Old 26th October 2005, 13:17   #1  |  Link
jellygumbo
Problem with Bewitched
It appears I have run into a movie I cannot backup? I recently purchased a movie, Bewitched, and tried to back it up but I keep getting errors Below is a copy of the log - 10% finished before erroring out:
I also attached the error in jpg format file.
I 05:04:45 DVD Decrypter Version 3.5.4.0 started!
I 05:04:45 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 05:04:45 Initialising SPTI...
I 05:04:45 Searching for SCSI / ATAPI devices...
I 05:04:45 Found 1 DVD-ROM and 1 DVD±RW!
W 05:04:48 Possible Structure Protection Found!
W 05:04:48 1 area has been marked as 'suspect'.
W 05:04:48 Dummy sectors will be inserted where necessary.
I 05:05:45 Operation Started!
I 05:05:45 Source Device: [0:1:0] SAMSUNG DVD-ROM SD-616E F501 (D (ATA)
I 05:05:45 Source Media Type: DVD-ROM
I 05:05:45 Source Media Region Code: 1
I 05:05:45 Source Media Copyright Protection System Type: CSS/CPPM
I 05:05:45 Source Media Implementation Identifier: SONY DVD Video
I 05:05:45 Destination Folder: C:\DVD Burn\BEWITCHED\
I 05:05:45 File Splitting: By File
I 05:05:45 Remove Structure Protection: Yes
I 05:05:45 Bad Sector Removal Method: Normal
I 05:05:45 Detect Mastering Errors: No
I 05:05:45 Multi Angle Processing: No
I 05:05:45 Remove Macrovision Protection: Yes
I 05:05:45 Stream Processing: No
I 05:05:45 Copying VIDEO_TS.IFO... (LBA: 379290 - 379304) - KEY: N/A
I 05:05:46 Decrypting VIDEO_TS.VOB... (LBA: 379322 - 389232) - KEY: C0 75 9C A2 09
I 05:05:49 Copying VIDEO_TS.BUP... (LBA: 389242 - 389256) - KEY: N/A
I 05:05:49 Copying VTS_01_0.IFO... (LBA: 389274 - 389290) - KEY: N/A
I 05:05:49 Decrypting VTS_01_0.VOB... (LBA: 389291 - 389307) - KEY: C0 75 9C A2 09
I 05:05:49 Decrypting VTS_01_1.VOB... (LBA: 389308 - 684668) - KEY: C0 75 9C A2 09
I 05:07:12 Copying VTS_01_0.BUP... (LBA: 684669 - 684685) - KEY: N/A
I 05:07:12 Copying VTS_02_0.IFO... (LBA: 684686 - 684725) - KEY: N/A
I 05:07:12 Decrypting VTS_02_0.VOB... (LBA: 684726 - 729179) - KEY: D5 CA 6F 01 9D
I 05:07:24 Decrypting VTS_02_1.VOB... (LBA: 729180 - 1253466) - KEY: D5 CA 6F 01 9D
E 05:14:33 Failed to read Sector 737513 - Unrecovered Read Error
E 05:14:34 Failed to decrypt VTS_02_1.VOB!
I 05:14:37 Decrypting VTS_02_2.VOB... (LBA: 1253467 - 1777753) - KEY: D5 CA 6F 01 9D
Last edited by jellygumbo; 26th October 2005 at 13:29. Reason: improper posting title
jellygumbo is offline   Reply With Quote
Old 26th October 2005, 13:22   #2  |  Link
Please follow forum rules, specifically, rule 9: use a proper thread title. Thank you.
Old 26th October 2005, 13:32   #3  |  Link
jellygumbo
Sorry...I changed the title.
Old 26th October 2005, 16:19   #4  |  Link
Imperial Zeppelin
It's a Sony disc so guess what? ARccOS is involved. I used DVDFAB Decrypter on it last night with no hassles after DVD Decrypter puked on it just like yours did.
Imperial Zeppelin is offline   Reply With Quote
Old 26th October 2005, 16:21   #5  |  Link
andyfav
follow this link
http://club.cdfreaks.com/showthread.php?t=153419
or
try with PSL2 generator
or
try with PSL2 plugin for PGCEDIT.
andyfav is offline   Reply With Quote
Old 26th October 2005, 18:24   #6  |  Link
ROSCO1167
I had the same problem and I first used Dvd Fab Decrypter 2.9.5.2 from www.dvdidle.com , then go to free stuff for download. Run it the use DVD shrink. It worked for me.
