Old 6th January 2006, 18:28   #21  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
as doom9 said add ConverToYV12() at the end of your avisynth script.
Sharktooth is offline
Old 6th January 2006, 18:38   #22  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
The command is ConvertToYV12(). If the source is interlaced, be sure to use ConvertToYV12(interlaced=true)
Richard Berg is offline
Old 6th January 2006, 18:41   #23  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Ok, I will try with that.
Live long and prosperLive long and prosperLive long and prosper
Romario is offline
Old 6th January 2006, 20:26   #24  |  Link
charleski
charleski's Avatar
Another bug:
MP3 audio output is disrupted: If you select MP3 as an output format in the main form and then go to configure it, on returning the format is reset to NAAC mp4.
I'll fix this.
[Fixed in 0.2.3.1037 - turns out it was an issue with rogue profiles with empty names]
charleski is offline
Old 6th January 2006, 20:32   #25  |  Link
charleski
charleski's Avatar
Originally Posted by Romario
DirectShowSource is " probably the most dangerous source loading command AviSynth offers ", can you tell me?
DirectShowSource is easily the flakiest part of Avisynth, and the bit I wish the Avisynth developers would work on. In many cases it just doesn't work and returns 'the filter graph manager won't talk to me' errors even though DirectShow is quite capable of rendering the file (this even happens if you feed it a filtergraph previously rendered by graphedit...).
If you have an avi file, then Avisource(<filename>) is probably a more robust method of loading it into Avisynth.
Old 7th January 2006, 02:22   #26  |  Link
Romario
Romario's Avatar
No, I don't have an avi file, only MPEG2 files.
Can I use Avisource instead DirectShowSource, for mpg files?
Romario is offline
Old 7th January 2006, 02:39   #27  |  Link
berrinam
berrinam's Avatar
For mpg files, use index them with DGIndex first, and then use mpeg2source. MeGUI will do this automatically for you. Go to Tools->D2V Creator, select your input file, and check the other settings, check 'On completion load files', then press queue. Run the job from the main window. You can now configure your file properly.
berrinam is offline
Old 7th January 2006, 16:23   #28  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
In x264 config, setting the turbo option in a first pass mode changes GUI options (macroblock options) which it shouldn't
Description : Checking turbo will get rid of all macroblock options (correct), but unchecking it will leave it that way (incorrect). Also, the P4x4 option is diasbled after unchecking turbo.
Status : Fixed in 1040
Old 7th January 2006, 16:37   #29  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Will this update show commandline also?
(And dont worry, files.x264.nl is being fixed with some updates and have stuff load @ startup, last uptime 300+ days, now power outage also )
bob0r is offline
Old 7th January 2006, 22:30   #30  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
What you mean?
Old 8th January 2006, 02:45   #31  |  Link
jmk
autocrop and AR autodetect
i hve a problem with the autocrop feature in the avisynth script generator dialog. somehow it can not find the right crop values for "2001: a space odyssey". how does it work anyhow?
and another thing thats odd: i recently started using the "SAR" feature. what i do is that i select "auto-detect" aspect ratio on one click mode (since i have some odd ones here, "2001..." for example seems to have the actual ar of 2,15:1). so far everything seems fine. if i check the final muxed files with mp4box -info i can see the that the video track has an aspect ration set. but somehow these values are to large for mplayer or vlc for example:
Track # 1 Info - TrackID 1 - TimeScale 25 - Duration 01:22:16.560
Media Info: Language "und" - Type "vide" - Sub Type "avc1" - 123412 samples
MPEG-4 Config: Visual Stream - ObjectTypeIndication 0x21
AVC/H264 Video - Visual Size 640 x 384 - Profile Unknown @ Level 5.1
Pixel Aspect Ratio 640:1067 - Indicated track size 640 x 384
Self-synchronized
thx for this grat program,
jmk
ps: can anyone explain, or point me in the right direction, how i can change the aspect ratio in these files? and why does it say 640:1067 and not something like 2,35:1 ???
jmk is offline
Old 8th January 2006, 03:06   #32  |  Link
berrinam
berrinam's Avatar
@jmk: You haven't given enough information. Read the guidelines in the first post of this thread.
