4th January 2014, 05:54 | #303 | Link |
Since you're new to using Avisynth and ffdshow, consider using MadVR's deband feature which is based off of f3kdb if you have a semi decent GPU. At this point I think it's generally accepted that it offers better debanding.
30th May 2014, 03:16 | #305 | Link |
I am too busy on my work and other projects recently, so this probably won't happen for some time, sorry.. Though if anyone can send me pull requests or patches, I can merge it into the main repository.
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 |
8th March 2015, 22:17 | #306 | Link |
I'm having problem compiling this plugin at 64bit on Windows using mingw64 and Msys 2.
I start waf using this Code:
./waf configure --static --no-shared --disable-avs --mode=release Code:
Setting top to : /f3kdb Setting out to : /f3kdb/build Shared library : no Static library : yes Checking for 'g++' (c++ compiler) : /mingw64/bin/g++ Checking for linker flags -Wl,-Bsymbolic : no Checking for linker flags -Wl,-z,noexecstack : no - alignas : no Code:
# project f3kdb (2.0pre) configured on Sun Mar 8 22:16:01 2015 by # waf 1.7.15 (abi 98, python 30303f0 on msys) # using ./waf configure --static --no-shared --disable-avs --mode=release # ---------------------------------------- Setting top to /f3kdb ---------------------------------------- Setting out to /f3kdb/build ---------------------------------------- Shared library no ---------------------------------------- Static library yes ---------------------------------------- Checking for 'g++' (c++ compiler) find program=['g++', 'c++'] paths=['/mingw64/bin', '/usr/local/bin', '/usr/bin', '/bin', '/mingw32', '/c/ProgramData/Oracle/Java/javapath', '/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common', '/c/Windows/system32', '/c/Windows', '/c/Windows/System32/Wbem', '/c/Windows/System32/WindowsPowerShell/v1.0', '/c/Program Files (x86)/ATI Technologies/ATI.ACE/Core-Static', '/c/Program Files (x86)/Common Files/Roxio Shared/9.0/DLLShared', '/c/Program Files (x86)/QT Lite/QTSystem', '/c/Program Files (x86)/AMD/ATI.ACE/Core-Static', '/c/Program Files (x86)/CMake/bin', '/usr/bin/site_perl', '/usr/bin/vendor_perl', '/usr/bin/core_perl'] var='CXX' -> '/mingw64/bin/g++' find program=['ar'] paths=['/mingw64/bin', '/usr/local/bin', '/usr/bin', '/bin', '/mingw32', '/c/ProgramData/Oracle/Java/javapath', '/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common', '/c/Windows/system32', '/c/Windows', '/c/Windows/System32/Wbem', '/c/Windows/System32/WindowsPowerShell/v1.0', '/c/Program Files (x86)/ATI Technologies/ATI.ACE/Core-Static', '/c/Program Files (x86)/Common Files/Roxio Shared/9.0/DLLShared', '/c/Program Files (x86)/QT Lite/QTSystem', '/c/Program Files (x86)/AMD/ATI.ACE/Core-Static', '/c/Program Files (x86)/CMake/bin', '/usr/bin/site_perl', '/usr/bin/vendor_perl', '/usr/bin/core_perl'] var='AR' -> '/mingw64/bin/ar' /mingw64/bin/g++ ---------------------------------------- Checking for linker flags -Wl,-Bsymbolic ==> int main(int argc, char **argv) { (void)argc; (void)argv; return 0; } <== [1/2] [32mcxx: build/.conf_check_73cb2ad4dc7ec5ddbb2d8468622d975a/test.cpp -> build/.conf_check_73cb2ad4dc7ec5ddbb2d8468622d975a/testbuild/test.cpp.1.o [0m ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] err: ../test.cpp:1:0: error: -fPIC ignored for target (all code is position independent) [-Werror] ^ cc1plus.exe: all warnings being treated as errors from /f3kdb: Test does not build: Traceback (most recent call last): File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Tools/c_config.py", line 458, in run_c_code bld.compile() File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Build.py", line 188, in compile raise Errors.BuildError(self.producer.error) waflib.Errors.BuildError: Build failed -> task in 