toggle
Modified files are attached. You'll need to diff against the CVS copies as of about 2 days ago (sorry, I didn't save a copy, and I only have anonymous CVS access).
Richard Berg is offline
Old 9th January 2006, 09:16   #34  |  Link
Doom9
clueless n00b
Can you elaborate on that? We already have an option in the settings that allows you to configure if the progress window automatically comes up when a job is being started (except for an index job, there it makes little sense to have a progress window since dgindex doesn't return any progress reports), and the view - progress menu is context sensitive, so the actual menu option is only active when there's no progress window on screen.
Doom9 is offline
Old 9th January 2006, 09:32   #35  |  Link
Richard Berg
developer wannabe
The View -> Progress menu item now has 3 states:
- disabled
- enabled but not checked (progress window hidden).
- enabled and checked (progress window shown)
Clicking it toggles back & forth between the latter states. Test the code, it's very simple.
Old 9th January 2006, 10:14   #36  |  Link
quake74
Multiple (more than 2) audio/subs tracks and psp stuff.
Multiple (more than 2) audio/sub tracks is my first complain with pretty much every gui out there (excluding the old dvd2ogm and dvd::rip). I would often like to rip the original soundtrack, the comments, the track in english or my native language, and maybe french since I'm trying to study it. From what I understand, it's mainly a gui problem since I can include as many tracks I want in mp4 or mkv, right?
For the psp it would be useful to be able to choose the sampling rate for the audio (psp only supports 48000Hz). Automatic running of atomchanger would be very useful as well
quake74 is offline
Old 9th January 2006, 10:38   #37  |  Link
Doom9
clueless n00b
Yes but I dare presume 2 tracks is sufficient for most people. After all, you are likely to only watch the movie with the commentary track once, so that can be done off the DVD, and that leaves two tracks for you Even though I speak 4 languages fluently, I'd never consider keeping more than two tracks in a backup (which after all is just that.. the original DVD is stored away safely and still in my posession). Generally when taking something on the road, a single track will even suffice.
Doom9 is offline
Old 9th January 2006, 13:14   #38  |  Link
berrinam
berrinam's Avatar
I've updated the list of all feature requests on the first post. If I have missed anything, or you feel I haven't done your request justice, please tell me.
berrinam is offline
Old 9th January 2006, 21:24   #39  |  Link
Raithmir
Time stamping in the logs for the start and end of each job please
Raithmir is offline
Old 9th January 2006, 21:25   #40  |  Link
Doom9
clueless n00b
You already have that in the queue, a precise time down to the second. Why would you need anything else?
Doom9 is offline
