Old 13th November 2005, 23:57   #21  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
leave the width alone. just addborders to reach 704
for NTSC anamorph calculate this:
392/1.2*1.3333 = 436 pixel vertically
bicubicresize(width,436)
addborders(4,22,4,22)
for PAL anamorph
just multiply 392 with 1.3333:
bicubicresize(width,522)
addborders(4,28,4,26)
here the numbers derive from:
PAL -> NTSC: divide the height by 1.2
NTSC -> PAL: multiply the height with 1.2
4:3 Letterboxed to 16:9 anamoprh: multiply the height with 1.333333
16:9 anamoprh to 4:3 Letterboxed: divide the height by 1.333333
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 14th November 2005, 00:55   #22  |  Link
mantis2k
Thanks scharfis_brain, I'll make a note of that for future reference!
BTW, I can't get this restore24 script to work with TMPGEnc, but it works with Virtualdub; anyone please advise?
mantis2k is offline   Reply With Quote
Old 14th November 2005, 08:10   #23  |  Link
Boulder
Pig on the wing
Boulder's Avatar
You shouldn't feed the Restore24 script directly into TMPGEnc, you're only asking for trouble. Save it into a lossless avi (with HuffYUV for example) in VDub and feed that into the encoder.
