Old 28th May 2007, 10:53   #1641  |  Link
qubic
Hi
I have a strange problem.
I'm rebuilding the Manchurian Candidate, under Linux. That meens EVOdemux (v.0.262) under wine. And use Mplayer.
So fare, there is only DTS(-HD), but no DD+ codec for Linux. VC-1 is fine too.
If I play the full movie (all sub-streams), I hear the Commentary track (which should be DD+ acording to XPL).
If I remove everything in EVOdemux, except VC-1 and the first english track (DD+). I get the usual sound glitches, when there is no DD+ codec(it tries the incompatible DD codec).
If I remove everything but VC-1 and the second english track (DTS-HD). I get this error:
[root@dhcppc0 film]# mplayer FEATURE_1_FEATURE_2.rebuilt.EVO
MPlayer dev-SVN-r23390-4.1.1 (C) 2000-2007 MPlayer Team
CPU: AMD Sempron(tm) Processor 3400+ (Family: 15, Model: 44, Stepping: 2)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE SSE2
Playing FEATURE_1_FEATURE_2.rebuilt.EVO.
MPEG-PS file format detected.
Searching for VC1 sequence header... found
VIDEO: VC-1 1920x1080, 29.970 fps, header len: 33
Requested video codec family [wmvvc1dmo] (vfm=dmo) not available.
Enable it at compilation.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffvc1] vfm: ffmpeg (FFmpeg M$ WVC1)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 6 ch, s16le, 1536.0 kbit/33.33% (ratio: 192000->576000)
Selected audio codec: [ffdca] afm: ffmpeg (FFmpeg DTS)
AO: [oss] 48000Hz 6ch s16le (2 bytes per sample)
Starting playback...
[dca @ 0xe16f20]Not a valid DCA frame
[dca @ 0xe16f20]Not a valid DCA frame000 1/ 1 ??% ??% ??,?% 0 0
VDec: vo config request - 1920 x 1080 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 1920x1080 => 1920x1080 Planar YV12
[ASPECT] Warning: No suitable new res found!
[dca @ 0xe16f20]Not a valid DCA frame001 2/ 2 ??% ??% ??,?% 0 0
[dca @ 0xe16f20]Not a valid DCA frame000 3/ 3 ??% ??% ??,?% 0 0
[dca @ 0xe16f20]Not a valid DCA frame000 4/ 4 ??% ??% ??,?% 0 0
A: 0.5 V: 0.1 A-V: 0.349 ct: -0.000 4/ 4 ??% ??% ??,?% 0 0
Exiting... (Quit)
Which just continous, with counting frames.
Has anybody seen this before???
regards qub
qubic is offline   Reply With Quote
Old 28th May 2007, 11:58   #1642  |  Link
qubic
Hi again
I went into WinXP and tried to remove everything, except vc-1 and the first english track.
I don't see anything in PowerDVD 6.5 (I guess the parser in PDVD is not good enough), but I hear the Commentary, which should be the fifth track?!?!?
I parse the rebuilded .EVO file in EVOdemux, but can't (un)select anything. Everything is grey, with no checkmark.
Is this normal?
regards qub.
Old 29th May 2007, 07:00   #1643  |  Link
Badness
Is there a filter to load a eac3 file directly into a avisynth script without using graphedit?
Badness
Badness is offline   Reply With Quote
Old 29th May 2007, 08:35   #1644  |  Link
SpAwN_gUy
Junglist
SpAwN_gUy's Avatar
I guess not..
well.. i think no .dll, that reads eac3-fileand decodes it internally..
if your DShowFilters are installed correctly,.. you can try DirectShowSource()
you can test that in graphedit ( ) .. by "Render Media file" option. if the proper chain of filters will connect automatically and you will hear Sound ... so then.. you have installed everything right
i think..
Rule Number 6: Concentrate!!!
(c)Hercules, Disney
"I like to build planes.... in the air" (c) some ADV.
tutorials
How to Setup agent-based encoding with x264farm (the easy way)
SpAwN_gUy is offline   Reply With Quote
Old 29th May 2007, 12:30   #1645  |  Link
Warren
Originally Posted by qubic View Post
Hi
regards qub
FFMPEG's VC-1 decoder is not ready for primetime yet.
Recompile mplayer with the referrred codec enabled and it might work.
Warren is offline   Reply With Quote
Old 29th May 2007, 16:44   #1646  |  Link
qubic
Sorry, if I didn't explain myself well.
VC-1 is working fine. I was talking about the sound.
It just depends which sound type I use. Which I think is strange.
And what is a DCA frame??
--qub
Old 30th May 2007, 00:23   #1647  |  Link
Warren
--qub
Just so you know, you will get artifacting with FFMPEG's VC-1 decoder, generally in the form of incorrect macroblocks (you'll know what I'm talking about when you see it).
As for audio, there are no opensource decoders for the codecs commonly in use on HD DVDs and BLU Ray discs (Dolby TruHD, Dolby Digital Plus aka E-AC3, and DTS HD)
Old 31st May 2007, 22:49   #1648  |  Link
akatitan
USING EVOdemux to demux .vob files.
first of all hi to everyone as this is my first post.
