10th September 2007, 12:51 | #761 | Link |
Didn't find anyonw that was able to play AVC and AC3 in bluray format. Maybe there something tricky int he authoring pass.
did someone try Encode CS3 ? DVDit pro HD don't output AVC, only mpeg2 If you have a software (can be demo or trial) send me a PM and I'll test it. There should be a new release of Scenarist 4.5 and Rhozet Coder 3 in september.. maybe that will help. |
10th September 2007, 17:19 | #764 | Link |
@Holllydoc
I have all tracks extracted, notice that I have Video, Audio and other (like 10) tracks of a type I cant remember right now, the name has something to do with graphics, I think they are menus parts. Can you tell me the steps to remux them *ALL* in MP2TSME ? Back home I'll get a screenshot of tsremux tracks list and post it if you want. Thanks |
10th September 2007, 19:09 | #765 | Link | |
I had demux the audio.This track is 5.1ch LPCM.I want to Encode it to Flac,but flac.exe doesn't work.Who can tell me why? It tells me: aaa.wav: ERROR: WAVE has >2 channels but is not WAVE_FORMAT_EXTENSIBLE; cannot a ssign channels |
10th September 2007, 21:21 | #766 | Link | |
-New project -Video and audio per drug and drop - PESaliggn yes by Video and audiosetting - Change framerate by videosettings from auto to 23.976 if the tracks from a bluray -muliplex The *.ts is 2-3 bigger then sorce *.ts > TSRemux > Ts or M2ts this step is nessesary for correct size Hollydoc |
10th September 2007, 23:20 | #767 | Link | |
11th September 2007, 03:14 | #768 | Link | |
I'm trying Encore CS3.. will see if I'm able to get farther. |
11th September 2007, 18:26 | #769 | Link |
H264 HDTV Sat records from S*yUK can't be remuxed.
It's a TS File and if i load it into TSremuxer there is the AVC Video Stream and two Audiostreams. But the message NO PCR AVAILABLE appears and it's not possible to remux. Any ideas how to fix the problem with the missing PCR ? Regards , K40 |
25th September 2007, 19:50 | #771 | Link | |
gaps in frame num...
Does anyone have an idea how to clear that flag ? As for AVC and blu-ray -i think 'chicken little' is avc on blu ray. |
26th September 2007, 01:35 | #772 | Link | |
update
The discs have AVC and AC3 and play fine on PS3. I also checked a piece of the AVC in the authoring tool and it does not return above mentioned Flag being set. hope this helps |
26th September 2007, 01:52 | #773 | Link | |
How did you mux the avc+ac3 ? |
26th September 2007, 03:11 | #775 | Link | |
AFAIK tsremux can't import avc & ac3 to mux them together. You need to import a muxed stream... mkv or m2ts/ts.... So what did you load into tsremux? Did you save an HDDVD stream (what format?) with evodemux and load it with tsremux to save it as a blu-ray structure (AVC+ac3)? |
26th September 2007, 04:12 | #776 | Link | |
demux clip from blu-ray ; avc and ac3 ; then mux ; then burn BD-RE this time. Plays fine on PS3 ; as said - when i take avc from HD-DVD i get error in authoring tool - ok ? check private mail for details |
26th September 2007, 12:54 | #778 | Link | |
[QUOTE=hollydoc;1048662]
Full review here: http://bluray.highdefdigest.com/chickenlittle.html |
27th September 2007, 02:17 | #779 | Link |
http://moitah.net/ (only for avi MPEG-4 ASP )
ohhhh we need a mkv MPEG-4 AVC resize tool.....1280x544to1280x720 (without reencode) to fulfill these AVCHD specifications..... Last edited by enjoyer; 27th September 2007 at 02:38. |
1st October 2007, 15:15 | #780 | Link |
question to the experts
tsremux and mkv - i tried a 3 min clip ; it took about 20 min to load into tsremux. by the way - it took about 1 hour to convert from m2v to mkv per minute on an athlon 2600+ (1080p clip) - is that normal? |
