Old 27th October 2005, 13:52   #21  |  Link
Rafik
incompressible ...
Rafik's Avatar
Thanks, now i understand this point.
another question : when MeGUI changes the options of x.264, why it doesn't change in the main x.264 codec configuration et vice versa ? who changes who ?
Le médecin soigne mais Dieu guérit ...
Rafik is offline
Old 27th October 2005, 14:43   #22  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
"x.264 codec configuration" icon, configures the VFW codec, while MeGUI uses the CLI.
Sharktooth is offline
Old 27th October 2005, 15:00   #23  |  Link
Rafik
incompressible ...
Rafik's Avatar
c'est aussi simple que ça !
Rafik is offline
Old 27th October 2005, 16:09   #24  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
For questions, comments and requests ask in this thread.
add if possible level profil ...
HD standalone player become and they use specific profil and level.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline
Old 27th October 2005, 16:27   #25  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
MeGUI-x264 still doesnt support levels
Old 28th October 2005, 16:47   #26  |  Link
bond
Originally Posted by Sharktooth
CE-Baseline: Common settings using baseline profile options (compatible with QuickTime)
quicktime handles main profile!
Ogg Theora | Ogg Vorbis
bond is offline
Old 28th October 2005, 18:16   #27  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yes, it "should"... but some features are broken. baseline will work with no doubts :P
Old 28th October 2005, 21:26   #28  |  Link
bond
which ones are broken?
bond is offline
Old 29th October 2005, 11:08   #29  |  Link
Doom9
clueless n00b
thanks to both aku for the level mapping and sharktooth for taking the initiative and start a MeGUI profile selection
Doom9 is offline
Old 29th October 2005, 14:18   #30  |  Link
panzerino
Ping->>Sharktooth
Sharktooth,
I think, it is time now someone here to say to you-THANKS for all your efforts and for the incredible MeGUI-x264 Custom video profiles. I'm simple customer. Without these profiles I was unable to achieve until now good quality. Yesterday I use some of these profiles, and they are marvelous.
Thank you again, and do not forget how many people here appreciate deeply your efforts, knowledge and kindness to share.
panzerino is offline
Old 29th October 2005, 22:59   #31  |  Link
QuadraQ
QuadraQ's Avatar
Are any of the above profiles usable for xbox compatible x.264 encoding? If not is there any chance that one could be added? Thanks.
QuadraQ is offline
Old 30th October 2005, 02:20   #32  |  Link
hpn
Sharktooth, thanks for the profiles. They are all about 10k compressed, so just one file for download instead of 4 would be simpler . I also guess you are planning to add the profiles to "x264 Full package" in your next build, so people just install it and have the profiles automatically. Or maybe even better, Doom9 could add them to the MeGUI x264 package for those who download the x264 Lite package and MeGUI separately.
hpn is offline
Old 30th October 2005, 15:56   #33  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Sorry, i dont remember which ones.
Maybe, but i'll add a specific XBOX profile ASAP.
You're right. I'll group them in one pack and then, when they're all ready, i'll add them to the "full" installer.
Old 30th October 2005, 21:56   #34  |  Link
QuadraQ
QuadraQ's Avatar
Thank you! Most appreciated.
QuadraQ is offline
Old 31st October 2005, 00:54   #35  |  Link
lexor
Dunno if you need any input on this, but arstechnica has a decent (as far as I can tell) MeGUI guide for putting h264 on iPod. You could take their settings as guidelines for a profile. (it would probably be best to find someone with a video iPod though, just to check stuff works)
http://arstechnica.com/guides/tweaks/ipod-video.ars/6
oh and just to make sure, if checkboxes are checked but are grayed out, it does mean they aren't used right? (i.e. if you choose one of the HQ profiles and then baseline and then show command line, is --analyse all --8x8dct ok in the base profile? I thought that dct stuff enables high profile)
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline
Old 31st October 2005, 08:58   #36  |  Link
Doom9
clueless n00b
nice. I never thought somebody else would write a guide for a software I wrote
Doom9 is offline
Old 31st October 2005, 11:09   #37  |  Link
Cyberace
Profiles for Consoles
PSP: Profile for Sony PSP playback.
