Old 15th October 2017, 21:30   #14401  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
The .h265 extracted with eac3to v3.32 from this sample don't play fine.
Just-so-you-know...
I downloaded your sample, transferred it to an USB pen-drive and can confirm that it plays fine in my LG television.
Cheers
SeeMoreDigital is offline
Old 16th October 2017, 01:02   #14402  |  Link
Megalith
HdBrStreamExtractor is updated in MeGUI -> Tools -> HD Streams Extractor
Or UsEac3to v1.2.7
All other GUI's are abandoned.
Thank you, MeGUI seems to be working great. It looks like I can finally move away from Clown_BD.
I am still confused about how eac3to handles Atmos tracks, though. Is an Atmos track the same thing as a TrueHD track, or is eac3to converting Atmos to a TrueHD track for compatibility reasons? Dolby's naming convention isn't helping me understand it any better.
Megalith is offline
Old 16th October 2017, 01:12   #14403  |  Link
Megalith
Well, looks like eac3to and MeGUI has failed, too. This is what an UHD HEVC file looks like when muxed to MKV. Only MKVToolNix appears to do it correctly. (Actually, maybe the problem lies with MKVToolNix in not handling separate/extracted files correctly...)
Megalith is offline
Old 16th October 2017, 01:38   #14404  |  Link
tebasuna51
tebasuna51's Avatar
The uploaded sample work fine, but if you extract the .h265 with eac3to and play it, even re-remuxed to mkv, fails (like the Megalith image).
tebasuna51 is offline
Old 16th October 2017, 01:46   #14405  |  Link
tebasuna51
tebasuna51's Avatar
A Atmos track is a TrueHD track with extra metadata than only a receiver with Atmos support (and ceiling speakers) can understand.
The metadata remain in thd extracted by eac3to/mkvextract.
Standard receivers ignore that metadata.
Old 16th October 2017, 02:24   #14406  |  Link
tebasuna51
tebasuna51's Avatar
Another sample with problems.
Remark the different size of extracted .h265
15/10/2017  22:03       177.693.906 Arrival UHD Sample.mkv_ 0.h265  (mkvextract)
15/10/2017  21:59       157.722.039 Arrival UHD Sample.mkv_1eng.h265 (eac3to)
Old 22nd October 2017, 14:09   #14407  |  Link
VAMET
UTAVATU
VAMET's Avatar
Dear madshi
I have used eac3to to identify my .mkv files and I have got such results:
MKV, 2 video tracks, 1 audio track, 2:15:58, 24p /1.001
1: h265/HEVC, English, 2160p24 /1.001 (16:9), 10 bits
2: h265/HEVC, English, 1080p24 /1.001 (16:9), 10 bits - Dolby Vision Enhancement Layer
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz)
Source disk has got DTS:X audio track, why it's not identified as DTS:X, but DTS Master Audio? The next .mkv file, which I show results below, has got in source disk Dolby Atmos and in the .mkv file it's Dolby Atmos too, which is correctly identified.
MKV, 2 video tracks, 1 audio track, 2:34:39, 24p /1.001
3: TrueHD (Atmos), English, 7.1 channels, 48kHz, 32ms
My second question, why there is not core embedded in track 3 TrueHD (Atmos) like in first .mkv file for DTS Master Audio (core: DTS, 5.1 channels, 1509kbps, 48kHz)?
Thank you in advance for your support.
Sincerely
VAMET
ALLEGRO BLOG FACEBOOK
VAMET is offline
Old 22nd October 2017, 17:26   #14408  |  Link
tebasuna51
tebasuna51's Avatar
Because eac3to can't detect DTS:X, maybe can be a feature request (not important for me, because can be extracted preserving DTS:X info, and can be decoded like standard DTS-MA)
Because TrueHD don't have any 'core', like DTS-HD have.
The AC3 track interleaved with TrueHD track is only possible in m2ts container, in mkv must be a different track.
Old 28th October 2017, 11:23   #14409  |  Link
tebasuna51
tebasuna51's Avatar
Posts about E-AC3+Atmos moved to new thread E-AC3+Atmos
Because eac3to can't recognize the tracks like Atmos.
BTW eac3to can decode them like standard 5.1.
Old 28th October 2017, 12:10   #14410  |  Link
LigH
LigH's Avatar
When eac3to was "fixed" not to crash when Atmos metadata are contained, the fix only meant to properly ignore them.
New German Gleitz board
LigH is offline
Old 28th October 2017, 12:34   #14411  |  Link
Music Fan
But I believe you can't remove the Atmos part and keep only the True HD part, thus it's not ignored but treated as is.
Music Fan is offline
Old 28th October 2017, 13:28   #14412  |  Link
nevcairiel
"Removing" would not be "ignoring". It just ignores if its present or not, and copies the entire TrueHD as-is. Removing it would require modifiying the entire TrueHD stream, since its not a separate sub-stream or anything like that, but actually integrated into the TrueHD stream itself.
nevcairiel is offline
Old 31st October 2017, 20:49   #14413  |  Link
pcroland
Hi! What's the difference between using and not using the -down16 option? I tried both way, but the output is still has 16bit bit-depth but the md5sum's are different: https://vgy.me/Tflfue.png
pcroland is offline
Old 31st October 2017, 20:59   #14414  |  Link
LigH
LigH's Avatar
If you use the -down16 option, the precision of your input WAV is first reduced from 32 bit float down to 16 bit integer, before encoding it to AC3.
