Old 20th May 2019, 19:30   #6281  |  Link
Manni
Originally Posted by Klaus1189 View Post
Manni
Does it happen with all files or just one specific video- and/or audiocodec?
What audio device do you use? Try to use another one for investigation.
Try to disable/enable hardware acceleration. Any difference?
Can you provide a sample UHD BD and another file for testing purposes, but only as p.m.
Devs know more
Thanks, but all these are basic debugging steps.
I'm asking here in case any one has had recently issues with a perfectly working MPC-BE that suddenly stopped working, and found a way to resolve them.
I've spent hours debugging, I've been a MPC-BE users for years, again I have never been in this situation.
I can't give a sample, I've ripped all my files to bd folders. The issue happens with most UHD Bluray folders as I said, so HEVC. Audio format doesn't matter but I can double check that.
Again, all these files/folders used to work fine with MPC-BE until a few weeks ago. They still work fine with MPC-HC and jRiver. So nothing wrong with the files/folders themselves.
I tried using internal filters with defaults after a reinstall of MPC-BE instead of the LAV/MadVR installed in jRiver, but that doesn't help.
I spent a few weeks trying to debug this, and am again only asking in case someone has experienced a samilar issue recently and found a way to fix it.
The only change I've made, which shouldn't play a part when using MPC-BE as a standalone, is installing the 8.8.2 MCE for windows 10 when 8.8.1 stopped working. The latest 8.8.3 doesn't work (can't install it). That could explain issues when launching with MyMovies, but I don't see why it would change anything when using MPC-BE standalone.
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 20th May 2019, 20:32   #6282  |  Link
Klaus1189
System restore possible?
Old 20th May 2019, 20:51   #6283  |  Link
a system restore to get a video player to work when another one does sounds like a bit much...
Some titles don't play or only play for a few seconds (The Meg). Other play fine.
is this consistent?
do you have something like this in an event manager: "Resource-Exhaustion-Detector" ?
Old 20th May 2019, 20:57   #6284  |  Link
Manni
Agreed, plus even if it solved it temporarily it would happen again if cause by an automatic update of some sort. I'd rather find the reason.
is this consistent?
Yes, except that it's getting worse. I started with a few titles, including The Meg, and it would only happen when playing from MCE. I.e. if I tried to play the same title from MPC-BE as a standalonem using the recent file list (so exactly the same plalist as the one played from MCE that crashed), it would work fine. Now it's more titles, and even as a standalone, even simple HDR patterns that MPC-BE has played forever. All these titles that MPC-BE isn't playing anymore, it used to play them fine until a few weeks ago.
Don't know, will check for this and will report back, thanks.
Win11 Pro x64 b23H2
Old 20th May 2019, 21:22   #6285  |  Link
Klaus1189
A system restore point will probably fix it and you can carefully watch every change when it happens again. But you don‘t have to, I only want to help.
A restore point on a HTPC won‘t hurt if you have settings you use already for months.
Old 20th May 2019, 22:04   #6286  |  Link
Manni
Okay, so I've got it back to the stage where if I start playback from MyMovies with some titles (for example The Meg), playback doesn't start, and if I go to MPC-BE and look at recent file, the file that was attempted to play is there, and if I play it it plays fine.
Some title won't play (The Meg), others will play fine (Lucy). All UHD Bluray folders. Very consistent. The same titles that don't play do play with MPC-HC (even from MyMovies) or jRiver.
I looked at the event log and here is what I get when MPC-BE fails to launch:
Faulting application name: mpc-be64.exe, version: 1.5.3.4488, time stamp: 0x5ca1b2bc
Faulting module name: mpc-be64.exe, version: 1.5.3.4488, time stamp: 0x5ca1b2bc
Exception code: 0xc0000409
Fault offset: 0x00000000015638b4
Faulting process ID: 0x2418
Faulting application start time: 0x01d50f4e9dd9fea1
Faulting application path: C:\Program Files\MPC-BE x64\mpc-be64.exe
Faulting module path: C:\Program Files\MPC-BE x64\mpc-be64.exe
Report ID: fd19750b-a1a2-4142-b0df-3129e180852c
Faulting package full name:
I've deleted all the LAV versions except the one use in the jRiver plugins folder. I've re-registered both the 32bits and 64bits .ax in these folders, to make sure these were the one used. MPC-BE is set to use external filters, and points at LAV video/audio/splitter/splitter source, same as MPC-HC. Both use madVR, but I get the same issue if I set the renderer to EVR-CP, so not a madVR issue.
The exception code is always the same, but the fault offset and Faulting process ID change every time.