'testprog' failed (exit status 1): {task 7696569521744: cxx test.cpp -> test.cpp.1.o} ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] no from /f3kdb: The configuration failed -------------------------------------------- Checking for linker flags -Wl,-z,noexecstack ==> int main(int argc, char **argv) { (void)argc; (void)argv; return 0; } <== [1/2] [32mcxx: build/.conf_check_1fb68c99b0b8fa44c9dc9af28b04c8de/test.cpp -> build/.conf_check_1fb68c99b0b8fa44c9dc9af28b04c8de/testbuild/test.cpp.1.o [0m ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] err: ../test.cpp:1:0: error: -fPIC ignored for target (all code is position independent) [-Werror] ^ cc1plus.exe: all warnings being treated as errors from /f3kdb: Test does not build: Traceback (most recent call last): File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Tools/c_config.py", line 458, in run_c_code bld.compile() File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Build.py", line 188, in compile raise Errors.BuildError(self.producer.error) waflib.Errors.BuildError: Build failed -> task in 'testprog' failed (exit status 1): {task 7696569193424: cxx test.cpp -> test.cpp.1.o} ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] no from /f3kdb: The configuration failed -------------------------------------------- - alignas ==> int main() { alignas(8) int x = 0; return x; } <== [1/2] [32mcxx: build/.conf_check_e3129656e5b3600e23d9ba3a04379822/test.cpp -> build/.conf_check_e3129656e5b3600e23d9ba3a04379822/testbuild/test.cpp.1.o [0m ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '-O3', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] err: ../test.cpp:1:0: error: -fPIC ignored for target (all code is position independent) [-Werror] int main() { alignas(8) int x = 0; return x; } ^ cc1plus.exe: all warnings being treated as errors from /f3kdb: Test does not build: Traceback (most recent call last): File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Tools/c_config.py", line 458, in run_c_code bld.compile() File "/f3kdb/.waf3-1.7.15-9c6c439a6416a92b3e844736c4ef3c7b/waflib/Build.py", line 188, in compile raise Errors.BuildError(self.producer.error) waflib.Errors.BuildError: Build failed -> task in 'testprog' failed (exit status 1): {task 7696569195024: cxx test.cpp -> test.cpp.1.o} ['/mingw64/bin/g++', '-fPIC', '-Wall', '-Wextra', '-Wno-unused-parameter', '-fvisibility=hidden', '-fvisibility-inlines-hidden', '-Werror', '-std=c++11', '-O3', '../test.cpp', '-c', '-o', 'test.cpp.1.o'] no from /f3kdb: The configuration failed |
8th March 2015, 22:23 | #307 | Link |
Professional Code Monkey
Remove -Werror from the build script. It shouldn't be there.
8th March 2015, 22:42 | #308 | Link |
I think I did try that and was no good. Here is a compile with msvs12 for vapoursynth-flash3kyuu_deband-2.0.20140721, and that's the date for the last time code updated on github. It includes 32/64 bit binaries and docs.
25th July 2016, 11:10 | #310 | Link |
Got an 8bit video.
Executed this command f3kdb(keep_tv_range = true, output_depth = 10) Rencoded using staxrip x265 2pass 10bit Got green screen Any work around?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
29th September 2016, 05:59 | #311 | Link | ||
The cult of personality
I am using vapoursynth (portable x64) on windows 7 x64. I have this :
I also tried loading it manually via LoadPlugin but didn't work. I installed the windows update that is needed for this to work and everything works like lsmash... I guess the problem is it doesn't load the f3kdb plugin. |
2nd May 2018, 16:23 | #317 | Link |
https://mega.nz/#F!Y10U2LiJ!2H29c5mv5npZiTMdtSwveg
("f3kdb-b98d6bc.7z" is newer. Don't remember exactly what is different, I think some crash-fix or something. So I'd use that instead of the older official build.) |
avisynth, deband |