Omitting it, more or less the full input precision is encoded to AC3.
LigH is offline
Old 31st October 2017, 21:03   #14415  |  Link
pcroland
And what do you suggest? Should I use it or omit it?
pcroland is offline
Old 31st October 2017, 21:20   #14416  |  Link
LigH
LigH's Avatar
Why would you want to possibly reduce the precision, thus quality, in the middle of a conversion? If you omit it, the precision might be better than just 16 bits.
LigH is offline
Old 31st October 2017, 21:22   #14417  |  Link
pcroland
Alright, thanks for the help
pcroland is offline
Old 1st November 2017, 00:50   #14418  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by Snowknight26 View Post
-logpids
For most Blurays match the PID list to the track info list,
but for this Bluray with 2 video streams and DTS Express not.
PID: 256/4113 ($ea), "VC-1", VC-1
PID: 256/4352 ($86), DTS Master Audio
PID: 256/4353 ($85), DTS Hi-Res
PID: 256/4354 ($86), DTS Master Audio
PID: 256/4355 ($81), "AC-3", AC3
PID: 256/4356 ($81), "AC-3", AC3
PID: 256/4357 ($81), "AC-3", AC3
PID: 256/4358 ($81), "AC-3", AC3
PID: 256/4608 ($90), Subtitle (PGS)
PID: 256/4609 ($90), Subtitle (PGS)
PID: 256/4610 ($90), Subtitle (PGS)
PID: 256/4611 ($90), Subtitle (PGS)
PID: 256/4612 ($90), Subtitle (PGS)
PID: 256/4613 ($90), Subtitle (PGS)
PID: 256/4614 ($90), Subtitle (PGS)
PID: 256/4615 ($90), Subtitle (PGS)
PID: 256/4616 ($90), Subtitle (PGS)
PID: 256/4617 ($90), Subtitle (PGS)
PID: 256/4618 ($90), Subtitle (PGS)
PID: 256/4619 ($90), Subtitle (PGS)
PID: 256/4620 ($90), Subtitle (PGS)
PID: 256/4621 ($90), Subtitle (PGS)
PID: 256/4622 ($90), Subtitle (PGS)
PID: 256/4623 ($90), Subtitle (PGS)
PID: 256/4624 ($90), Subtitle (PGS)
PID: 256/4625 ($90), Subtitle (PGS)
PID: 256/4626 ($90), Subtitle (PGS)
PID: 256/6656 ($a2), DTS Express
PID: 256/6657 ($a2), DTS Express
PID: 256/6912 ($ea), "VC-1", VC-1
M2TS, 2 video tracks, 9 audio tracks, 19 subtitle tracks, 2:36:07, 24p /1.001
1: Chapters, 80 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: VC-1, 480p24 /1.001 (3:2)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
   (core: DTS-ES, 5.1 channels, 1509kbps, 48kHz)
5: DTS Hi-Res, French, 5.1 channels, 3018kbps, 48kHz
6: DTS Master Audio, German, 7.1 channels, 24 bits, 48kHz
7: AC3, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB
8: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB
9: AC3 Headphone, English, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB
10: AC3 Headphone, German, 2.0 channels, 224kbps, 48kHz, dialnorm: -27dB
11: DTS Express, English, 2.0 channels, 192kbps, 48kHz
12: DTS Express, English, 2.0 channels, 192kbps, 48kHz
13: Subtitle (PGS), English
14: Subtitle (PGS), French
15: Subtitle (PGS), German
16: Subtitle (PGS), Turkish
17: Subtitle (PGS), English
18: Subtitle (PGS), French
19: Subtitle (PGS), German
20: Subtitle (PGS), English
21: Subtitle (PGS), French
22: Subtitle (PGS), German
23: Subtitle (PGS), English
24: Subtitle (PGS), French
25: Subtitle (PGS), English
26: Subtitle (PGS), English
27: Subtitle (PGS), French
28: Subtitle (PGS), German
29: Subtitle (PGS), English
30: Subtitle (PGS), French
31: Subtitle (PGS), German
The change of the stream order breaks simple parsing.
@madshi
Could you add the eac3to stream number at the end of the PID info line for each PID?
hubblec4 is offline
Old 1st November 2017, 04:19   #14419  |  Link
pstn
Could anyone explain what is going on with this pls?
1) 00003.mpls, 00009.m2ts+00004.m2ts, 1:51:42
- Chapters, 12 chapters
- h264/AVC, 1080i50 (16:9)
- DTS Master Audio, Norwegian, multi-channel, 48kHz
- DTS Master Audio, French, multi-channel, 48kHz
since the 00009.m2ts file is a 10frame (1/2 second) black screen with no audio track, followed by the movie, should I be doing the demuxing directly on the 00004.m2ts (the actual movie) file instead?
thanks
pstn is offline
Old 1st November 2017, 08:41   #14420  |  Link
LigH
LigH's Avatar
I would assume that this is an "authoring trick" prefix (e.g. to catch a "double PREV button", as I remember from DVD authoring). So, yes, try to work with the 00004.m2ts only, but check well if audio is in sync in your result. (No warranties, though.)
LigH is offline
eac3to
