Old 12th July 2010, 17:52   #2041  |  Link
RedDwarf1
RedDwarf Fan
Originally Posted by tormento View Post
Today I'll feed some memory intensive jobs to your newer version.
Yep, just waiting for a less hungry Fermi.
Why not just get a GT240 GDDR5 1GB? I have a Zotac GT240 GDDR5 1GB card with 4GHz Samsung memory chips which overclock quite well, 3400MHz default and overclock to 4GHz quite easily using Zotac Firestorm. But memory bandwidth has never been an issue as it has never gone over 20% so far.
The Zotac card is a single slot card so leaves more expansion slots free than dual slot designs.
Fermi and GT 240 are meant to share the same VP engine, it's only Gaming or GPU encoding that Fermi would benefit and GPU encoding has been a waste of time so far, plus the improved audio output if that was needed on a PC. So why spend large sums on cards that are largely unnecessary?
I think a comparison of cards decoding capabilities and speeds would be beneficial. If suitable clip(s) could be found to be used for comparing cards.
I wonder whether there has been any speed improvement in the VP engine in recent nVidia cards like has been suggested.
How about it? Are you up for it?
RedDwarf1 is offline   Reply With Quote
Old 12th July 2010, 19:36   #2042  |  Link
Who, me? I can't afford to buy all those different cards.
VP engine clock rate and memory bandwidth are the specs to compare. We could all post our card and what the Nvidia control panel shows for those specs.
My card at work (my home card is better, a 9600GT):
NVIDIA System Information report created on: 07/12/2010 13:42:58
System name: SCHDTLABPC1
[Display]
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ (2004 MHz)
Operating System: Microsoft Windows XP, 32-bit (Service Pack 3)
DirectX version: 9.0c
GPU processor: GeForce 8500 GT
Driver version: 190.38
Stream processors: 16
Core clock: 500 MHz
Shader clock: 1020 MHz
Memory clock: 400 MHz (800 MHz data rate)
Memory interface: 128-bit
Memory: 1024 MB
Video BIOS version: 60.86.41.00.23
IRQ: 16
Bus: PCI Express x16
Old 12th July 2010, 20:11   #2043  |  Link
GZZ
I have a GT9500, it gives the same speed as my GTX 260 I have somewhere and only put in when I want to play.... Not very offen.
Here are the spec om my 9500 GT card (passiv cooled card at a price around 350 dkr ~ 70$) - Max Power use ~ 50 watt
[Display]
Processor: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz (3200 MHz)
Operating System: Windows 7 Ultimate, 64-bit
DirectX version: 11.0
GPU processor: GeForce 9500 GT
Driver version: 197.45
CUDA Cores: 32
Core clock: 550 MHz
Shader clock: 1400 MHz
Total available graphics memory: 2815 MB
Dedicated video memory: 1024 MB
System video memory: 0 MB
Shared system memory: 1791 MB
Video BIOS version: 62.94.3C.00.00
IRQ: 16
Bus: PCI Express x16 Gen2
GZZ is offline   Reply With Quote
Old 12th July 2010, 20:19   #2044  |  Link
You have 2GB? I hate you.
OK, I wanna see the most kick-ass specs. Bring it on!
P.S. I believe the VP is clocked off the core clock.
Old 12th July 2010, 20:54   #2045  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i can post my ATI card specs... those rox... but i think they wont be usefull LOL
Old 12th July 2010, 21:38   #2046  |  Link
cweb
cweb's Avatar
This is my main system, with a GTX 285 card.
[Display]
Processor: AMD Athlon(tm) 64 FX-62 Dual Core Processor (2800 MHz)
Operating System: Windows 7 Professional, 32-bit
GPU processor: GeForce GTX 285
Driver version: 196.21
CUDA Cores: 240
Memory interface: 512-bit
Total available graphics memory: 2303 MB
Shared system memory: 1279 MB
Video BIOS version: 62.00.45.00.00
IRQ: 16
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 12th July 2010, 21:50   #2047  |  Link
RedDwarf1
RedDwarf Fan
No, I was referring to tormento. You have already said you don't have the time to do it.