Pelican9,
Can you help me? when i use evodemux to demux .vob files it will only demux the first two .vob files. i have tried renaming the files, and even renamed them .evo files. i am using the latest build .626.
akatitan is offline   Reply With Quote
Old 2nd June 2007, 08:33   #1649  |  Link
starkhouse33
any updates for the issues with evodemux and the fountain.
thanks
starkhouse33 is offline   Reply With Quote
Old 3rd June 2007, 15:11   #1650  |  Link
qtx999
Originally Posted by Easy123 View Post
Hello,
I reencoded the DTS HD into AC3 using tranzcode and Sonic Foundry.
can you describe this method? I am trying to convert a dts-hd track to ac3 without much success...
I used tsremux to isolate the dts-hd track (it was around 4GB when done), then tranzcode which recognized the stream and extracted 6 separate wavs all around 1.1GB...The resultant data doesn't seem like it's correct, when I convert these to ac3 (I have several methods, sonic foundry, wav to ac3) all I get are squeeks and static...did I miss a step?
TIA!
qtx999 is offline   Reply With Quote
Old 3rd June 2007, 19:12   #1651  |  Link
Chumbo
Chumbo's Avatar
You can use BeHappy with aften to easily convert a dts track to ac3. For dts-hd, just get the core dts and then feed it into BeHappy using either directshow via avs script or directly using NicDtsSource.
Chumbo
Chumbo is offline   Reply With Quote
Old 3rd June 2007, 21:09   #1652  |  Link
qtx999
[QUOTE=Chumbo;1010431]
QUOTE]
ahhhh...this would be what I need, can you explain how? sorry for my ignorance, when I use tranzcode, it gave me the full stream (as it was about 4GB) ...how to strip just the core stream?
thanks again!
Old 5th June 2007, 18:12   #1653  |  Link
Chumbo
Chumbo's Avatar
[QUOTE=qtx999;1010467]
QUOTE]
thanks again!
Did you try using the SEARCH and search for "dts core?" I believe the utility is mentioned earlier in this thread.
Chumbo
Old 14th June 2007, 22:28   #1654  |  Link
DeepBeepMeep
Does EVODemux support rewriting PMT timestamps when rebuilding the parts of an EVO file like TSRemux? It seems the two EVO files are merged but only half of the movie can be watched because there isn't any continuity between the two files .
DeepBeepMeep is offline   Reply With Quote
Old 15th June 2007, 00:25   #1655  |  Link
dmz01
This is more likely due to sequence_end_code (MPEG2), end_of_stream_rbsp() (AVC), or end_of_sequence start code (VC-1) being present rather than the clock change.
dmz01 is offline   Reply With Quote
Old 19th June 2007, 12:41   #1656  |  Link
3ngel
I can do two little suggestions for the program:
1) Add a copy (to clipboard) contextual menu on the main window (althougt it already does with CTRL+C)
2) Add an option to add to the filename the number of calculated frames (needed in the script). This is useful because it can happen someone forget to write down the number after closing program.
3ngel is offline   Reply With Quote
Old 19th June 2007, 18:30   #1657  |  Link
Chumbo
Chumbo's Avatar
I think it would be more useful to have a new option checkbox to log to file and an edit box to enter the log file location and name like the current Output folder. Or, automatically name the log file and use the current Output folder as the log location. Something like that.
Chumbo
Old 20th June 2007, 08:17   #1658  |  Link
3ngel
Personally i wouldn't need a log, and for me it would be more comfortable to take the number directly from the filename (less files in the dir without the log and no need to open an additional program to read the number from the log), but as an optional addiction to my proposed option, for me it would be fine.
Old 20th June 2007, 10:46   #1659  |  Link
Pelican9
Coder
Pelican9's Avatar
Good ideas....
Pelican9 is offline   Reply With Quote
Old 23rd June 2007, 22:37   #1660  |  Link
Wilbert
@Pelican9,
I'd like to ask some questions about your EVOdemux (i'm using 0.626). I've a bunch of AOBs (accordingly to EVOdemux it contains a MLP track):
Opening file ATS_01_1.AOB
Reading...
File size: 1023 Mbytes.
It contains 1 audio stream.
MLP audio stream 1 found!
   First PTS = 00000294  (+7ms)
   Substream id = A1
   Standard MLP stream (up to 6 channels)
   Quantization length = 24 bits
   Sampling frequency = 96 kHz
   Channel arrangement = Lf + Rf + Ls + Rs + C + LFE
   Dynamic range control = -10,6371 dB .. 8,4282 dB
1) If I demux it, it is demuxed as "ATS_01_1_ATS_01_2.LPCM.stream.01.mpa". Is the MLP converted to LPCM or MPA or is the extension wrong and is it just the MLP file?
2) Does LPCM demuxing from AOB files work correctly?
3) Could you make EVOdemux open source? I've been talking with neuron2 lately, and he's willing to add AOB support to DGIndex, but he has no specs, nor any samples. (I've seen some specs, and will send him a few samples once i bought a dvd-writer to burn them) It would be great if you can work together.
