Old 2nd January 2007, 10:13   #121  |  Link
buzzqw
HDConvertToX author
i suggest to use the new AutoMkV !
it is more stable and offer both an "AutoCrop Only" (in width) or Resize NONE
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 2nd January 2007, 10:37   #122  |  Link
Eles10
Cool, thanks...
Eles10 is offline   Reply With Quote
Old 10th March 2007, 15:13   #123  |  Link
delacroixp
Emperor building empire
delacroixp's Avatar
Does MkvMagic support batch processing with the 'modified' Const-Quantizer BR ?
I've just started using AutoMKV to encode the 'Band of Brothers' series into Mkv Avi... using constant-quality quantizer. After much experimentation it dawned on me that the modified-quantizer is not working in batch-mode. Batching is quite important since I run the series through at, let say, Q24 and then again if the result is too big/small for a single 4.5GB DVD. I can also modify the resolution up or down for best results.
I encoded the entire series with Dr DivX 1 & VirtualDub many years ago (also onto 1 DVD) and again with Dr DivX 2 more recently ... I'm eager to compare the results with H264 and MP4 audio.
Pascal
delacroixp is offline   Reply With Quote
Old 10th March 2007, 16:15   #124  |  Link
buzzqw
HDConvertToX author
@delacroixp
wrong thread ?
mkvmagic is a ended project.
i suppose you mean automkv, so this post is for automkv...
anyway mkvmagic doesn't support batch or queue
about your issue i can suggest to modify the x264 CRF profile ( ConstantQuality-CRF.xml ) the <BitrateQuantizer>18</BitrateQuantizer> to your value
i will look to this issue
thanks
BHH
Old 10th March 2007, 20:32   #125  |  Link
delacroixp
delacroixp's Avatar
@ buzzqw
Well I'm using AutoMKV though I've downloaded MkvMagic which looks really gr8... I'm quite happy with AutoMKV 0.76 though I do need the batching.
I do change the quantizer from the default 18 to 24, or even 16 (RAW Avi) but if I enqueue and run the queue it can't remember the 24 (even when I tick the 'Advanced Profile Editing' box and the saved xml file has the correct quantizer).
I should reiterate that 'modified quantizers' (other than 18) work flawlessly in single, direct encodes and the results are truly awesome.
wierd
Pascal
Old 19th March 2007, 18:17   #126  |  Link
delacroixp
delacroixp's Avatar
MkvMagic... the real deal !!!
So I suppose MkvMagic is still the Real Deal... and the best H264 GUI...
Pascal
Old 19th March 2007, 22:47   #127  |  Link
salman1
i can't unpack this file and this is not in rar file
salman1 is offline   Reply With Quote
Old 30th April 2007, 05:06   #128  |  Link
movmasty
Hi, in the wide resize section of Mkv i dont see the Bell filter,
i'm using it with good results for pics, so would be nice to have for movies too,
or maybe some filter that i dont know gives same results of Bell?(removing noise but sharper than bilinear)
movmasty is offline   Reply With Quote
Old 5th May 2007, 12:43   #129  |  Link
delacroixp
delacroixp's Avatar
@movmasty
Bells are all good and well but I use LimitedSharpenFaster and RemoveGrain(mode=2) (sse2) for all my up-scaling and oversampling encodes...
in a quest for true absolute quality with H264...
LoL
Pascal
HDConverToX Xtreme
