Old 10th March 2006, 12:01   #141  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Originally Posted by tebasuna51
With aac 5.1 sometimes make a wav6 with all channels equal to a distorted Center channel, and sometimes
Can you provide small samples to send it to BASS developers?
dimzon is offline   Reply With Quote
Old 10th March 2006, 13:25   #142  |  Link
dimzon
dimzon's Avatar
I'm planning to write AudioLimiter plugin
output = tahh(input*factor) / tanh(factor)
factor = 1
factor = 1.5
factor = 2
factor = 3
factor = 4
Does anybody know another sutable formulas?
Old 10th March 2006, 15:31   #143  |  Link
dimzon
dimzon's Avatar
Yet another filter to play with / test - AudioLimiter
http://forum.doom9.org/showthread.php?t=108470
Old 10th March 2006, 16:45   #144  |  Link
tebasuna51
tebasuna51's Avatar
Here is: Test6HE.7z
The source Test6HE.aac is decoded ok by Foobar v0.8.3 for instance.
Old 10th March 2006, 17:53   #145  |  Link
dimzon
dimzon's Avatar
Here is: Test6HE.7z
please test this binary with your AAC
http://www.un4seen.com/filez/2/bass_aac.dll
Old 10th March 2006, 23:08   #146  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, same output.
Works for you?
Old 11th March 2006, 14:39   #147  |  Link
gino25
i try to transcode a file wav (44100 hz, mono) into a aac+ 16kbps.
In [1] i select my wav file as "Wavsource", in [2] and [3] all are empty. In [4] i select aac+ 16kbps as adts aac
but i have this error
Starting job bri.wav->bri.aac
Error: BeHappy.AviSynthException: Script error: there is no function named "AudioDubEx"
at BeHappy.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env)
at BeHappy.Encoder.encode()
gino25 is offline   Reply With Quote
Old 11th March 2006, 14:39   #148  |  Link
gino25
ah this is the avc generated by behappy
#Created by BeHappy v0.1.0.28107
#Creation timestamp: 11/03/2006 14.39.50
#Source FileName:C:\Documents and Settings\Enea\Desktop\bri.wav
#Target FileName:C:\Documents and Settings\Enea\Desktop\bri.aac
# [Source: WavSource]
WavSource("C:\Documents and Settings\Enea\Desktop\bri.wav")
EnsureVBRMP3Sync() # Some black magic to avoid desync
# [BeHappy: Create fictive 1000fps video for triming]
AudioDubEx(BlankClip(length=Int(1000*AudioLengthF(last)/Audiorate(last)), width=32, height=32, pixel_type="RGB24", fps=1000), last)
# [Encoder: Coding Technologies AAC+ @ 16 kbps as ADTS AAC]
# [BeHappy: Kill video]
AudioDubEx(Tone(), last)
Old 11th March 2006, 15:09   #149  |  Link
dimzon
dimzon's Avatar
@gino25
instal AviSynth 2.56
Old 12th March 2006, 17:38   #150  |  Link
gino25
@gino25
thank you
Old 14th March 2006, 07:26   #151  |  Link
3dsnar
3dsnar's Avatar
factor = 1
factor = 1.5
factor = 2
factor = 3
factor = 4
Dimzon, I will send you a code for a limiter constructed from a sine glued with a linear section. It also has a limiting
knee that can be adjusted. Morover, this always limits to [-1, 1] range and up to some signal level is linear (no harmonic distortion).
Aud-X MP3 5.1 Format
3dsnar is offline   Reply With Quote
Old 15th March 2006, 15:49   #152  |  Link
dimzon
dimzon's Avatar
@tebasuna51
Please, test my AudioLimiter filter http://forum.doom9.org/showthread.php?t=108470
What does You think, does it acceptable to use it for DRC?
Old 16th March 2006, 03:52   #153  |  Link
tebasuna51
tebasuna51's Avatar
@tebasuna51
I'm not a expert in DRC, but I think if DRC algorithms use parameters like attack and dekay is for good reasons.
A instant volume conversión with simple math formulas produce distort output like you can see in this image.
With a frequency analysis you can see the audible overtones, not present using more sophisticated algorithms:
Frequency Analysis.
For me the DRC is only useful with ac3 or dts sources, and this work ok with your modified NicAaudio.dll. For others uses the compand Sox function still work better than this AudioLimiters.
Old 16th March 2006, 07:08   #154  |  Link
3dsnar
3dsnar's Avatar
Frequency Analysis.
Tebasune51 is right. The limiter (or also called soft clipper) is usually used to make the hard clipping effect more listenable. It is a useful tool, so it is good to have it. It also can be viewed as the simplest form of compressor.
However, for compressing the amplitude of the signal, usually a dynamic compressor is used (with the attack phase, release phase, compression ratio, and other parameters).
Dimzon, I have implemented in the past a very high quality (very low harmonic distortions) compressor for some pro-audio applications, and the code belongs to me (personally). I will have to just clean it a bit and will provide you with it. So you will be able to use it as open source, or in whaterver way you prefer. So I will get back with this to you soon.
Old 16th March 2006, 09:31   #155  |  Link
dimzon
dimzon's Avatar
@3dsnar
Thanx a lot
@3dsnar, @tebasuna51
http://en.wikipedia.org/wiki/Amplitude_compression
I'm just trying to reproduce BeSweet's custom boost modes (LigH/Tera/DSPGuru) - there are no attac/decay parameters for it, seems like they are just limiters. Custom boost modes + additional AC3 DRC is last to cover all BeSweet functionality...
Old 16th March 2006, 17:38   #156  |  Link
tebasuna51
tebasuna51's Avatar
Really I never use the Boost BeLight section. I make some test with default values in BeLight:
- DSPguru method -boost( /b2=4 /l=0.95 ): Broken for input values > -7.16 dB. Don't need emulate.
- Tera method -boost( /b3=5 /l=0.95 ): low range values very amplified. Not similar behavior with your AudioLimiter functions.
- LigH method -boost( /b=3 /l=0.95 ): This method can be emulated with ExpotencialLimiter(2.4) with light differences.
All values are peak (-) dB
Met\Input  46.6 40.8 36.0 31.2 26.4 21.6 16.8 12.0 10.45  7.2  2.40
Tera_norm  30.3 25.6 21.1 16.8 12.7  9.1  6.0  3.5  2.85  1.7  0.45
LigH_norm  37.3 31.2 26.4 21.6 16.9 12.2  7.7  3.9  2.85  1.2  0.14
Expot 2.4  37.6 32.6 27.5 22.2 16.8 11.4  6.7  3.2  2.44  1.2  0.24
Expot 2.0  39.0 34.1 29.1 23.9 18.6 13.4  8.5  4.6  3.60  1.9  0.43
Expot 3.0  35.6 30.5 25.3 19.9 14.3  8.9  4.6  1.9  1.33  0.6  0.10
Old 16th March 2006, 17:58   #157  |  Link
dimzon
dimzon's Avatar
@tebasuna51
Thanx a lot
Does anybody know good free math-modeling software (free MathLab analogue)?
Old 16th March 2006, 18:02   #158  |  Link
dimzon
dimzon's Avatar
found very interesting site
http://musicdsp.org/
Old 16th March 2006, 18:18   #159  |  Link
dimzon
dimzon's Avatar
Yet another fine link http://www.dspguru.com/sw/opendsp/mathclo2.htm
Old 16th March 2006, 18:29   #160  |  Link
dimzon
dimzon's Avatar
fine, found some free matlab replacement
http://www.scilab.org/
will try it tonight
behappy