Different systems, such as CPU, Windows version and GPU might influence the decoding speed but how big a difference the GPU makes is the question that has never been discovered. Do we really need the latest, fastest, highest electrically powered card to provide fast video decoding or will a very basic card be sufficient? For H264 transcoding the card probably doesn't make much difference as the encoding is the slow part and the decoding speed is unlikely to be the bottleneck. It's only when encoding from HD to SD that decoding speed becomes an issue as encoding is very fast and often faster than the decoding speed. That's a big issue for anyone doing such things.
If I was to encode an XVid from HD video, I can decode@ about 100fps for 1440x1088i@25fps but I can encode at around 140+ fps from an SD Mpeg2 source. So the bottleneck would be decoding HD video using a GPU.
You nVidia contact said that the VP engine is usually clocked the same right across the nVidia chipset range. It usually clocks at 250MHz but in some cases can be clocked lower for lower end cards. That is what was show in your development notes.
[Display]
Core clock: 500 MHz
Memory: 1024 MB
IRQ: 16
I don't think the Core clock has anything to do with the VP engine clock. I think that they are totally separate and don't influence one another. It's the VP engine which is used to decode the video as you have mentioned before and is shown by GPU-z. The GPU load is usually fairly low when decoding video but the Video engine hits 99% on mine.
What might be helpful would be to have some test videos which people could use to preview using DGIndexNV and then post the average decode speed as a graphic showing the window. Post a GPU-z image of the graphics card details and maybe some shots from CPU-z. Then see whether the Graphics card makes any difference.
The only HD video I have is HD broadcast video from BBC HD & ITV HD TV channels which is 1440x1088i@25fps.
Movie trailers might be useful if those are permitted by forum rules.
@neuron2
They are all 1GB cards, note the Dedicated video memory: 1024 MB. I don't think they have 2GB of memory. His looks like it might have onboard AMD video so that might be why his is showing as being over 2GB. The video memory is the total of shared and dedicated video memory.
  1. Processor: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz (2666 MHz)
  2. Operating System: Microsoft Windows XP, 32-bit (Service Pack 3)
  3. DirectX version: 9.0
  4. GPU processor: GeForce GT 240
  5. Driver version: 197.45
  6. CUDA Cores: 96
  7. Core clock: 550 MHz
  8. Shader clock: 1340 MHz
  9. Memory clock: 1700 MHz (3400 MHz data rate)
  10. Memory interface: 128-bit
  11. Memory: 1024 MB
  12. Video BIOS version: 70.15.38.00.01
  13. IRQ: 16
  14. Bus: PCI Express x16 Gen2
or
  6. CUDA Cores: 96
  9. Memory clock: 2000 MHz (4000 MHz data rate) A bit more memory bandwidth if needed
  11. Memory: 1024 MB
  13. IRQ: 16
Old 12th July 2010, 21:56   #2048  |  Link
650 not 250.
I know the card makes a difference. On one poor system with 8500 at work I get 15 fps decoding on a stream for which I get 68 fps at home.
Old 12th July 2010, 22:09   #2049  |  Link
RedDwarf1
RedDwarf Fan
650 not 250.
I think we both got the wrong numbers.
The notes say 450MHz with some running at 400MHz. Search the notes for MHz
Different video, bitrate, resolution, framerate can be decoded at different speeds. These are factors and the VP engine/GPU might also play a part.
As I said I get around 100fps for 1440x1088i@25fps low bitrate HDTV. I don't have any sources to check Blu Ray or high bitrate video so don't know what mine is capable of.
It would be interesting to know whether a badass high end card provides any benefit for such uses or whether a more power efficient low end card is just as good.
Does the updated VP engine make any difference to decoding speed? Is a VP4 beneficial? In what way? Speed? Quality? The video it can decode? Some are known because of information from various sources but other things are not. These things can only really be found through testing.
Old 12th July 2010, 22:16   #2050  |  Link
I just got done saying I know it makes a difference. Are you doubting that or just missed my statement?
Old 12th July 2010, 22:59   #2051  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Awesome work, neuron2! This is a very solid version of DGNV!
Here's a question for you - say I need to run a lot of 1080p transcodes at once, say enough to overrun even a 2GB card.
If I install multiple cards in the system, will DGNV spawn instances on all the cards, or is it restricted to one?