Just clearing up a few other things:
-auto-detect in oneclick is actually supposed to read Auto-Detect Later, but the end of it is chopped off. You see, there are two stages at which the Aspect Ratio can be found out: immediately, when you load the file, or later, after you've pressed Go, and it's done some processing. Now, normally, it will detect the Aspect Ratio immediately upon loading the file, and set it to the correct value (ie 16:9, 4:3, 1:1), but if something goes wrong, then it will default to Auto-Detect Later. If you think it is detecting it wrong, then it is probably set wrong on the DVD. In that case, what you want to use is the 'Custom' option, so that you can enter 2.35 yourself. If you are sure that it is correct on the DVD, then post a MeGUI bug report with everything asked for on the first post of this thread.
-You don't seem to be aware of the difference between Pixel Aspect Ratio (PAR) and Aspect Ratio, or Display Aspect Ratio. There are links about it Q17 of the x264 FAQ on the x264 win32 daily builds sticky.
berrinam is offline
Old 8th January 2006, 03:12   #33  |  Link
Doom9
clueless n00b
and as far as autocrop goes.. you know we need a vob sample to reproduce that but I'm not ruling out the code works for everything.. for instance your black bars could be less than black (for instance if you pick the wrong color range in dgindex), or if you have a lot of black scenes, the algorithm can't tell between what's black bars and what's part of the movie..
Doom9 is offline
Old 8th January 2006, 09:34   #34  |  Link
nurbs
Since I haven't used autocrop lately I don't know if this is still an issue, but I noticed that on pictures that it should not crop at all it always crops 2 pixels form the right. I'm sorry I couldn't check, but I just read this and I am not at the PC I use for encoding till friday.
nurbs is offline
Old 8th January 2006, 11:16   #35  |  Link
berrinam
berrinam's Avatar
Cropping must be in multiples of two, and autocropping favours over-cropping by one line to under-cropping by one line, so as to ensure removal of the borders. Perhaps this is causing what you are talking about. OTOH, it could actually be a bug. I'll wait for confirmation of this.
berrinam is offline
Old 8th January 2006, 18:41   #36  |  Link
Doom9
clueless n00b
In the x264 config, starting from the default settings, if you uncheck chroma, the commandline doesn't update. The same goes for bime.. seems showcommandline isn't called when those two options are changed.
Doom9 is offline
Old 8th January 2006, 18:49   #37  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
I already fixed that... how come it's back?
It's now re-fixed... and CVS is updated
Old 9th January 2006, 22:02   #38  |  Link
Raithmir
0.2.3.2001 - AVISynth creator
Should enabling the deinterlace, noise filter, and colour correction tick boxes load the appropriate dll in the script for you? It doesn't for me, hence I just get a black narrow band when previewing the script. Using the load dll bit on the edit tab I would expect to just add the relevant load line to the existing script, but it deletes everything else.
MPEG2 deblocking checkbox does nothing?
ticking IVTC checkbox, then ticking the deinterlace box should remove the IVTC settings and add the selected deinterlace option, but it keeps the IVTC settings.
When does the AVI options section get enabled? or is that a future feature?
Raithmir is offline
Old 9th January 2006, 22:08   #39  |  Link
Raithmir
Loading the MeGUI snow version complains about the video profiles on startup ("is this a valid profile?" etc.).
Raithmir is offline
Old 9th January 2006, 22:44   #40  |  Link
berrinam
berrinam's Avatar
Not everyone agrees on this, but in the current mode of operation, it shouldn't. The AviSynth plugins directory is very useful, and if you put your plugins there (why wouldn't you?), you don't need the loadplugin lines.
Bug confirmed and added to the list
Not true. It's called mpeg2 deblocking because it is only for mpeg2 sources. Have a look at the mpeg2source(...) line when you press it -- it adds 'cpu=4'.
Confirmed and added to the list
When you load an AVI file.
Only for non-Snow profiles. It makes sense, doesn't it? Why should MeGUI-Snow be able to load x264/xvid/lavc profiles? If you want that functionality, use the full version.
berrinam is offline