Here is the connected information:
Fault bucket 1264916888158018584, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: mpc-be64.exe
P2: 1.5.3.4488
P3: 5ca1b2bc
P4: mpc-be64.exe
P5: 1.5.3.4488
P6: 5ca1b2bc
P7: 00000000015638b4
P8: c0000409
P9: 0000000000000005
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2351.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER249A.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER24AA.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER24AC.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER24CD.tmp.txt
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Id: 218575a0-1255-4a8c-a6ab-1feaf16ac9e3
Report Status: 268435456
Hashed bucket: a813813bd95aa688318de3353d0d1c18
Win11 Pro x64 b23H2
Old 20th May 2019, 23:56   #6287  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Manni
1 - Try latest SVN version https://yadi.sk/d/hlf1lfC8mKU58/!_last
2 - Reset settings
3 - Try without any external filters(LAV, madVR ...).
4 - Update Nvidia drivers to latest.
I'm using only with internal filters and ANY UHD BD play perfect.
P.S. If nothing help - i can help only if you upload UHD BD for me or give torrent link.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 21st May 2019, 02:11   #6288  |  Link
ryrynz
ryrynz's Avatar
More than likely it's mpc-be settings related than anything else. Nvidia drivers shouldn't make a difference considering mpc-hc has no issues.
Old 21st May 2019, 08:48   #6289  |  Link
Manni
Originally Posted by Aleksoid1978 View Post
Manni
2 - Reset settings
Thanks!
Unfortunately, the fact that MPC-BE is now working perfectly well again as standalone points to a problem with the latest MCE 8.8.2 / windows build 1809 issue, or possibly MyMovies. Before 1809, when I used 1806 and MCE 8.8.1, all was working fine.
I only posted in this thread when I started to have issues with the standalone app, but following my last debugging session, I don’t have any more issues with MPC-BE standalone.
For some reason, MPC-BE doesn’t work anymore when called from MyMovies within MCE, and MPC-HC doesn’t have this issue.
Not a title issue, as I said from the beginning, as The Meg is played fine now in standalone MPC-BE (even with external LAV and madVR).
I understand it’s not your job to fix MCE and Windows 10 forced updates, but you won’t be able to reproduce unless you use MyMovies/Media Centre to launch MPC-BE.
I’ll keep using MPC-HC with MyMovies for now, but I’ll see if I can get MPC-BE to work again with MCE. Maybe a reinstall of MCE or similar. I think the best place to discuss this is the MyMovies forum, so I’ll post there.
I’ll keep you posted if I find a solution.
Thanks for your help, and for a great software!
Win11 Pro x64 b23H2
Old 21st May 2019, 09:05   #6290  |  Link
Grimsdyke
Manni, I had audio-problems (drop-outs and glitches) with MPC-BE after the win10-503 update !! But their 504-update seem to have fixed the current problems.
So MPC-BE is as great as ever !!
Grimsdyke is offline   Reply With Quote
Old 22nd May 2019, 05:16   #6291  |  Link
Megalith
Does anyone here own an RME ADI-2 Pro DAC? Using the MPC Audio Renderer, WASAPI Shared plays fine, but Exclusive results in laggy video. This is with the device in Class Compliant (driverless) mode.
Megalith is offline   Reply With Quote
Old 22nd May 2019, 06:03   #6292  |  Link
Aleksoid1978
Do you test on latest SVN version - https://yadi.sk/d/hlf1lfC8mKU58/!_last ?
Try change "Device buffer".
Old 22nd May 2019, 14:05   #6293  |  Link
wushantao
hi,everyone
what is the MPC VR
something like madVR?
or VR(Virtual Reality)?
wushantao is offline   Reply With Quote
Old 22nd May 2019, 14:09   #6294  |  Link
Aleksoid1978
Originally Posted by wushantao View Post
hi,everyone
what is the MPC VR
custom VR(Video renderer) - https://github.com/Aleksoid1978/VideoRenderer
Old 23rd May 2019, 04:18   #6295  |  Link
wushantao
oh,i see
Old 25th May 2019, 16:18   #6296  |  Link
mood
Originally Posted by tormento View Post
Is it only me or the latest versions get lot of time when launching?
Originally Posted by Qotscha View Post
Same thing for me too. Tested nightlies (x64) and 1.5.3.4373 seems to be the last build launching practically instantly. Builds starting from 1.5.3.4378 take several seconds.
I have this problem too, take several seconds in last build 1.5.4.4554 and starting from 1.5.3.4378
mood is offline   Reply With Quote
Old 25th May 2019, 18:44   #6297  |  Link
Klaus1189
mood
Does this help?
https://forum.doom9.org/showpost.php...postcount=6163
Old 26th May 2019, 14:41   #6298  |  Link
mood
Thanks, but does not help,
Old 26th May 2019, 22:34   #6299  |  Link
Megalith
No improvement. I think it's a quirk with my DAC.
That said, I noticed another peculiarity with WASAPI Exclusive. In that mode, certain passages of loud bass sound distorted. No such issue in WASAPI Shared.
It's obvious in the Ready Player One, when King Kong slams his hands against the road during the race where the main character drives backward to get the key.
Old 27th May 2019, 01:13   #6300  |  Link
Aleksoid1978
Megalith
Try this build using WASAPI Exclusive - https://yadi.sk/d/GiM3josEiFOlMA
It's create log on Desktop. Upload it for me after playback and close MPC-BE.
