Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 5th October 2005, 02:01   #1  |  Link
zyzzle77
IMGBURN 1.000, question / comment
I noticed this in the ChangeLog:
Added: Possible workaround for drives that randomly return 'Unknown' for 'current profile' that then leads to DVD+R/+RW discs not being finalised.
What does this mean, and / or accomplish for the workaround?
I have a Plextor 716A drive that is prone to this problem-- Sometimes .ISO files seem to burn properly and then upon trying to read them back, the drive does not even recognize the disc, and acts like it is blank, even though the .ISO was burned in the (DVD-Decrypter) program. Note that Nero will burn these .ISO images without problems in DAO mode... I've lost several good media discs (TY DVD+R) to this bug / problem. Why does (did) this happen in the defunct DVD-Decrypter?
Thank you for any help on explaining this,
-z
zyzzle77 is offline   Reply With Quote
Old 5th October 2005, 21:14   #2  |  Link
LIGHTNING UK!
Author of ImgBurn
No idea really.
There are some occasions where the drive wont report the 'current profile' it's using.
The 'current profile' is linked to what the drive has determined is in its tray - media wise.
If it's reporting 'unknown', DVD Decrypter wouldn't know exactly which commands to execute in order to finalise the disc properly.
ImgBurn takes extra steps to reduce the chance of this happening.
btw, those discs aren't lost, just close them manually.
LIGHTNING UK! is offline   Reply With Quote
Old 9th October 2005, 19:56   #3  |  Link
FilipeAmadeuO
LIGHTNING UK!
Is there any possibility to post what is on the mds file ? And how to create it ?
My idea is for PGCEdit so the image created can be record after.
FilipeAmadeuO is offline   Reply With Quote
Old 10th October 2005, 16:41   #4  |  Link
LIGHTNING UK!
Author of ImgBurn
Should you ever need one, you do it via the tools menu.
If you just wanted it for the layer break stuff, it's not so important with ImgBurn (compared to DVD Decrypter).
Old 10th October 2005, 18:27   #5  |  Link
FilipeAmadeuO
My idea is for PGCEdit. When an ISO is created if also the MDS file was created i could burn the image later on without having to put the layerbreak sector manualy.
How does IMGBURN 1.000 work ? Does it says where the layerbreak is ?
Old 16th October 2005, 13:43   #6  |  Link
Ja32
Hello,
How to Verify burned DVDR after a time?
Of course I still have original ISO file.
Ja32 is offline   Reply With Quote
Old 16th October 2005, 21:23   #7  |  Link
LIGHTNING UK!
Author of ImgBurn
cdspeed, dvdinfopro ?
Old 18th October 2005, 16:35   #8  |  Link
Ja32
But this is not a test of quality burning only? It not compare original with copy.
By away, this is a wish, ImgBurn could be burn DVD Video from VIDEO_TS data?
Old 19th October 2005, 01:03   #9  |  Link
int 21h
Still Laughing
int 21h's Avatar
Originally Posted by Ja32
By away, this is a wish, ImgBurn could be burn DVD Video from VIDEO_TS data?...
That has been my wish for a long time as well, way back into DVDDecrypter days, maybe now he has more time to focus on such things
"I thought what I'd do was, I'd pretend I was one of those deaf-mutes. That way I wouldn't have to have any god!#$% stupid useless conversations with anybody. If anybody wanted to tell me something, they'd have to write it on a piece of paper and shove it over to me. They'd get bored as hell doing that after a while, and then I'd be through with having conversations for the rest of my life." Chapter 25, pg. 198, The Catcher in the Rye, J.D. Salinger
int 21h is offline   Reply With Quote
Old 19th October 2005, 03:11   #10  |  Link
blutach
Country Member
blutach's Avatar
There's a verify box - do it at the same time. That's what I do.
@int21h - I think you might find that ImgBurn is there to burn images. To create them, use PgcEdit or ImgToolClassic. But, who knows what LUK! might do in future versions?
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 19th October 2005, 05:20   #11  |  Link
int 21h
Still Laughing
int 21h's Avatar
Regards
It was more tongue in cheek than anything... the original post regarding it is here: http://forum.doom9.org/showthread.ph...400#post368876
Old 19th October 2005, 12:17   #12  |  Link
blutach
Country Member
blutach's Avatar
You tax my memory int21h
Regards
Les