ROSCO1167 is offline   Reply With Quote
Old 27th October 2005, 00:00   #7  |  Link
ratboy68
I had no problems at all using DVD Shrink 3.2
ratboy68 is offline   Reply With Quote
Old 27th October 2005, 01:00   #8  |  Link
kis2005
DVDFab will work.
kis2005 is offline   Reply With Quote
Old 27th October 2005, 03:49   #9  |  Link
setarip_old
setarip_old's Avatar
@jellygumbo
Hi!
if your copy of "Bewitched" is the Region 1 "Special Edition", load the DVD into DVD Decrypter v.3.5.4 again - and then "Import" (File>>Import PSL)the following PSL2 file (posted at another forum):
PSL2
0:0xA3A4320D,4169919,Bewitched - Special Edition - Region 1
1:729194,729200
1:729215,745825
1:4169650,4169909
6:2,1,3,2,1
6:2,1,3,3,1
6:2,1,3,4,0
6:2,1,6,2,1
6:2,1,6,3,1
6:2,1,6,4,0
6:2,1,7,2,1
6:2,1,7,3,1
6:2,1,7,4,0
6:2,1,8,2,1
6:2,1,8,3,1
6:2,1,8,4,0
6:2,1,9,2,1
6:2,1,9,3,1
6:2,1,9,4,0
6:2,1,10,2,1
6:2,1,10,3,1
6:2,1,10,4,0
6:2,1,11,2,1
6:2,1,11,3,1
6:2,1,11,4,0
6:2,1,12,2,1
6:2,1,12,3,1
6:2,1,12,4,0
6:2,1,13,2,1
6:2,1,13,3,1
6:2,1,13,4,0
6:2,1,14,2,1
6:2,1,14,3,1
6:2,1,14,4,0
6:2,1,15,2,1
6:2,1,15,3,1
6:2,1,15,4,0
6:2,1,16,2,1
6:2,1,16,3,1
6:2,1,16,4,0
6:2,1,17,2,1
6:2,1,17,3,1
6:2,1,17,4,0
6:2,1,18,2,1
6:2,1,18,3,1
6:2,1,18,4,0
6:2,1,19,2,1
6:2,1,19,3,1
6:2,1,19,4,0
6:2,1,20,2,1
6:2,1,20,3,1
6:2,1,20,4,0
6:2,1,21,2,1
6:2,1,21,3,1
6:2,1,21,4,0
setarip_old is offline   Reply With Quote
Old 27th October 2005, 04:17   #10  |  Link
jellygumbo
Thanks guys!! I havent tried the PSL import yet, but I did download and run DVDFAB....worked like a champ. Thanks a million!
Old 28th October 2005, 04:58   #11  |  Link
tjones
I tried all suggestions to no avail; PSL files kept giving the error message stating no PSL on line 0 ??? Please consider advising me on this task. FAB worked fine but shrink would not work kept getting errors.
"the following PSL2 file (posted at another forum):" what other forum ?
tjones
tjones is offline   Reply With Quote
Old 28th October 2005, 05:52   #12  |  Link
jellygumbo
What version of shrink are you using? Did you let FAB extract all files and then open files in shrink?
Coool Tools
Old 28th October 2005, 06:21   #13  |  Link
setarip_old
@tjones
Hi!
Are you (as you should be for using a PSL2 file) using DVD Decrypter v.3.5.4 (NOT an older version) to "Import" the PSL2 file AFTER loading the DVD?
Old 28th October 2005, 11:32   #14  |  Link
starscomeout
Originally Posted by setarip_old
@tjones
Hi!
What is a PSL2 file and where do I import it from?
Don
starscomeout is offline   Reply With Quote
Old 28th October 2005, 12:54   #15  |  Link
tjones
@tjones
Hi!
"What version of shrink are you using? Did you let FAB extract all files and then open files in shrink?" Version 3.2 of Shrink, and yes I did let Fab completely finnish the disk then tried to open as file, only to get error message.
I am Using DVD Decrypter version 3.5.2, for the import I will look for the version 3.5.4.see what happens.
(Installed version 3.5.4 then attempted import, now recieving the error message Initial checks indicate it is not intended for the current disc. (1).)
I am using the same file for PSL2 as posted above.
tjones
Old 28th October 2005, 13:16   #16  |  Link
starscomeout
[QUOTE=tjones]"What version of shrink are you using? Did you let FAB extract all files and then open files in shrink?" Version 3.2 of Shrink, and yes I did let Fab completely finnish the disk then tried to open as file, only to get error message.
I was having all the same problems as stated above. I just figured out how to do the PSL file. Copy and paste the text below to notebook and save it as bewitched.psl .