XBOX: Profile for XBOX (XBMC is needed).
Coming soon...
VERY nice! Can't wait to see the result of those profiles in actions (after they have been fully optimized?)
Cyberace is offline
Old 1st November 2005, 03:11   #38  |  Link
QuadraQ
QuadraQ's Avatar
BTW I know I'm not the most qualified, but if there's anyway in which I could contribute to documenting MeGUI, let me know, since I have the time and some resources to contribute.
QuadraQ is offline
Old 1st November 2005, 05:05   #39  |  Link
QuadraQ
QuadraQ's Avatar
Sharktooth if you need someone to help you test the xbox profile, I have a modded xbox with the latest version of xbmc and would be happy to help.
QuadraQ is offline
Old 1st November 2005, 11:11   #40  |  Link
Cyberace
Coming soon...
MPEG4 AVC (H.264) encoding tips for the Xbox and decoding on XBMC:
Hints: Suggest you sacrifice encoding-speed to maximize quality at low-bitrates by using 2 or more encoding passes based on AVC Main-Profile or High-Quality Profile, (aim for 700MB or lower in total-size for 2-hours of encoded-video with audio, ie a 1 CD rip). Note!; Xbox only have a 733Mhz Intel Pentium-III CPU and 64MB shared-memory!, and because of the limited resourses on the Xbox it helps disabling any features in XBMC that you do not use (like ex. Python-scripts, WebServer, FTP-server), also suggest you enable the hardware-overlays renderer, lower the video-cache leverls and disable all post-processing filters in XBMC. By the way, remember that Xbox/XBMC are very good at upscaling/upconverting low-resolutions to higher-resolutions (like ex 640x480 to 720x576, and 720x576 to 720p/1080i).
Please DO use:
- Maximum resolution of 720x576 @ 25FPS and 720x480 @ 30FPS.
- ABR (Avarage Bit-Rate) for video.
- Low Bit-Rate video (suggested maximum ABR; 1400kbit/sec).
- Crop (remove) any black-bars on widescreen movies.
- CBR (Constant Bit-Rate) for audio.
- Max 448kbit/sec LC-AAC or 256kbit/sec HE-AAC audio.
- I/P/B-Frames (though a maximum of 3 b-frames in a row).
- P-Frames (though a maximum of 2 reference frames).
- Weighted Prediction.
Please DO NOT use:
- Loop/Deblocking, (XBMC does support deblocking but it slows decoding).
- Interlaced-output, (instead convert any interlaced-input to progressive).
- Anamorphic resolutions, (instead rescale/stretch as needed during encoding).
- Loop/Deblocking; (this signifantly slows decoding).
- CABAC; brings down the bitrate by ~10-15% but slows decoding signifantly.
The jury is out on these:
- Variable Block Sizes/Macroblock Partitions; decoding not supported by XBMC yet?
- 8x8 intra prediction.
- Audio downmix mode "Stereo" (output channels); 5.1 is slower to decode than 2.0?
(Remember to normilize or use dynamic-decomression the audio during encoding!)
Links to XboxMediaCenter's forum discussions regarding ACV playback on Xbox:
Nero-Digital/x264 H.264 MPEG-4 AVC codec, is the Xbox CPU powerfull enough?
HOW-TO play Nero AVC (H.264) in AVI by compile MPlayer with latest FFmpeg!
Nero Digital MPEG-4 AVC / H264 in .MP4 containers support (feature request)
PS! XBMC currently uses FFmpeg CVS from around 4th of October 2005, does that support decoding CQM (Custom Quantization Matrix) for H.264?, if not can 'old' FFmpeg before CQM still decode MPEG4 AVC (H.264) encoded with CQM? By the way; does CQM slow down decoding?, if it does even a little then CQM should probebely be disabled for the Xbox-profile anyway?
Cyberace is offline
