#1 | Link |
BeHappy/MeGUI developer
BeHappy - AviSynth based audio transcoding tool (UPD 19-07-2006)
![]() Use-Case BeHappy is designed mostly for movie audiotrack transcoding. It's powerfull BeLight/BeSweet replacement. So do not ask me about:
Screenshots ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() System requirements
Installation
Original idea Workspace is hosted @ ![]() Note MeGUI since v 0.2.3.2038 23 Jan 2006 share same code with BeHappy. So you can use MeGUI for audio encoding via AviSynth too. MeGUI audio part has less functionality/flexibility but is more stable Mini FAQ: TODO
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS Last edited by dimzon; 19th July 2006 at 02:07. |
#2 | Link |
*** READ THIS: actualized 2008-02-05 ***
- BeHappy Workspace link don't work because GotDotNet Workspaces have been phased out. - New BeHappy home: CodePlex BeHappy project with last mod's included. ------------------------------------------ *** Now the original post *** ------------------------------------------ Good job, Dimzon! For me work the 'Delay', 'Split', 'Downmix', ... Only with the 'Upmix' I get always: Error: Can't find audio stream! Please be patient with me, because I have a lot of comments: Questions In Avisynth internal plugin info say SuperEq(string filename), then wait for a parameter like this: SuperEq("C:\Equalizer Presets\Loudness.feq") Can work SuperEq(clip, values="0 0...96...0")? In Upmix using Reverberation you put the plugin reverb(). Is a external plugin and need be downloaded? EnsureVBRMP3Sync(). We can work with mp3 audio?. Is not necessary a decoder first to work with uncompressed audio? If is possible, EnsureVBRMP3Sync() must be before AudioDubEx(BlankClip(...)) or after? Petitions With buttons 'New' and 'Edit' in Source, DSP and Destination we can test others decoders, DSP functios and encoders. Please include the Downmix - DPL I, like DPL II but: ssr = MixAudio(sl, sr, 0.2222, 0.2222) ssl = Amplify(ssr, -1.0) Bugs The last buffer send to the encoder can be incomplete but is send complete, then there are extrabytes at end. The RiffChunkSize in wav header is incorrect. A example (without DSP), the same Input.wav and three outputs: Code:
Input.wav (with correct classical wav header) -------------- FileLength ..: 1920044 bytes RiffChunkSize: 1920036 Ok = FileLength - 8 = DataLength + 36 DataLength ..: 1920000 Duration ...: 10.000000 sec. Output.wav (RiffChunkSize error, Extrabytes at end of file) -------------- FileLength ..: 1933356 bytes RiffChunkSize: 1920450 Error: Must be FileLength - 8 = 1933348 DataLength ..: 1920000 Warning: ExtraBytes at end of file, bytes = 13312 Duration ...: 10.000000 sec. (with DataLength Ok, extrabytes are ignored) Output.dat (Raw PCM, without header) -------------- FileLength ..: 1933312 bytes Duration ...: 10.069333 sec. Error: Extrabytes interpreted as data Output.ogg -------------- Duration ...: 10.069333 sec. Error: Extrabytes interpreted as data m_nSizeInBytes = m_nSampleCount * nBlockAlign is > 2^32, then we need a int64 variable in source code. Last edited by tebasuna51; 14th September 2009 at 02:08. Reason: Deleted link to Shon3i package because donīt wok with actual BeHappy versions |
#4 | Link | ||
@tebasuna51
Upmix is not forking yet, this is just algorytm, not working script yet! EnsureVBRMP3Sync - I think it must be right after decoder. I believe this is just buffering to avoid desync and it can be used with any source type (maybe i'm wrong?) Petitions Quote:
Creating new Source Use nicaudio.extension as starting point for new source. Copy it to yorsource.extension and open via notepad. Don't forget to generate new UUID(GUID) for UniqueID attribute Edit Name attribute and Edit <Script> element {0} means input file name {1} means output file name {2} means unique string (to use as part of identifier) {3} means '{' character (to allow '{' to be used) {4} means '}' character (to allow '}' to be used) Add/Delete/Edit <SupportedFileExtension> element Sample: Code:
<?xml version="1.0"?>
<BeHappy.Extension
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://workspaces.gotdotnet.com/behappy">
<AudioSource Name="MySourceName" UniqueID="5D209A6D-E6EA-4640-AF60-BAE14A529792">
<Script>SomeSource("{0}")</Script>
<SupportedFileExtension>ext1</SupportedFileExtension>
<SupportedFileExtension>ext2</SupportedFileExtension>
<SupportedFileExtension>ext3</SupportedFileExtension>
</AudioSource>
</BeHappy.Extension>
There are 2 ways to create simple DSP: Creating very simple DSP Example: Code:
<BeHappy.Extension
<AudioDSP Name="Normalize to 100%" UniqueID="6158f79f-d8a0-4021-89ae-b77b37c04c55">
<Script>
# Some script:
Normalize()
</Script>
</AudioDSP>
Take look @ DownMix.extension and UpMix.extension - good examples of multioption DSP Code:
<BeHappy.Extension
<AudioDSP UniqueID="9579E57B-2D27-4583-99A4-921718E25B41">
<Plugin>
<MultiOptionDSP Type="BeHappy.Extensions.MultiOptionDSP, BeHappy">
<TitleFormatString>DSP Name, Selected Option = {0}</TitleFormatString>
<ScriptPrologue>
# ScriptPrologue
# this part of script will be included in resulting script without any conditions
# {0} means input file name
# {1} means output file name
# {2} means unique string (to use as part of identifier)
# {3} means '{' character (to allow '{' to be used)
# {4} means '}' character (to allow '}' to be used)
</ScriptPrologue>
<Option>
<Name>Option Name 1</Name>
<Value>
# this part of script will be included in resulting script only if this option is selected
</Value>
</Option>
<Option>
<Name>Option Name 2</Name>
<Value>
</Value>
</Option>
<Option>
<Name>Option Name 3</Name>
<Value>
</Value>
</Option>
<Option>
<Name>Option Name 4</Name>
<Value>
</Value>
</Option>
<Option>
<Name>Option Name 5</Name>
<Value>
</Value>
</Option>
<Option>
<Name>Option Name 6</Name>
<Value>
</Value>
</Option>
<Option>
<Name>Option Name 7</Name>
<Value>
</Value>
</Option>
<ScriptEpilogue>
# ScriptEpilogue
</ScriptEpilogue>
</MultiOptionDSP>
</Plugin>
</AudioDSP>
Creating new Destination is very close to new Source. Take look @ ffmpeg-ac3.extension, enc_aacPlus.extension, wavpack.extension, flac.extension <ExecutableArguments> {0} means output file name {1} means samplerate in Hz {2} means bits per sample {3} means channel count {4} means samplecount {5} means size in bytes Example: Code:
<BeHappy.Extension
<AudioEncoder Name="EncoderName" UniqueID="83517DA6-B34F-45ee-B48C-5D9370CC6032">
<Script>#Some script to be used for this encoder</Script>
<ExecutableFileName>encoder.exe</ExecutableFileName>
<ExecutableArguments>- "{0}" --cbr 32000</ExecutableArguments>
</AudioEncoder>
If you are familiar with .NET you can create really fine and complex extension. Take look @ BeHappy.OggVorbis.Encoder.Extension project. You must:
PS. One *.extension can contain any amount of DSP Source and Encoder at same time
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS Last edited by dimzon; 28th December 2005 at 13:44. |
#5 | Link |
fresh beta out
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS Last edited by dimzon; 23rd May 2006 at 22:22. |
#6 | Link | |
Now I'm using such workaround: Code:
int nHowMany = Math.Min((int) (m_aviStreamInfo.dwLength-frameSample), MAX_SAMPLES_PER_ONCE) ; AVIStreamRead(m_aviStream, frameSample, nHowMany, h.AddrOfPinnedObject(), frameBufferTotalSize, out bytesRead, out samplesRead);
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
#7 | Link |
Nero7 AAC encoder extension is avaluable
![]() download it @ workspace @ gotdotnet.com
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS Last edited by dimzon; 28th December 2005 at 20:00. |
#8 | Link | ||||
Thanks for your rapid and large answer. I have a lot of work to do.
