Old 19th January 2006, 12:21   #201  |  Link
Gehenna
Network XXIII
Gehenna's Avatar
Im getting the same error as AMED,i think the problem could lie here
Command line from my custom NAAC
Build 0.2.3.2024
"C:\Program Files\MP3 Utils\BeSweet\BeSweet.exe" -core( -input "G:\DVD\02x25\VTS_02_PGC_01_1 T01 3_2ch 448Kbps DELAY 0ms.ac3" -output "G:\DVD\02x25\VTS_02_PGC_01_1 T01 3_2ch 448Kbps DELAY 0ms.mp4" -logfile "G:\DVD\02x25\VTS_02_PGC_01_1 T01 3_2ch 448Kbps DELAY 0ms.besweet.log" ) -azid( -s stereo -c normal -L -3db ) -bsn( -2ch -vbr_internet -codecquality_high -aacprofile_lc ) -ota( -g max )
Build 0.2.3.2033
This part is missing "C:\Program Files\MP3 Utils\BeSweet\BeSweet.exe" in build 2033
Asus PC-DL | 2 x Xeon 3.06@3.52 | 2GB OCZ PC4000 | Raptors x 2 RAID 0 | 6800Ultra | ATA2400a RAID 5 | Watercooled | Vista Ultimate 32bit | StaxRip 1.0.0.1
Gehenna is offline
Old 19th January 2006, 13:23   #202  |  Link
Richard Berg
developer wannabe
Richard Berg's Avatar
I tracked down AMED's messagebox, worried because it originates from my new error checking code. Turns out it's not my bug
In MeGUI.getDelay(), fix this line:
// wrong: string delay = openFileDialog.FileName.Substring(start + 6, openFileDialog.FileName.LastIndexOf("ms.") - start - 6);
string delay = fileName.Substring(start + 6, fileName.LastIndexOf("ms.") - start - 6);
AMED: please confirm that it does not happen if you rename your audio file to not have "delay" in the name.
Richard Berg is offline
Old 19th January 2006, 13:28   #203  |  Link
Doom9
clueless n00b
Thanks for an insightful report.. I'm afraid this is most likely an error on my part.. I can verify when I get home.
Doom9 is offline
Old 19th January 2006, 14:35   #204  |  Link
stax76
staxrip & mpv.net
Not necessary better but a different approach:
public int ExtractDelay(string value) {
    Match m = Regex.Match(value, @"(-?\d+)ms\.");
    if (m.Success) return int.Parse(m.Groups[1].Value);
    return 0;
staxrip is in need of a new maintainer since I would like to retire.
stax76 is offline
Old 19th January 2006, 16:25   #205  |  Link
Doom9
clueless n00b
Well.. somebody moved around stuff and it wasn't me.. I still recognize my openDialog
@stax: while I have no doubt it does the same, it is incomprehensible for anybody not familiar with regexps.. that's why I think they are to be avoided at all cost. Regexps all but kill Perl and invite people to write code nobody else can comprehend. While that may be good for job security, there are also the obvious drawbacks of such an approach.
Doom9 is offline
Old 19th January 2006, 21:47   #206  |  Link
AMED
AMED's Avatar
When i change the filename from VTS_02_1 T01 2_0ch 192Kbps DELAY -15ms.ac3 to VTS_02_1 T01 2_0ch 192Kbps.ac3, the unsupported configuration error box does not appear.
AMED is offline
Old 19th January 2006, 21:49   #207  |  Link
Morte66
Flying Skull
Morte66's Avatar
When you hit "Auto Encode" on the "Input" tab with no audio file selected, then check "Add additional content" on the "Automatic Encoding" dialogue and hit "Queue", there is an error launching the "Mux" dialogue. It pops up a message to say "Problem with audio input filename: The path is not of a legal form." Of course, at this point you have not selected any audio (since you are e.g. muxing original AC3 without encoding it).
You can just ignore the message, select sound/subtitles/chapters, and hit "Go". The output filename is disabled so you can't change it, but it loads the mux job in the queue with the default name.
Morte66 is offline
Old 20th January 2006, 10:24   #208  |  Link
Doom9
clueless n00b
@Richard: what morte66 reports.. could it be caused by the changes you've made? I know when I wrote this I tested it and I don't recall making changes there
Doom9 is offline
Old 20th January 2006, 15:07   #209  |  Link
Richard Berg
developer wannabe
Yes. I had it call my filename error checking during AutoEncode. Is it legal to AutoEncode w/o audio? What is it supposed to do?
Old 20th January 2006, 15:13   #210  |  Link
Doom9
clueless n00b
Yes it is..
if (noAudio2BeEncoded && noAudioToBeMuxed)
bitrate = calculateBitrate (for the given container given the desired target size... make nothing if the "don't care" flag is set for bitrate)
if (noAudio2BeEncoded && audioToBeMuxed)
bitrate = calculatebitrate(target size - audio size - audio muxing overhead )
if (audioToBeEncoded)
just create jobs and write the desired target size in the video job so that once we switch from audio to video, we can recalculate the bitrate.
