Thread Tools Display Modes
Old 24th November 2005, 01:23   #1  |  Link
IgorC
Xvid 1.2 cvs
http://celticdruid.no-ip.com/xvid/
cleanings in code spotted by sparse (ed dot gomez at free dot fr>
update cvs-head to reflect xvid-1.2 development status:
set build string to "xvid-1.2.0-dev"
set XVID_VERSION to 1.2.-127
set XVID_BS_VERSION to 40
set XVID_UNSTABLE
What's new?
IgorC is offline   Reply With Quote
Old 24th November 2005, 03:00   #2  |  Link
sysKin
sysKin's Avatar
Originally Posted by IgorC
What's new?
Nothing *yet*
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 24th November 2005, 04:05   #3  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
so...we can expect 1.1 final soon right? since dev on 1.2 is started obviously heh
ChronoCross is offline   Reply With Quote
Old 24th November 2005, 18:17   #4  |  Link
DeathTheSheep
<The VFW Sheep of Death>
DeathTheSheep's Avatar
XviD 1.2 started. A fresh new XviD coming up. This is nice...
(*mumbles under breath*insanemodeinsanemodeinsanemode*)
Good luck to the dev.s!
New VfW builds. High quality AVC Guide. Check out DeathTheSheep United today!
DeathTheSheep is offline   Reply With Quote
Old 24th November 2005, 19:12   #5  |  Link
ChronoCross
what do you mean by insane mode? you mean that lame attempt by divx to increase quality by dropping the speed 400% and then do nothing? If so then I will have to say no to that lol. but a new Adapt. Quant would be sweet.
Old 24th November 2005, 20:18   #6  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
well... it's not divx network fault if USERS asked for an "insane mode" some time ago...
Old 24th November 2005, 22:08   #7  |  Link
DeathTheSheep
Ah, whatever do you mean, gentlemen?
(*COUGHcheckthisoutCOUGH*)
Old 24th November 2005, 22:19   #8  |  Link
DeathTheSheep
No, nothing like that at all.
The so-called "Ultra" motion search precision preset doesn't even enable Advanced Diamond 8/16, EXTSEARCH8, etc.
As far as I can tell (and that's not very far, believe me ), a bit more can definately be milked out of it even before we go exhaustive...
Old 24th November 2005, 22:20   #9  |  Link
DeathTheSheep
PS: In my second post in this thread, I gave a link to some Insane mode stuff... and here are my results:
Given these results, it's actually more than a 16% quality increase with Helium [insane mode over balanced mode]. So, a 16% filesize decrease and a 0.1db PSNR increase is absolutely worth it, and such a mode would help XviD tremendously.
Nice thesis, eh?
Old 24th November 2005, 22:52   #10  |  Link
IgorC
Speed of Xvid 1.1 is already lower than of 1.0. But there was a big impovements since then.
However something has happened with Xvid 1.1 beta 1 -> beta 2. Speed has gone down.
Developers said that there was quality improvement for very low bitrate, but for low (middle low >500 kbps) and high bitrates there wasn´t any quality change. SSIM and OPNSR are almost identical for beta 1 and beta 2.
Maybe it can be fixed or reworked.
Implementing of very slow settings shouldn´t be a problem, while they aren´t enabled by default.
Old 24th November 2005, 23:02   #11  |  Link
DeathTheSheep
I think there were a few quality increases for the higher bitrates, too. VHQ for B-frames is the most noticeable, I believe. But you're absolutely right--that's the development path, I suppose. Figure out your priorities then implement them, steadily improving everything else on the way. As development progresses, quality goes up steadily. But in the mean time:
My thoughts exactly
Old 24th November 2005, 23:07   #12  |  Link
IgorC
VHQ for B-frames was already impelemnted in alpsha cvs builds.
I was talking about speed down on beta1 -> beta 2 without any impovements for bitrates >500 kbps .
Old 24th November 2005, 23:15   #13  |  Link
DeathTheSheep
Oh, woopsies I thought you were talkin' 'bout XviD 1 to XviD 1.1. hehe
Yeah, yer absolutely right then.
Yeah, y'all know me, I'm obsessed with low bitrates. I think XviD did something along the lines of logarithmic quantization adjustments for high quants back in beta 2, yeah.
Good stuff. Can we all look forward to any more quality bolsterings in the low-bitrate area or have priorities shifted more to the higher rates?
Old 25th November 2005, 04:42   #14  |  Link
sysKin
sysKin's Avatar
There was defnitely NO code change from beta1 to beta2 that would affect speed.
Old 25th November 2005, 06:10   #15  |  Link
ChronoCross
I never saw a slowdown between the two. I'd like to see improvements to speed through HT/multithreading. the quality is already better than any of the other asp encoders out there.
<Here's where my rant on how I think an INSANE mode is a waste of time was supposed to go>
All I'll say about it is that PSNR isn't a end all be all of measurement for how something looks. Things with lower PSNR values have many many times looked better than things with a higher one. This is back to the arguement that quality is subjective.
Old 25th November 2005, 12:46   #16  |  Link
IgorC
I remember some people said that speed of beta 2 was lower. I also notice it.
http://forum.doom9.org/showthread.ph...ight=beta+slow
And there was hot dicussion about improvements beta 1 -> beta 2.
There was RD changes since beta 1.
I´m agree PSNR isn´t ideal metrics. But SSIM and OPNSR together are good tests. Visually I also can´t see difference between beta 1 and beta 2.
Old 25th November 2005, 13:13   #17  |  Link
sysKin
sysKin's Avatar
OK this is weird, and probably worth checking. However, I was telling the truth - no algorithms changed that would explain this.
I remember a thread about XviD beta2 (I think) not detecting CPU features correcly. If you can reproduce the slowdown, could you check that? Just compare beta2 with auto and manual CPU features.
Yes but these changes were strictly in RD constants (lambda). Just differrent values in the same equations, they can't change speed.
Old 25th November 2005, 15:17   #18  |  Link
sysKin
sysKin's Avatar
OK I'm disappointed with you guys.
One, yes, beta2 is 5% slower at defaults than beta1.
Two, but who cares about it if quality has gone down the drain???
You actually did not catch such a huge regression? :/
Old 25th November 2005, 15:23   #19  |  Link
Didée
He-heheh, at home still using a celtic's build from "before beta2"
What did go wrong with beta2 ?
(edit: Frankly, I can't pretend to actually have spotted a difference, but always had the impression that there was, well, ~something~ about beta2. Guess I'd have gotten tared and feathered when asking about that ...
Poke in the blue: perhaps something with AQ thresholding?)
We´re at the beginning of the end of mankind´s childhood
Old 25th November 2005, 15:26   #20  |  Link
IgorC
Sorry , Syskin. I´m preparing for exams now. Later I will run some video for Beta 1, Bet2 with different cpu flags with diferent setings.
So for what bitrate there is quality change between Beta 2 and Beta 1?
maybe for extreme settings there is no change?
weird
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