Derek
Old 12th July 2010, 23:46   #2052  |  Link
RedDwarf1
RedDwarf Fan
I don't doubt that, I wondered how much of a difference it makes.
From what I have seen, memory bandwidth doesn't seem a big issue on my card so far as mine has never gone over 20% with a default 54.4GB/s bandwidth on a 128 bit bus. If the VP cores run at similar speeds where is the difference coming from. Are new VP cores more efficient at decoding and hence faster.
Data would reveal a lot and remove a lot of guesswork on which card to choose.
Old 13th July 2010, 00:30   #2053  |  Link
Multiple instances are supported of course. But currently a new instance looks at only the first CUDA-enabled card. tormento has already asked for a way to specify which of multiple cards should be used. Now you bring up another mode that should be supported: dynamically find a card that has enough memory for another instance. Adding to the to-do list.
Old 13th July 2010, 01:35   #2054  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Something i might be interested into.
9500GT comes with stock frequencies at 550/1400/400 (gpu/shaders/memory), while this is pretty "low" i can safely overclock it (without volt mod) to 700/1820/510.
Does the overclocking influence also video decoding speed or has it a dedicated unit for video decoding that's completely independent from core/shaders/memory clocks?
Old 13th July 2010, 02:03   #2055  |  Link
adiabatic
adiabatic's Avatar
Main PC:
[Display]
Processor: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (2673 MHz)
Operating System: Windows 7 Professional, 64-bit
GPU processor: GeForce GTX 275
Driver version: 257.21
CUDA Cores: 240
Core clock: 648 MHz
Shader clock: 1458 MHz
Memory clock: 1188 MHz (2376 MHz data rate)
Memory interface: 448-bit
Total available graphics memory: 3707 MB
Dedicated video memory: 896 MB GDDR3
Shared system memory: 2811 MB
Video BIOS version: 62.00.60.00.70
IRQ: 24
Secondary PC (my old workhorse)
[Display]
Processor: Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz (1995 MHz)
Operating System: Windows Vista (TM) Home Premium, 32-bit (Service Pack 2)
DirectX version: 10.1
GPU processor: GeForce 8600 GT
CUDA Cores: 32
Core clock: 540 MHz
Shader clock: 1188 MHz
Memory clock: 700 MHz (1400 MHz data rate)
Total available graphics memory: 1021 MB
Dedicated video memory: 256 MB GDDR3
Shared system memory: 765 MB
Video BIOS version: 60.84.51.00.00
IRQ: 16
adiabatic is offline   Reply With Quote
Old 13th July 2010, 02:16   #2056  |  Link
MrVideo
MrVideo's Avatar
Here is mine, for the new quadcore. The same graphics card is in the dual core system.
[Display]
Processor:              AMD Phenom(tm) II X4 965 Processor (3411 MHz)
Operating System:       Microsoft Windows XP, 32-bit (Service Pack 2)
CUDA Cores:             96
Core clock:             550 MHz
Memory:                 512 MB
Memory type:            GDDR5
Video BIOS version:     70.15.2C.00.51
IRQ:                    24
Old 13th July 2010, 03:19   #2057  |  Link
Hit man is on the way.
I think we should hold off further reports and do what RedDwarf1 suggested. I will get a sample clip prepared with instructions for playing it in DGIndexNV and then we will report the data above together with our FPS. Stand by...
Old 13th July 2010, 03:21   #2058  |  Link
Good question. I'll see what Nvidia has to say about it. I'll also ask if there is a way to determine the VP engine clock rate.
Old 13th July 2010, 03:53   #2059  |  Link
Audionut
I asked the rivatuner author about these things not long after dgindexnv was released and got this response.
Hmm, interesting. I did some researches tonight and it looks like there is indeed separate 4xx MHz clocked domain in the chip which can be used to feed VP independently of SPs. However, forget about controlling it: drivers doesn't provide overclocking support for it and implementing low-level way doesn't worth the efforts from my POV.
http://forums.guru3d.com/showthread.php?t=274311
Perhaps a few of you guys should register there and bug the dev about adding overclock support for the chip.
http://www.7-zip.org/
Old 13th July 2010, 04:17   #2060  |  Link
adiabatic
adiabatic's Avatar
It is a nice card It rips through SETI work units like crazy too!
