31st May 2009, 17:47 | #261 | Link |
What does the output look like when you do:
E:\audio\eac3to-3.16>eac3to.exe "G:\" 8)
HdBrStreamExtractor |
1st June 2009, 06:20 | #262 | Link | ||
Swallowed in the Sea
11th June 2009, 13:10 | #264 | Link |
Can you show me the results from inspecting the feature with eac3to?
eac3to-3.16>eac3to.exe [DISC]: [STREAM#])
11th June 2009, 13:34 | #265 | Link |
Sure, here we go:
Track 5 gives the DTS export option, track 6/7 only AC3 Code:
M2TS, 3 video tracks, 7 audio tracks, 7 subtitle tracks, 1:38:40, 98.945p 1: Chapters, 32 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: h264/AVC, 480p24 /1.001 (20:11) 5: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48khz) 6: DTS-ES, Italian, 5.1 channels, 24 bits, 1509kbps, 48khz 7: DTS-ES, German, 5.1 channels, 24 bits, 1509kbps, 48khz 8: AC3 Surround, English, 2.0 channels, 192kbps, 48khz 9: AC3 Surround, Italian, 2.0 channels, 192kbps, 48khz 10: AC3 Surround, German, 2.0 channels, 192kbps, 48khz 11: AC3 Surround, English, 2.0 channels, 192kbps, 48khz 12: Subtitle (PGS), English 13: Subtitle (PGS), English 14: Subtitle (PGS), Italian 15: Subtitle (PGS), German 16: Subtitle (PGS), Italian 17: Subtitle (PGS), German 18: Subtitle (PGS), English HdBrStreamExtractor SVN (0.5 throw an error regarding parent threads etc.) |
11th June 2009, 15:36 | #266 | Link | |
it's because, DTS-ES, AC3 Surround & AC3 EX are not yet recognized by the GUI...
btw, I'm surprise by this: Quote:
11th June 2009, 17:26 | #267 | Link |
I've been super busy @ work so don't have much time right now to address this and other issues.
As long as you keep posting issues like this they are captured and I can fix them when I do have time.
12th June 2009, 06:10 | #269 | Link |
have you seen already movies at 98.945p ?
@Greif: Code:
Index: eac3to/AudioStream.cs =================================================================== --- eac3to/AudioStream.cs (revision 13) +++ eac3to/AudioStream.cs (working copy) @@ -85,9 +85,12 @@ switch (audioStream.Name.ToUpper()) { case "AC3": + case "AC3 EX": + case "AC3 SURROUND": audioStream.AudioType = AudioStreamType.AC3; break; case "DTS": + case "DTS-ES": case "DTS MASTER AUDIO": case "DTS HI-RES": audioStream.AudioType = AudioStreamType.DTS; |
13th June 2009, 18:54 | #273 | Link |
Hi all.
First off, if theres a thread about this elsewhere or not the correct place for this I apologize, please direct me to where I should be I use the HD stream extractor (EAC3to) for most of my blurays. However, since the latest updates of MeGUI 3.1.1040 and 3.1.1041 I get constant errors with the stream extractor. It Queues and shows the codec as EAC3to and the directory where ever I chose with ((xxx)) right after it. As soon as I click start it just says error. I reverted back to 3.1.1028 and updated all but the core of MEgui and now the stream extractor and Eac3to is working properly. Is this a new bug in the new core versions, or a fix for it somewhere or am I being a complete noob and missing something simple. Thanks. |
19th June 2009, 13:48 | #276 | Link |
No, nothing you did wrong. That is an outstanding bug that I have to track down.
I have been really busy @ work and still continue to be so I haven't had time to work on this stuff. I will get to it probably during the summer, hopefully sooner. I do not think the same things is happening in MeGUI so you can try using that as well.
19th June 2009, 14:09 | #277 | Link | |
19th June 2009, 14:23 | #278 | Link |
Yes, I have found the bug with just certain titles.
22nd June 2009, 18:58 | #279 | Link |
fails rather often
I have tried HDBrStreamExtractor numerous times. I have found that at least 50% of the time it chokes and complains about 'discontinuity' in the stream file or some such nonsense.
But when I run eac3to from the command line the conversion always works! I would really like to get this program working as it is the only GUI I am aware of that supports MKV video and FLAC audio. The author of ClownBD, for some reason, thinks it unimportant to support the FLAC audio conversion. In my mind this is the key benefit of conversion. After all, the video remains the same just in a different container and DRM-free. |
23rd June 2009, 01:01 | #280 | Link |
Can you provide me with the exact error message? Can you show the log that is created?
eac3to, hdbrstreamextractor |
