Old 26th October 2005, 21:38   #1  |  Link
Malow
In bytes we trust
Malow's Avatar
ffdshow not show vobsub subtitles anymore
hy, i donīt know is this is the place for my question, but, the lasts builds of ffdshow simply doesnot work anymore with idx/sub subtitles... older versions works fine, (like august builds) but lastest one not. sometimes it shows, sometimes disappears after some minutes of playing, but almost not load correctly. i think it will be bad this question in ffdshow development thread...
sorry for the poor/bad/illegible/inmature/wrong english
Malow is offline   Reply With Quote
Old 27th October 2005, 08:04   #2  |  Link
CWR03
Custom User Title
CWR03's Avatar
You can disable ffdshow for displaying subs and just use DirectVobSub.
CWR03 is offline   Reply With Quote
Old 27th October 2005, 23:18   #3  |  Link
Malow
In bytes we trust
Malow's Avatar
but my need is just do keep with ffdshow, to avoid installing vobsub.
besides, vobsub make more cpu utilization....
Old 28th October 2005, 09:35   #4  |  Link
CWR03
Custom User Title
CWR03's Avatar
If you know it doesn't work due to factual data rather than not having it work on your computer, your post would belong in the ffdshow development thread, and until the problem is corrected you'd really have no choice than to use something different. Otherwise, VobSub uses practically no CPU resources.
Old 28th October 2005, 12:40   #5  |  Link
bond
Malow, tell milan about it
Ogg Theora | Ogg Vorbis
