Old 28th October 2005, 14:09   #1  |  Link
bond
libavcodec now able to decode custom quant matrices
thanks to akupenguin libavcodec is now able to decode custom quant matrices of avc
i tested it with various cqms with x264 and jm and it seems to work fine
enjoy
Ogg Theora | Ogg Vorbis
Old 28th October 2005, 14:16   #2  |  Link
Sirber
retired developer
Sirber's Avatar
NICE
Gonna add "Low bitrate matrice (AVC)" to RealAnime LE
Mega thanks akupenguin
Detritus Software
Sirber is offline   Reply With Quote
Old 28th October 2005, 14:51   #3  |  Link
IgorC
is this version mplayer already enable to decode cqm? http://ffdshow.faireal.net/mirror/mp...05.10.26.P4.7z
IgorC is offline   Reply With Quote
Old 28th October 2005, 14:52   #4  |  Link
bond
26 oct works
Old 28th October 2005, 15:29   #5  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Yeeeesssssss. =D
Now I get to hand out another bleeding edge ffdshow to everyone for new encodes! Thank you Akupenguin. =D
Old 28th October 2005, 15:40   #6  |  Link
Daodan
unrecognized user
Indeed, this is a nice addition to ffdshow. Hopefully now more custom matrices will appear and I'm really happy I can use now Sharktooth's high bitrate matrix (I usually encode above 1500 kbps) without worries that others won't be able to play it.
zzz
Daodan is offline   Reply With Quote
Old 28th October 2005, 22:15   #7  |  Link
Suchy
Yatta!
Suchy is offline   Reply With Quote
Old 28th October 2005, 22:41   #8  |  Link
max-holz
Good I wait for ffdshow compilation by CelticDruid.
Is it possible using Media Player Classic now?
max-holz is offline   Reply With Quote
Old 30th October 2005, 13:01   #9  |  Link
max-holz
I have tried with this build ffdshow-20051025 Nightly Builds playng a file x264 video codec with CQM, FAAC audio codec in MKV container using Media Player Classic 6.4.8.4 but I got this exception when MPC is opening:
Applicazione che ha provocato l'errore mplayerc.exe, versione 6.4.8.4, modulo che ha provocato l'errore ffdshow.ax, versione 1.0.2.153, indirizzo errore 0x0006f65f.
H.264 -> libavcodec
AAC -> realaac
Old 30th October 2005, 13:22   #10  |  Link
bond
maybe someone simply compiled libavcodec and replaced it with the old one from cd, which is NOT something you can do!
ffdshow needs its own libavcodec compile (from ffdshow cvs)
Old 30th October 2005, 14:25   #11  |  Link
max-holz
Where could I found the latest ffdshow build?
Old 30th October 2005, 17:05   #12  |  Link
Revgen
Go here to download clsid's ffdshow build. It supports cqm.
Revgen is offline   Reply With Quote
Old 31st October 2005, 13:08   #13  |  Link
DeeGee
DeeGee's Avatar
how about new mplayer build?
DeeGee is offline   Reply With Quote
Old 31st October 2005, 13:35   #14  |  Link
bond
we already discussed in this thread that there is a working mplayer build from cd existing already...
Old 31st October 2005, 14:55   #15  |  Link
DeeGee
DeeGee's Avatar
Me == Blind
Old 2nd November 2005, 19:10   #16  |  Link
bob0r
Pain and suffering
bob0r's Avatar
bob0r is offline   Reply With Quote
