Old 15th June 2009, 06:56   #361  |  Link
lucassp
Here's AMD's official answer:
http://forums.amd.com/forum/messagev...9872&forumid=9
[Intel] Core i5 8500|[ASUS] ROG STRIX Z390-I GAMING|[Noctua] NH-U12S|[GSkill] DDR4 2400 2x16GB|[MSI] RTX2060 Super Gaming X|[Samsung] 970 Pro 512Gb|[Seasonic] Focus SGX 650|[NZXT] H400|[LG] 27GL850
lucassp is offline
Old 21st June 2009, 00:45   #362  |  Link
nabilash
Why did you program it in a way that it only works with nVidia GPUs? :/
I mean I'd donate for this, but because it requires a nVidia GPU it's totally useless for me and many other people...
Still good job though...
nabilash is offline
Old 21st June 2009, 13:56   #363  |  Link
As explained in the posts immediately above yours, Nvidia is the only manufacturer that has made available an appropriate video decoding API.
Guest is offline
Old 23rd July 2009, 18:11   #364  |  Link
A630761
License file
Hello Donald.
I changed my PC and the license file does not work anymore.
I sent you three messages asking you a new license file, but have not yet been answered.
My new ID machine is F9174253.
My e-mail is sollazzo.rosario @ alice.it.
can You send me the file?
Thank you .
A630761 is offline
Old 23rd July 2009, 20:38   #365  |  Link
If I remember to look at this again when I get home this evening I'll do it. You should have used PM for this!
Guest is offline
Old 25th July 2009, 10:18   #366  |  Link
darkmantis
i need to see an actual working copy before i dump out 15$ on something I don't even know will help me..sorry..
darkmantis is offline
Old 25th July 2009, 16:42   #367  |  Link
Inspector.Gadget
darkmantis, you created an account just to troll this thread? Do you think there would be 19 pages of discussion in this thread and inummerable pages elsewhere if these tools didn't work as promised on supported GPUs? Come on.
Inspector.Gadget is offline
Old 28th July 2009, 04:25   #368  |  Link
I've had only one refund request (which I honored) and that was due to the user not realizing his Nvidia card did not support the tools.
Anyway, I think I can survive without your donation.
Guest is offline
Old 21st September 2009, 00:31   #369  |  Link
vwpassion
I was wondering if there's any (significant) difference with regards the decoding speed (lets say source is a VC-1 Bluray) between a VP2 and VP3 engine card, and whether for instance a cheap Geforce 8400 does the same job as a let's say GTX 260 (or better).
vwpassion is offline
Old 21st September 2009, 01:04   #370  |  Link
The actual decoding time is not significantly different, but the bandwidth for moving data to/from the CPU is significantly higher on the high end cards. That significantly increases overall performance.
Guest is offline
Old 25th September 2009, 07:24   #371  |  Link
XadoX
XadoX's Avatar
Should I prefer cropping by DGVC1DecNV or cropping in Avisynth? Are there speed differences?
Edit:
I get a green bar on the left, after loading the cropped .DGV (cropped by MOD16) file into AviSynth.
After loding the .DGV file into DGVC1DecNV again there also seems a problem.
Edit:
cropping only in high seems to work.
XadoX is offline
Old 25th September 2009, 14:10   #372  |  Link
If you need to crop before resizing and you want to resize on the GPU, then you have to crop on the GPU. Otherwise it doesn't matter.
I have updated NV beta 10 with the fix for cropping with Load Project. Thanks for pointing it out.
Regarding your green bar, I do not see the issue. There are several possibilities:
1. You are using UseD3D=1. Please advise if you are.
2. You are running an older CUVIDServer and not the one in NV beta 10. Please check that.
3. You have an older version of the Nvidia drivers. Which driver version are you using?
Guest is offline
Old 25th September 2009, 16:14   #373  |  Link
XadoX
XadoX's Avatar
1. no (not INI was created with UseD3D=1)
2. Using the one in the Beta 9 package (though that was the newest)
3. v190.38
XadoX is offline
Old 25th September 2009, 18:20   #374  |  Link
Well at least telll me what Nvidia card you have.
Guest is offline
Old 27th September 2009, 18:28   #375  |  Link
XadoX
XadoX's Avatar
Nvidia Quadro NVS290.
Edit:
Updated post before (#373).
Edit:
Trying it now with driver v191 and your NVbeta10 package.
Now it works.
XadoX is offline
Old 20th October 2009, 23:51   #376  |  Link
Atomic420
DGVC1DecodeNV.dll
I have DGVC1DecodeNV.dll from version 1.0.6, but i used DGVC1IndexNV.exe 1.0.7 beta 10 from your "NV.Beta.10" package.
When trying to load a .dgv file in avisynth its saying there's a mismatch between the versions of Index/Decode.
So is there a dll for 1.0.7 ? There must be since on your site you state 107 is the recommended version.
Could you point me to the dll i need, or how to get around this?
Atomic420 is offline
Old 21st October 2009, 00:09   #377  |  Link
If you use the indexer from beta 10, you have to load the source filter from the same beta 10, that is, DGDecodeNV.dll. Then use DGSource("file.dgv") in your script.
Guest is offline
Old 2nd November 2009, 00:46   #378  |  Link
skylinekiller
Install
I am having trouble importing a VC-1 file in MeGUI that was demuxed by TSmuxer and they said this program would solve the problem. How do I install this correctly?
skylinekiller is offline
Old 2nd November 2009, 00:53   #379  |  Link
Tell me exactly what you did and what trouble you are having.
Guest is offline
Old 2nd November 2009, 01:01   #380  |  Link
skylinekiller
Vc-1
I have a VC-1 I used tsMuxer and extracted to M2ts, then I used MeGUI AVSScript Creator and go to import the M2ts, but I keep getting error AviSynth script error: DirectShowSource: Timeout waiting for graph to start.
I only get this error with VC-1. I dont know what to do with the dgdecnv200b1 files.