Doom9 is offline
Old 20th January 2006, 17:53   #211  |  Link
digidragon
digidragon's Avatar
When deleting some jobs from the queue, I got an error (MeGui 0.2.3.2033):
Fatal error
MeGUI encountered a fatal error and has to close. Reason: The given key was not present in the dictionary. Source of exception: mscorlib stacktrace:    at System.ThrowHelper.ThrowKeyNotFoundException()
   at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
   at MeGUI.MeGUI.deleteJobButton_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
OK
Although it said it had to close, it didn't.
BTW, this was when deleting some duplicate jobs (jobs 2 through 4) - jobs 1-1, 1-2, and 5 would have remained afterwards.
digidragon is offline
Old 20th January 2006, 20:07   #212  |  Link
Doom9
clueless n00b
@digidragon: can you be more specific as how anybody can reproduce this scenario? Start out with a vanilla MeGUI build (extract it to another directory), then set up jobs and try to make it crash again.. that's what we need to reproduce and identify the problem.
Yippie.. my code to catch fatal flaws works... I was never sure since I hardly manage to crash it anymore.
Doom9 is offline
Old 20th January 2006, 20:57   #213  |  Link
digidragon
digidragon's Avatar
Well, it was actually a virgin install...
I just loaded an avisynth script. I added the video to the queue (avc-mp4). Then I tried to add the audio (ac3->FAAC) to the queue. But it complained that the input/output formats were incompatible. I altered some parameters and tried to queue it again, but had the same error. I tried again, but got the same error. I tried yet again, and finally it seemed to work. But then I noticed that although it had given me the incompatibility errors, it had actually added all those the jobs to the queue. That's why I deleted the duplicate jobs mentioned in my above post.
Old 20th January 2006, 21:41   #214  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Not really a bug, but just pointing this warning out again:
dimzon creates them, sharktooth fixes them (just to promote one megui version here comes):
megui-x264-svn.exe
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
SettingsForm.cs(111,25): warning CS0169: The private field 'MeGUI.SettingsForm.textBox3' is never used
SettingsForm.cs(112,23): warning CS0169: The private field 'MeGUI.SettingsForm.label3' is never used
SettingsForm.cs(113,24): warning CS0169: The private field 'MeGUI.SettingsForm.button3' is never used
SettingsForm.cs(114,25): warning CS0169: The private field 'MeGUI.SettingsForm.textBox2' is never used
SettingsForm.cs(115,23): warning CS0169: The private field 'MeGUI.SettingsForm.label2' is never used
SettingsForm.cs(116,24): warning CS0169: The private field 'MeGUI.SettingsForm.button2' is never used
SettingsForm.cs(117,25): warning CS0169: The private field 'MeGUI.SettingsForm.textBox1' is never used
SettingsForm.cs(118,23): warning CS0169: The private field 'MeGUI.SettingsForm.label1' is never used
SettingsForm.cs(119,24): warning CS0169: The private field 'MeGUI.SettingsForm.button1' is never used
"SettingsForm.cs 1.19 dimzon lame/faac/neroaac path selection some little code cleanup"
EDIT:
DOH that was irontic:
http://forum.doom9.org/showthread.ph...938#post771938
Bloody slow SF CVS
bob0r is offline
Old 20th January 2006, 22:34   #215  |  Link
puffpio
Not a bug, but warning
Using megui 0.2.3.2033
Created a cbr mp3 w/ megui, created an xvid avi w/ megui using the mencoder program.
When I tried muxing them together with the avi muxer, I selected the audio and video, chose CBR for audio, and when I added it to the queue, I get an error saying the avi could not be loaded...a problem with loading the avi and to check the avs script (even though the avi I'm loading i an avi..not avs)
However the job still added to the queue and I was able to mux succesfully
puffpio is offline
Old 20th January 2006, 22:39   #216  |  Link
puffpio
When loading an avs file into the program, then going into the bitrate calculator, the video length, framerate, and framecount is incorrect
This occurs both when I loaded an avs script taht was @ 29.97fps and also at 23.97fps. In both cases the framerate the bitrate calculator displayed was 25fps, and the video length was short by a couple minutes.
It used to work correctly a couple versions ago...maybe I need to delete some configuration files?
puffpio is offline
Old 20th January 2006, 22:50   #217  |  Link
Doom9
clueless n00b
I suspect the fps reported is not exactly 23.976 anymore.. did you recently upgrade dgindex or avisynth? those changes aimed at getting around QT's and mplayers inability to play all kinds of MP4 files were bound to break other applications...
Doom9 is offline
Old 21st January 2006, 03:20   #218  |  Link
puffpio
ahh..yeah im running the latest beta of dgindex..i'm running 2.56 of avisynth
o well..not a big problem..i just get the framecount by opening the avs in vdub..and i know what the framerate is, so I can just it manually
puffpio is offline
Old 21st January 2006, 16:21   #219  |  Link
The Link
The Link's Avatar
A bug I reported here.
When birds burp, it must taste like bugs! (Calvin&Hobbes)
The Link is offline
Old 21st January 2006, 16:44   #220  |  Link
Richard Berg
developer wannabe
@Doom9 - here is a patch to fix the two bugs we discussed. Please review.
http://richardberg.net/bin/temp/file...g-bugfixes.rar