Insert the movie into your DVD drive and then open DVD DVD Decrypter. Click on File, then Protected Sectors List, and then Import. Go to where you have saved the bewitched.psl and click on it and then on open. This will now allow you to completely rip the whole DVD to your hard drive. When finished you can then open the directory that now contains the complete ripped DVD and then edit it with DVD Shrink.
Don
Copy and paste the following to note and save as bewitched.psl :
PSL2
1:729194,729200
1:729215,745825
1:4169650,4169909
6:2,1,3,2,1
6:2,1,3,3,1
6:2,1,3,4,0
6:2,1,6,2,1
6:2,1,6,3,1
6:2,1,6,4,0
6:2,1,7,2,1
6:2,1,7,3,1
6:2,1,7,4,0
6:2,1,8,2,1
6:2,1,8,3,1
6:2,1,8,4,0
6:2,1,9,2,1
6:2,1,9,3,1
6:2,1,9,4,0
6:2,1,10,2,1
6:2,1,10,3,1
6:2,1,10,4,0
6:2,1,11,2,1
6:2,1,11,3,1
6:2,1,11,4,0
6:2,1,12,2,1
6:2,1,12,3,1
6:2,1,12,4,0
6:2,1,13,2,1
6:2,1,13,3,1
6:2,1,13,4,0
6:2,1,14,2,1
6:2,1,14,3,1
6:2,1,14,4,0
6:2,1,15,2,1
6:2,1,15,3,1
6:2,1,15,4,0
6:2,1,16,2,1
6:2,1,16,3,1
6:2,1,16,4,0
6:2,1,17,2,1
6:2,1,17,3,1
6:2,1,17,4,0
6:2,1,18,2,1
6:2,1,18,3,1
6:2,1,18,4,0
6:2,1,19,2,1
6:2,1,19,3,1
6:2,1,19,4,0
6:2,1,20,2,1
6:2,1,20,3,1
6:2,1,20,4,0
6:2,1,21,2,1
6:2,1,21,3,1
6:2,1,21,4,0
Old 28th October 2005, 13:22   #17  |  Link
tjones
[QUOTE=starscomeout]
Don
PSL2
1:729194,729200
1:729215,745825
1:4169650,4169909
6:2,1,3,2,1
6:2,1,3,3,1
6:2,1,3,4,0
6:2,1,6,2,1
6:2,1,6,3,1
6:2,1,6,4,0
6:2,1,7,2,1
6:2,1,7,3,1
6:2,1,7,4,0
6:2,1,8,2,1
6:2,1,8,3,1
6:2,1,8,4,0
6:2,1,9,2,1
6:2,1,9,3,1
6:2,1,9,4,0
6:2,1,10,2,1
6:2,1,10,3,1
6:2,1,10,4,0
6:2,1,11,2,1
6:2,1,11,3,1
6:2,1,11,4,0
6:2,1,12,2,1
6:2,1,12,3,1
6:2,1,12,4,0
6:2,1,13,2,1
6:2,1,13,3,1
6:2,1,13,4,0
6:2,1,14,2,1
6:2,1,14,3,1
6:2,1,14,4,0
6:2,1,15,2,1
6:2,1,15,3,1
6:2,1,15,4,0
6:2,1,16,2,1
6:2,1,16,3,1
6:2,1,16,4,0
6:2,1,17,2,1
6:2,1,17,3,1
6:2,1,17,4,0
6:2,1,18,2,1
6:2,1,18,3,1
6:2,1,18,4,0
6:2,1,19,2,1
6:2,1,19,3,1
6:2,1,19,4,0
6:2,1,20,2,1
6:2,1,20,3,1
6:2,1,20,4,0
6:2,1,21,2,1
6:2,1,21,3,1
6:2,1,21,4,0
Thanks Don,
Tried your pSL2 in notepad, but did not work error message keeps saying Initial checks indicate it is not intended for disc(1).
tjones
Old 28th October 2005, 20:27   #18  |  Link
setarip_old
@tjones
The PSL2 file I provided can ONLY be used with the PURCHASED, Region1, "Bewitched - Special Edition".
Is this what you have?
Old 28th October 2005, 23:23   #19  |  Link
tjones
@tjones
Yes !
tjones
Old 28th October 2005, 23:32   #20  |  Link
setarip_old
Just to provide you with a bit more information as to why I asked what version you have - As was noted regarding the Region 1 "Lords of Dogtown", not only were there two different versions for PURCHASE (with two different ARccOS protection schemes), the two versions available for RENTAL (with two different ARccOS protection schemes), had different ARccOS copy protection schemes than did the two versions available for PURCHASE.
This could very well be the same situation regarding "Bewitched"...