First I want answer your questions. Quote:
http://ccrma.stanford.edu/courses/42...ts/WaveFormat/ Quote:
The faad decoder (aac) can generate 'invalid' wav's > 4 GB, and fill these fields (RiffLength and DataLength) with 0xFFFFFF00. Foobar also make 'invalid' wav's > 4 GB, and fill these fields with the 4 low order bytes. Really the only way, afaik, to use a wav > 4 GB is split it in mono wav's. Then Tranzcode, WaveWizard and BeSplit can generate valid (not for BeSplit because a bug in BlockAlign field) mono wav's with the original length. The method is ignore these fields and continue working until end of file. I prefer the faad method (0xFFFFFF00) because Foobar method can be confused with valid fields. Quote:
Int64 nByteSize = streamSampleLength * m_WavHeader.nBlockAlign; target.Write(BitConverter.GetBytes((uint)Math.Min(nByteSize,uint.MaxValue)),0,4); In the actual version, the variable with possible overflow is used also in: Code:
private uint m_nSizeInBytes; ... m_nSizeInBytes = m_nSampleCount*m_wavHeader.nBlockAlign; // may be > 2^32 ... private void createEncoderProcess() ... info.Arguments = string.Format(m_commandLine, m_output, m_wavHeader.nSamplesPerSec, m_wavHeader.wBitsPerSample, m_wavHeader.nChannels,m_nSampleCount,m_nSizeInBytes); |
#9 | Link | |
private long m_nSizeInBytes;
private void writeHeader(Stream target )
const uint FAAD_MAGIC_VALUE = 0xFFFFFF00;
const uint WAV_HEADER_SIZE = 36;
bool useFaadTrick = m_nSizeInBytes>=(uint.MaxValue-WAV_HEADER_SIZE);
target.Write(System.Text.Encoding.ASCII.GetBytes("RIFF"),0,4);
target.Write(BitConverter.GetBytes(useFaadTrick?FAAD_MAGIC_VALUE:(uint)(m_nSizeInBytes + WAV_HEADER_SIZE)),0,4);
target.Write(System.Text.Encoding.ASCII.GetBytes("WAVEfmt "),0,8);
target.Write(BitConverter.GetBytes((uint)0x10),0,4);
target.Write(BitConverter.GetBytes(m_wavHeader.wFormatTag),0,2);
target.Write(BitConverter.GetBytes(m_wavHeader.nChannels),0,2);
target.Write(BitConverter.GetBytes(m_wavHeader.nSamplesPerSec),0,4);
target.Write(BitConverter.GetBytes(m_wavHeader.nAvgBytesPerSec),0,4);
target.Write(BitConverter.GetBytes(m_wavHeader.nBlockAlign),0,2);
target.Write(BitConverter.GetBytes(m_wavHeader.wBitsPerSample),0,2);
target.Write(System.Text.Encoding.ASCII.GetBytes("data"),0,4);
target.Write(BitConverter.GetBytes(useFaadTrick?FAAD_MAGIC_VALUE:(uint)m_nSizeInBytes),0,4);
#11 | Link |
introducing new feature - Multioption encoder (wait for fresh beta)
#12 | Link |
brainless
I don't know whether you are already doing this:
any_audiosurce() ConvertAudioTo24bit() #or better float or 32bit downmix() / upmix() / normalize() ConvertAudioTo16bit() this should effectively reduce rounding errors.
Don't forget the 'c'! Don't PM me for technical support, please. |
#13 | Link | |
#14 | Link |
New beta is out!
Get it @ workspace @ gotdotnet.com
#15 | Link |
Usually, ac3 to ac3 encodings with besweet (and also with ffmpeg as i heard) has a problem, that resulting ac3 has low volume.
Has BeHappy same problem or does it manage this issue well?
Prodater64 |
#16 | Link | |
#17 | Link |
Hey! Now we can create more advanced DSP using Sox Audio Effect Filter !
#18 | Link |
I need Your help!
2 All
Hi! You can help BeHappy project! I need: New DSP scripts - Dinamyc Range Compression e.t.c BeHappy logo & icons
#19 | Link |
Now BeHappy works Ok with wav header and without extrabytes at end.
I make a test with a source 5.1, 48 KHz (ac3) > 132 min. and BeHappy works Ok for wav > 4 GB and for a transcode to aac. Relevant info of input.ac3 Code:
SampleRate 0 : 48000 KHz. BitRate 15 : 448 Kb/s. Audio coding mode (acmod) 7 : 3/2 - L, C, R, SL, SR Low Frequency Effects channel 1 : Present FileSize : 444358656 bytes. Frames : 247968 Duration : 7934.976 seconds ( 2 h. 12 m. 14.976 s.) Code:
FileSize ....: 4570546220 RiffLength...: 4294967040 (= 0xFFFFFF00) Error: ... (always with > 4GB) NumChannels .: 6 SampleRate ..: 48000 OffsetData ..: 44 DataLength ..: 4294967040 (= 0xFFFFFF00) Warning: assumed Datalength = 4570546176 (FileSize - 44) Duration ...: 7934.976 sec., (2h. 12m. 14.976 s.) behappy.extension.encoder.nero7aac.exe -o "D:\...\132.mp4" -rr 48000 -rb 16 -rc 6 -vbr_streaming -aacprofile_he -codecquality_high Relevant info of output.mp4 (from Foobar2000 v0.8.3) Code:
bitrate = 191 samplerate = 48000 channels = 6 aac_profile = HE AAC codec = AAC tool = Nero AAC Codec 4.2.1.0 samples = 380878848 FileSize = 189,944,318 Bytes (181.15 MB) Length = 2:12:14.976 |
#20 | Link |
What ideas do you have for the logo? (colors, style, some logos you like, etc.)
To buttress the Hun's suggestion: http://www.digitalprosound.com/Htm/S...ap2_Apogee.htm It deals with sample rate, not resolution but the concept still applies, expand to at 2x, preferably 4x, do the modifications, downsample.
Curator of links at http://neuron2.net (Yes, I know it's woefully out of date...) Collecting 9/11, Afghan/Iraq, Mail Call, Trains, Cooking, Woodworking, Fighting Illini |
| Tags |
| behappy |
| Thread Tools | |
| Display Modes | |
